    Jun 2009
    Georgia
    44 Post(s)
    You don't have to go to a FEA shop to access or use the software. Its an add on to most CAD software these days and its cheap. The idea that if it breaks it wasn't strong enough and then make it stronger sure as hell doesn't take FEA software. We all have been doing that since hector was a pup. FEA analysis requires load/force data as input to work. I sure hope someone doesn't think the loads on a race boat are the same for the Paris race as it is for the Parker race or the loads are the same with Ron Hill driving vs Tommy Posey. FEA is a wonderful tool and I have used it since the early 70's when you had to construct the mesh work manually and a simple run would require the IBM main frame to run all night long. I say again, the result of FEA is only as good as the load input.
  2. Likes Jimboat liked this post
  3. #9947
    Quote Originally Posted by Rotary John View Post
    John is that with homogeneous materials I assume you are talking? If you are taking steel yes very simple process thats downloadable.
    Its not a bracket or metal engine component its a monocoque.
    Does the drop down box have every combo of composite materials, cloth, weave angle, resin, foam density etc etc, I dont think so?
    I think these guys had a business for a reason then good enough to be bought out after years of consulting answers that clearly you couldnt download
    https://www.compositesworld.com/news...s-high-modulus
  4. #9948
    Jun 2012
    England
    5 Post(s)
    Ok you guys—— you’ve proved your point——— and I have to admit——- you’re smarter than the average !
    Im lucky, partly because I always knew my capabilities and limitations——— my problem is——- I love to “Discuss”—— (Argue then, if push comes to shove).
    You can take every one of the equations——- Homogeneous and Composite materials——- bracket and metal component material for the monocoque——- tensile and tinsel, testicle testing tomolites constructed by Roger the robot, in the end——— the guy who takes the finished article —— out on the water and gives it the first shakedown will stand up in front of you——- give you an honest to God opinion of what’s wrong with the damn thing———— and I absolutely guarantee that it will be far more accurate than a thousand print outs from “High Modulus Molecular Monsters” could ever hope for!
    JUST SAYING ,!
  5. #9949
    Jun 2009
    Georgia
    44 Post(s)
    Your NZ company is a composite material company that was bought out by another composite company. I'm not sure what that has to do with the price of tea in China. My point was, FEA is only as good as the input loads, regardless of the material you are trying to analysis. Its those loads that have hundreds of variables on a race boat. Weight, water conditions, speed, load distribution, etc, etc. You get the point. Even if some one could instrument a race boat; which I doubt they have, conditions change and so do the loads. Its back to the old, if it breaks make it stronger. If it doesn't break make it lighter.
    As Jackie said enough.
  6. #9950
    Jun 2012
    England
    5 Post(s)
    There ya go Gene——-Hows that for a sixty footer ?——— think it’s long enough ? —-
    So—— seeing as how it Never was——— you want outboards or stern drives ?
    Just did a count of all the concepts I have on the go at once——NINE——- that’s over double the amount I ever had on the go at once———- I got APACHE——-CIGARETTE——FOUNTAIN——FORMULA—— A couple of tunnels and ten made up stern drives and 24 400 R’s drawn out ready for the new blade!
    If I disappear——— you won’t have far to look——— I’ll be up my own arse!
  7. Likes GENE LANHAM liked this post
  8. #9951
    Jun 2012
    England
    5 Post(s)
ID:	435498Click image for larger version.
ID:	435499Click image for larger version.
    Just some of the ongoing stuff in the shop of JRW INC?
  9. Likes GENE LANHAM liked this post
  10. #9952
    Quote Originally Posted by jackiewilson View Post
    It is Concept!!!!
    Lets go with two of each!!
  11. #9953
    Jun 2012
    England
    5 Post(s)
    Quote Originally Posted by GENE LANHAM View Post
    It is Concept!!!!
    If that’s what you really want Gene——- that’s what it’ll be—— two of each !
    I know there’s been configurations of most form of propulsion—— but I can’t recall there being “TWO OF EACH” on anything.
    Magoon would probably have loved it———-
    See what I can come up with——- leave it with me for a couple of weeks———- I’m up to my fetlocks in “CONCEPTS” of one sort and another at the minute !
    Daughter sam wants me to finish off the pair of CORNHOLE BOARDS I made last month——- she made the eight bean bags, but wants a bit of customisation!
    I picked up a very old vintage lead 1908 Rolls Royce Silver Ghost—— needs fixing to the BONHAMS BARN FINDS concept.
    On top of that, my son Mark is bringing out a new “FAST FISH” boat and needs a concept for his desk!
    Still running Gene—— Life in the Fast line is still a bunch of laughs if you don’t falter—— how close is the MALIBUSTANG to take off?
  12. #9954
    Jun 2012
    England
    5 Post(s)
    Picked up another superb barn find model Ferarri ——— now I’ve got the full set——- BONHAMS Barn find “Concept” is ready for the finishing touch.———- might even try sending them a few phoggies——- see if I can whet their appetite!
  13. #9955
    Jun 2009
    Georgia
    44 Post(s)
    Might want to clean the dust off first.
  14. #9956
    Gentry actually made it across the Atlantic---something Magoon never did---in record time!!
  15. #9957
    Jun 2012
    England
    5 Post(s)
    Jesus wept Gene——— is that a pair of squirts and a surface ?
    Oh well——- soon as you think you’re done, something else comes along !
  16. #9958
    Jun 2012
    England
    5 Post(s)
    Now that looks like a much “BIGGER BOAT” Gene !
  17. Likes GENE LANHAM liked this post
  18. #9959
    Jun 2012
    England
    5 Post(s)
    Johnno———- never came across a genuine “BARN FIND” that wasn’t covered in dust——- just trying to get a little authenticity here————- all the vehicles on the Concept are quite valuable in their own right———— but not one of them is perfect, they’ve all got bits missing and broken parts———
    I must have got it damn near right if it made you comment “might want to clean the dust off first” !
  19. #9960
    Sounnds like a Picasso
Page 664 of 1253 FirstFirst ... 164 564 614 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 714 764 1164 ... LastLast
