Page 50 of 54 FirstFirst ... 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 LastLast
Results 736 to 750 of 797
  1. #736
    Apr 2007
    Quote Originally Posted by That's Right View Post
    Is it what you thought it would be?
    not even close but i can fix it least everything is there
    7 to 3pm 5 days a week
    Custom Fiberglass and Paint
    In Business since 1984
    for sale
  2. #737
    Jun 2008
    North Carolina
    Quote Originally Posted by merctech1979 View Post
    Lou, i was waiting for the word to come from the horses mouth but since he hasnt replied to this thread in a while, i guess i just say it....virgil deals didnt pan out. vessel will be back in my yard in a couple of weeks. if you like i could send you pic of the center conversion when complete. ricky
    Sorry it been a while since I checked on this thread. Sounds good Ricky, just pm me or post some pics up here!
  3. #738
    Dec 2009
    md
    I have a 89 HST at the end of the tunnel their is a adjustable plate ,how much should it be shimmed down?
  4. #739
    Old thread you replied to; but have you read this: http://hydrostream.org/TechTalk/HSTtunnelext.htm
  5. Thanks rtarford thanked for this post
  6. #740
    St Petersburg, Florida
    Any HST's running in Florida or St Petersburg/Tampa area?
  7. #741
    Jul 2010
    Miami Springs, FL
    Quote Originally Posted by rtarford View Post
    I have an 89, but don't know about adjustable plates. It came with aluminum tunnel extensions that protrude past the back but were never adjustable. Never have used them though as I believe they were meant to help when carrying heavy loads and skiing people.
    1989 Hydrostream HST
    1989 Actioncraft Flatsmaster SE
    2006 Baycraft
  8. #742
    Dec 2009
    md
    mine just had some washers between the plates and the hull on the very back edge ,just woundering what speeds are everyone getting? ive gotten 109 at 8200 rpm 28"prop with a full tank of gas on a hot day with a 2.5 280 with a little more playing maybe 112-115
  9. Likes afr liked this post
  10. #743
    Belgium
    Rtarford. Post soms pics of your hst. What prop do you run and How much setback? Any idea how much the hull weighs? 109 is Fast!!!
    http://www.geocities.com/fletcher_arrowbeau
    Fletcher 17F6
    Hydrostream HST 20F
  11. #744
    Dec 2009
    md
    Quote Originally Posted by bigboy View Post
    28in. et don't know what name brand. 12" 4" setback 8Click image for larger version.
ID:	328861Click image for larger version.
ID:	328859" for hydraulic jack plate. no idea how much it weighs. How much
    do they normally weight? It was too windy to get it out last weekend. I only go down there on weekends.
  12. #745
    Jul 2010
    Miami Springs, FL
    You are doing pretty good at 190 with the 280 based on speeds I have compiled from others over the year. I do think you could get it into the teens with work on the setup. I think most of the higher numbers involve a clever usually.Setback looks good, but where are you running the prop in regard to the pad? Weight is a big thing too as others have said. A lot weight in around 950 on the hull, but many nowadays have water in the foam within the sponsors, which can weight quite a bit.
    I have a work steel sleave carbed 2.5 doing 95 with 29 RE4 on a sporty, but I think I can get 100 out of it with another prop and additional tuning on the engine (need new stator and leaning the jets).
    By the way, that is the first HST I have seen handing on davits. How do you have the bow hooked up?
    2006 Baycraft
  13. #746
    Jul 2010
    Miami Springs, FL
    Looking at the picture I don't see any plates on the tunnels. Did you take them off? From this angle it looks just like my 89.
    2006 Baycraft
  14. #747
    Dec 2009
    md
    Quote Originally Posted by rankink View Post
    I used a soft tie down used for a motorcycle 12" long 3800 lbs. nylon webbing doubled over. plenty strong. Hopefully the bow eye won't pull out! The 2 stern eyes pulled out luckily I caught it b/f the boat dropped. Had to reinforce the stern and put bigger eyes, now it's good.
  15. #748
    Dec 2009
    md
    I had washers between the back edge of the plates and the tunnels but reading an article on this site I took them out and sealed up around all the edges. I haven't had a chance to put it in the water since then, hopefully it was the right thing to do?
  16. #749
    Belgium
    Had it in the water yet? Wondering if it made any difference. Why don't you just take the ally plate away?
    Fletcher 17F6
    Hydrostream HST 20F
  17. #750
    Dec 2009
    md
    Made a big difference. I bought this boat when I was 25 , I'm pushing 50 now. I was never able to lift the bow with using the trim on the engine. The nose was very heavy and I had a hard time breaking loose from smooth water. Last time out that all changed, the plates aren't pushing the nose down anymore. It was hard to get between 90 & 100 with the tabs down. Now its easy but I have to learn how to fly it all over again.
