Page 65 of 142 FirstFirst ... 15 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 115 ... LastLast
Results 961 to 975 of 2122
  1. #961
    Yes aka m2.
  2. #962
    Long Island N.Y.
    [QUOTE=Greg G;2789182]Is this the gearcase Dirk has?[/QUOT
    thats the case, so kevin it would be safe to block up the side inlets? figuratively speaking of course
    21 Tuff, Mercury 300X
  3. #963
    Jul 2004
    Connecticut
    Yes aka m2.
    Thanks. What does the standalone smaller hole #7 do on these Magnum 2 lower units?
  4. #964
    Tells you how fast you are going?
  5. Thanks baja200merk thanked for this post
  6. #965
    Yup speedo
  7. #966
    Jul 2004
    Connecticut
    Gotcha guys on the speedo hole. Pretty simple plastic bag fix for the side inlets you found Baja200. Should be interesting to see the speed differences. Gotta be worth 4mph.
  8. Thanks baja200merk thanked for this post
  9. #967
    Sep 2010
    long island,ny
    A tuff boat run? Be kinda lonely no Joe?
    When Joe gets more comfortable driving his new toy then I will set-up a little Peconic Bay Run for .....hopefully end of Sept- early Oct. if there is interest ! ??
    1990 22' Activator Yami HPDI 300-sold-86.4
    1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
    1982 21' Superboat 300merc-87
    1990 22' Activator yami OX66 Vmax 250-84.2
    1982 30' Scarab-twin 200 Merc-sold
    1979 21' Challenger 300 Evenrude-sold
    1979 21' Superboat 200 Merc-sold-72
  10. #968
    And the blow out speed for this stock profile lower is?
    Jul 2004
    Connecticut
    The m2 is 5.25" my sporty is 4.5". It's not only diameter that's the killer it's the fact the sporty is more hydrodynamic and can be setup to go faster. Yes the m2 has forward pickups. I have run a fleetmaster on the front holes and as soon as the motor is high enough water pressure drops due to the side pickups being bone dry. Oh, and with no nosecone they run great to 89. at 90 they blow out and almost chucked my buddy out of his mirage.
    When you take a close look at the funky BRP Mag2 lower unit it's interesting to see how high the 6 factory water inlet holes sit on the nose of the case to begin with. It makes me wonder if someone running a notched transom hull (with between 12" and 18" of setback) could carefully tap and close the very top 2 inlet holes and get the same or better water pressure running the remaining 4 on the M2. Seeing the threads in the top 2 holes would affect warranty though I suspect.
  12. #970
    I moved the low water pickup holes to the bottom of the bullet like a sporty and ran this lower to 104 with no nose cone but the case was very high. It would have went faster but I was on the rev limiter with a 2000hour 200HO
    Like this, the pickups actually are lower then a bobs come if you do it correctly. I don't know if he tuff will carry the bow with themotor as high as I had it.
  13. #971
    Prince George B.C. Canada
    That doesnt look to bad at all. Other than the covering on the upper holes. haha You could plug those up nice and {Smooth} with some danaglas then paint white and look factory..
    The sides shape its self looks good I think! It looks like it would carry well.
  14. #972
    Titus modded Magnum is sweet!!!
  15. #973
    Quote Originally Posted by whipper View Post
    That was a pic of a guy I helped do the mods it wasn't finished when he took the pic. Mine looked factory and I filled in the side water pickups and shot the whole motor with brp white. I did it like 4 yrs ago so i can't find any good pics. Here's mine from a few boats ago
  16. #974
    Love that mid!!
  17. #975
    Jul 2004
    Connecticut
    I was thinking the same thing. Would Dirks ETEC 300 below with the dual side water inlets (plugged with totally removable BajaBags) allow the 100% factory stock M2 lower unit to be moved up so high that it will cause it to blow out above 90mph. The M2 case has to be kept bone stock to keep the 7 year factory warranty. I'm not even sure that adding an epoxy torque tab would be allowed.
  1. Any Jet boat shops long Island NY??
    By Jo Jos Fountain in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 05-19-2014, 09:01 PM
  2. long island boat events
    By mercracer2.5 in forum Upcoming Events, Races, and Gatherings
    Last Post: 07-29-2011, 02:39 PM
  3. Long Island Boat Accident
    By lightspeed in forum General Boating Discussion
    Last Post: 10-09-2009, 02:56 PM
  4. need help with boat LONG ISLAND???????????????
    By 21eagle in forum General Boating Discussion
    Last Post: 05-18-2009, 02:03 PM
  5. any boat appraisers on long island?
    By wbones9 in forum The Scream And Fly Lounge
    Last Post: 07-16-2008, 04:22 PM
