Page 29 of 142 FirstFirst ... 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 79 129 ... LastLast
Results 421 to 435 of 2122
  1. #421
    May 2001
    great south bay
    Quote Originally Posted by THE HOSER View Post
    How much faster did Eddie go after the bottom was cut ?
    Billy, Your boat Has No Notch Right? Did you ever weigh your boat?
    Not to pit one against the other just a question......
    Who was faster Dirk Pitts 21 with X or yours?
  2. #422
    I think it also makes the boat smaller. Have been unable to run the sportmaster any where near as fast as the coned torquemaster. I believe cause I run out of hull in the water and roll side to side on the sportmaster bottom. Hopefully Titus will correct this cause I would love to have more skeg in the water which will allow me to run the motor much higher with good water pressure.
  3. #423
    Jul 2015
    Canada
    Quote Originally Posted by DoktorC View Post
    It's not the boat RBT is referring to (which runs an XS)...That was one of the original boats and the dude who bought it used it once and put it in storage with his collection of sports cars he never drove. I forgot all about that one...full carbon race hatch with a flood coat on the inside.
    The guy driving this one said it does 106 with some kind of prop and 99 with the non-labbed version. I forgot which kind unfortunately
  4. #424
    You can see how the water comes off the notch here like a big trim tab pretty much eliminating chine walk.
  5. #425
    Longer l/u bullet= more stern lift. Notch might be a little big? Not detracting, just observing. You are at neutral trim with the bow fairly high in the pic.
    I personally think notch is a little to deep. The notch they did on my Challenger was perfect. But my super was built for one purpose and that was to be the fastest. Time will tell
  7. #427
    May 2001
    great south bay
    Did you ever consider putting it back to normal? Then sporty wont need mods either!
  8. #428
    Quote Originally Posted by 2.5-21 View Post
    No the boat is light and believe me speed is not a problem, Im positive it will be much cheaper to have the sporty blue printed than have Raybo fill the notch.
  9. #429
    Maybe tweak the area where the notch intersects the trans with some bondo and make a lil hook on it. 1/8'' or so. If it works, replace with gell.
    Jan 2007
    Amityville/Lindenhurst
    Mike your boat has less notch then eddies, he had no problem running sportmaster.
    maybe dirk can check his folder and post how big his notch was
  11. #431
    Rob you mean Eddies blue challenger? Maybe weight has something to do with it? Superboat is 10" Challenger was 8". Joe didnt have a problem running a sporty on his super either but I think his notch was 8" also. Im also running a 1 1/2" above the pad and would go higher if I had water pressure.
  12. #432
    Jan 2007
    No ed L's superboat. The last 21 made with the old deck, was also running a 15" 300x
    if waterpressure is theonly issue why not a external water pickup?
  13. #433
    Quote Originally Posted by RobF View Post
    Ah dont know the boat. Cant run a 15" on mine, the BIA is to high but I really dont see the need. Joe always said his best speed was with prop shaft even with his bottom.
  14. #434
    Jan 2007
    Keep at it mike you will get there
  15. #435
    I know Rob I have to call you after the summer and bring it up to have a couple things taken care of.
  1. Any Jet boat shops long Island NY??
    By Jo Jos Fountain in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 05-19-2014, 09:01 PM
  2. long island boat events
    By mercracer2.5 in forum Upcoming Events, Races, and Gatherings
    Last Post: 07-29-2011, 02:39 PM
  3. Long Island Boat Accident
    By lightspeed in forum General Boating Discussion
    Last Post: 10-09-2009, 02:56 PM
  4. need help with boat LONG ISLAND???????????????
    By 21eagle in forum General Boating Discussion
    Last Post: 05-18-2009, 02:03 PM
  5. any boat appraisers on long island?
    By wbones9 in forum The Scream And Fly Lounge
    Last Post: 07-16-2008, 04:22 PM
