Page 61 of 105 FirstFirst ... 11 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 ... LastLast
Results 901 to 915 of 1571
  1. #901
    Aug 2002
    florida
    Chris wow factor always makes em run better.glad to see it all come together
  2. #902
    Aug 2004
    Venice, Florida
    Quote Originally Posted by ultrafast View Post
    You going to St. Johns run? I still have some $ for you.
    21' Paramount
    Mercury 300 Promax
  3. #903
    Aug 2004
    Venice, Florida
    Jackplates going back on. Ran 65 miles today and it was a handful. Motor needs to come down about 1/2" and I cant do that without flipping the jackplate or notching the transom. Trying the jackplate first.
    The back kept trying to pass the front today. Just a little too high. It was fine in slick water but any chop or small wakes and it was like trying to drive a skateboard an on ice rink.
    Drove through the worst rain ever on a boat and again driving home today.
    Thanks for the pics Regan.
ID:	301362 Click image for larger version.
    21' Paramount
    Mercury 300 Promax
  4. #904
    Jun 2009
    Middle USA
    The skeg looks pretty big too... Surprised it looses grip.
    L6fan57-88
  5. #905
    Aug 2004
    Venice, Florida
    Well it look like even with the jackplate Ill have to notch the top of the transom some.
    21' Paramount
    Mercury 300 Promax
  6. #906
    sw florida
    Can Marty take .5 out of the swivel bracket and
    then put a collar/shim on the bottom.?
    Dago
  7. #907
    Aug 2004
    Venice, Florida
    I have a plan, stand by...
    21' Paramount
    Mercury 300 Promax
  8. #908
    Sep 2002
    Dublin, Ireland
    Just thought I'd stick up a pic of the finished yam V4 cowl.
    Power Marine 650 Offshore Race, Yamaha 130 Pro-V
  9. #909
    Aug 2004
    Venice, Florida
    Quote Originally Posted by Alan Power View Post
    Cool Cowl! Tell me about how you made it and what it weighs.
    After a lot of head scratching, bloody knuckles, and a broken pinky toe from an epic toe stub on the engine hoist wheel, I was able to lower the motor 1/2" and back 1-1/2". That should settle it down and it may need to come up a little but we will see, If it works well, I'll pull the jackplate back off and just make some 1-1/2" setbacks.
    Had to grind off the little "hooks" under the tilt tube that hang over the transom. Steering barely clears and I have to watch how far I tilt it up.
ID:	301456 Click image for larger version.
    21' Paramount
    Mercury 300 Promax
  10. #910
    Aug 2004
    Venice, Florida
    The sacrifices we make in the pursuit of speed!
    21' Paramount
    Mercury 300 Promax
  11. #911
    Sep 2002
    Dublin, Ireland
    Quote Originally Posted by Mr. Demeanor View Post
    About 200 hrs sanding and it can be as light as you like!
    A lot lighter than the stock cowl that's for sure!!
    next I want to do a light weight tray to go with it!
  12. #912
    Aug 2004
    Venice, Florida
    Well the boat runs great and handles a lot better. It likes the extra 2" of setback with less hop letting my run it flatter. Turns MUCH better and doesnt dance side to side as bad in chop.
    Now the bad news. The mid cracked. THIS IS NOT A WELD THAT MARTY POWELL DID. Marty did not do any work on the actual mid, only on my swivel. The mid itself was cut and welded by Bob Kottman for Bob Lipton. When I bought it from Lipton he told me it had a small crack and that is had never grown over years of use but that he would weld it for me. Lipton is a prop guy so I figured might as well have him weld it. Unfortunately it cracked again in the same spot but the whole side. It had been fine for about 150 miles of running but I got into some rough water and being a full tunnel, the lower units just takes a beating.
    Marty is going to fix it and we are making it super strong maybe with some plates on the outside as well. After its welded, we will surface it to make sure it perfectly square.
    Im more pissed about the paint as it came out a perfect match and I dont think I have enough to do another.
    21' Paramount
    Mercury 300 Promax
  13. #913
    East Wallyworld Vt
    That crack went pretty far in a short time, would have been interesting had it not been detected. Nice thing about play toys is they get looked at more often than a daily use item.
    Regards,
    Charlie North
    If it ain't broke, modify it.
    87 Glastron CVX20 Hull
  14. #914
    Aug 2004
    Venice, Florida
    Quote Originally Posted by CharlieN View Post
    Funny you mention that. I was at the spring and a kid on a watecraft bumped into my boat. I was looking at the transom where he hit for damage (just a bump when I saw the crack. The kid may have saved me some real damage.....
    21' Paramount
    Mercury 300 Promax
  15. #915
    Dam Dude 2 steps forward and one back. Good for you finding that before it bit you.
