Page 35 of 72 FirstFirst ... 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 ... LastLast
Results 511 to 525 of 1076
  1. #511
    Jun 2008
    kingman az
    it sure looks wild...
  2. #512
    Quote Originally Posted by BarryStrawn View Post
    Of all the ways to add a two speed transmission, the Deuce High has to be the worst. The only positive design feature is that it might bolt on to a standard midsection. Which is probably what some idiot in marketing decided was the critical feature.
    but its not a std mid though is it?
  3. #513
    Dec 2001
    Find the rite prop and build aroun it......
  4. #514
    Jul 2005
    Locust Grove, OK
    That's what I'm talking about right there!!!!! I like your way of thinking!!!! Of course, I might be somewhat prejudice??? haha
    Cause, you can have everything else & if the prop can't get you there, then ....... you're screwed!!!!!
    Thanks,
    Tim Bostic
    Hoss Marine Propellers
    www.hossprops.com
    918-479-5167 (shop)
    Pugh Hydro w/260 Merc - 12" mid
    1987 XB2002 Allison w/2.4 EFI Merc - 15" mid
    1985 XR2002 Allison w/2.4 EFI Merc - 12" mid (Restoration Project)
    "New" - 1987 XTB21 Allison (Refurbished at the Factory!!!!) w/'99-225 ProMax Merc
    Top Speed Blog - http://www.screamandfly.com/blog.php...OSS-quot-Style
  5. #515
    Jul 2005
    Locust Grove, OK
    google it
    Mercury deuce high
    Quote Originally Posted by rock View Post
    this it
    Cool ...... I've never seen or heard of this !!!!!
    I must be "out of the loop"??? hehe
    Thanks,
    Tim Bostic
    www.hossprops.com
    918-479-5167 (shop)
  6. #516
    Central Florida
    Note I said it "might" bolt on. I would guess someone in engineering found a way to make it need a special midsection and be even more expensive. I recall someone from Merc saying it ended up costing more to manufacture than the whole engine retailed for. I think they made two or three.
  7. #517
    Mar 2002
    N.E. Ohio
    this it
    I'll never forget the first time I put my hands on that thing. Brings a tear to my eye....Anyway, I know that Duece High was mean, it ran on some boats and put up some impressive numbers
    Mirage Jaguar RiverRacer
    Polaris PRO785
    Bennington 255LCC
    Scream & Fly Flying Machine of the Month:
    September 2005
    http://www.screamandfly.com/showthre...ild&highlight=
  8. #518
    Tennessee River
    Quote Originally Posted by Hoss Marine Propellers View Post
    The two speed Lenco is the way to go, for sure!!!
    A good friend of mine, Dave Bentley, built one inside a 20" mid & stuck it on an Allison XR2001 (Late 80', early 90's???). The gear ratio was pretty close. He would down shift it (underdrive) to start and zip up to 6000 rpm, shift (air-shift) into direct drive (1:1)and the rpm would drop back to 5000 and start pulling again..... Never let off the throttle!!! The boat had a small wobble when the shift happened ...... other than that, it ran great!!!!
    There are many, many ratios to play with.... To overdrive the Lenco, just turn it upside down. It's a bullet proof transmission too!!!!!
    I use to have a video of it running, but haven't come across it in years & wouldn't know where to look? It was cool to hear the rpm change so quickly and the boat take off again.
    Jons/Todds 2 speed trans is a B&J unit designed for a Top Fuel Harley. Jon had to modify it to run vertical and be able to keep water out of it. It is a planetary trans like a Lenco but Jon being Jon saw how much lighter it was and would withstand the power he was making. It is a underdrive in low and 1 to 1 when shifted. We never tried turning it over to get a overdrive because we were drag racing with it. Like you said it is way cool when a outboard shifts gears. The crowd at Augusta went nuts but the record was set that weekend without it but with the lightweight tube midsection Jon built for it.
  9. #519
    Apr 2011
    grove ok
    Tim I meet you at the Grove boat race I worked for Dave when we shut down the shop I saved alot of pictures from the dumpster. I think there some pictures of the turbo motor with the 2 speed installed Ill go thru them and post them up.
  10. #520
    Jul 2005
    Locust Grove, OK
    Quote Originally Posted by doubleeagle View Post
    Wow.. Man, that would be great!!!!
    I have a few pictures somewhere??? Not many..... back then , we didn't think about documenting much of anything....... wish we would have, cause now it's pretty cool thinking about it and talking about it.
    Thanks,
    Tim Bostic
    www.hossprops.com
    918-479-5167 (shop)
  11. #521
    Ohio
    I am going to try and start sorting some of Jon's items this weekend and I will start a posting them in the Buy and Sell titled "Jon Wright's stuff". Not sure what we are getting rid of yet, but the boat, transmission and big motors are staying with us.
  12. #522
    Dec 2001
    The old OMC V4 record boat... starflight used a 20 percent overdrive gear case made by Hubbel. That gear case had 1to1 gears with a overdrive set up top.... a sun planet set.....Small gear running in a big open gear. I think ya going to need a tow boat or a 2 speed.....
  13. #523
    Tennessee River
    Quote Originally Posted by aerotech View Post
    I believe the record of 176 is not out of reach. In 1995 I took a Gary Pugh 16' hydro (Jon Wright's old Doo Dad), an Earl Moorman 2.5 on alcohol well over 400 hp, with a Wright's device and my own NOS system (.040 NOS holes and .038 fuel holes per cylinder approx. 175-200 hp.) and ran on a radar gun 168 mph spinning almost 10,500 rpm on a 1.1 #4 with one of Jon's props (remind you these props are for 1/4 mile, we had no top end props.) This was further than a 1/4 mile, stretching it out a bit. The motor needed more prop, but the boat and I had enough. It could have taken more pitch, but this was the biggest prop Jon had at the time. If someone has a way to take video from a VHS tape and put it on youtube, I will send it to you to post. Let me know, I'll dig for it. I want to do it with a true outboard first, than let's see what the future holds. Crawl, walk and run theory.
    Lets get back on track here. Todd has already done the above.. Now he has a more effecient hull but not by much because that 4 point Pugh was about as good as it gets. He ran that boat about 30 mph faster than it was supposed to go but made it work. A tad more horsepower with the current 2.5 nitrous set up on the outrigger if it works as advertised and with a LOT more gear/prop and I am pretty sure the current record is well within sight. Where it goes from there to 200 remains to be seen.
  14. #524
    Ohio
    Ok, got the first video posted. I do not know who took this video, but some how I have it. I cut the part out of Tom Kunzmean's death, we have the full footage, it is heart breaking and I did not feel like it was right to air it. RIP Jon Wright and Tom Kunzeman. https://www.youtube.com/watch?v=v93UsmMA5UE
  15. #525
    Jul 2005
    Locust Grove, OK
    Hey Todd,
    Thanks for posting the video. I didn't think there was any video of that race either. It was really bad when Tom crashed..... so sad.
    Do you have any other video's from that race of any other classes? I was running in my Allison in the outside lane against my good friend Larry Harrel in the inside lane in his Mirage. He blew it over and went thru the steering wheel & dash. I think it was the next day after Tom's crash? He barely survived that crash .... it was a long drive back to Oklahoma for all of us after loosing Tom & almost Larry. Larry stayed in the hospital at Augusta for about a week before he got to come home...... it took all Winter for him to heal up. That next Spring, Larry blew his new Mirage race boat over & passed away..... it was 2-2 1/2 weeks before we found the body..... never found the boat!!! Just wondering if anyone had the video of our race?
    Thanks,
    Tim Bostic
    www.hossprops.com
    918-479-5167 (shop)
