Page 19 of 23 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 LastLast
Results 271 to 285 of 332
  1. #271
    Chatting with a European racer on the weekend he said they are all fed up with buying new engine designs every couple of years as the UIM with Merc dictate what happens.
    When he looks at a pair of 300's from a about 5 years ago to what they need now, its more than doubled in price.
    Put the race engine brand out to tender story coming back again
    They have heard Honda is looking around...
  2. Likes David - WI liked this post
  3. #272
    Jul 2004
    Connecticut
    Quote Originally Posted by FBM View Post
    Will do, we are going to hang it on a 2 seater XB21 just to see how it does on a tournament rigged boat so I will throw it on the scales at that time.
    I weighed a 250R with Darris back in 2018 and it was 560lbs, oddly enough the R cowl was 34lbs and the Pro XS cowl was 27lbs. I cant imagine the R mohawk weighs 7lbs...
    Getting an accurate weight on the V6 200R versus the V8 300R's 561 lbs will be interesting for sure.
  4. #273
    Sep 2021
    Grand Rivers, KY
    FBM you need to hang the little fella on a scale and get a true weight. Not sure what Merc has placed on the tag but the big 300 R weighs 561lbs
    Engine, full of fluids w/ 5.44 SM - 484lbs
    Cowl - 30lbs
    Total - 514lbs
  5. Thanks Greg G, David, David - WI thanked for this post
    Likes David, NCKH liked this post
  6. #274
    Apr 2023
    Long island, NY
    Cowl - 30lbs
    Total - 514lbs
    Did you weigh it without fluids? Mercury lists the weight without fluids. Mercury lists the 200R SM weight as 489lbs. dry, with the cowl, no prop. 514-489=25lbs. 25lbs for 7 Quarts of motor oil and a quart of gear lube sounds about right. Looks like Merc published the correct weight for the motor.
  7. Likes aj06bolt12r liked this post
  8. #275
    Sep 2021
    Grand Rivers, KY
    Quote Originally Posted by skialot2 View Post
    We did not drain the fluids, weights above are with engine oil, filter, g/l, and some gas in the fuel system. One thing I will mention, this is not an off the shelf 200R w/ DTS....this is a mechanical test engine that we have been running for Allison and Mercury Racing. There could be some variance there, but not much.
  9. Likes skialot2, aj06bolt12r, Greg G liked this post
  10. #276
    Lake Coochiching, Ontario
    What is g/l ?
  11. #277
    Sep 2021
    Grand Rivers, KY
    Quote Originally Posted by David View Post
    What is g/l ?
    G/L = Gear Lube
  12. Thanks David thanked for this post
  13. #278
    Apr 2023
    Long island, NY
    Did you weigh the motor with or without a prop? I heard the DTS has a total weight of less than 3lbs for the entire system.
  14. #279
    Sep 2021
    Grand Rivers, KY
    Does not include a prop, hub kit, or steering system.
  15. Thanks David - WI, skialot2, Greg G thanked for this post
    Likes skialot2, hellbents-10, Greg G liked this post
  16. #280
    Jul 2004
    Connecticut
    FBM you need to hang the little fella 200R on a scale and get a true weight. Not sure what Merc has placed on the tag but the big 300 R weighs 561lbs
    Engine, full of fluids w/ 5.44 SM - 484lbs. Cowl - 30lbs. Total = 514 lbs
    514lbs for the V6 and 561lbs for the V8. 200R is heavier than we would have thought. Appreciate the info FBM!
  17. Likes FBM liked this post
  18. #281
    Dec 2009
    middle tennessee
    Honestly for that little of a weight difference and the fact that they both run the gigantic diameter gearcase.. I see little or no reason to run a 200r... For 100hp Ill take the extra 40-50lbs
  19. Likes Greg G liked this post
  20. #282
    Jul 2004
    Connecticut
    514 lbs ..... Great data from FBM
  21. Thanks FBM thanked for this post
  22. #283
    Jul 2004
    Connecticut
    So the new V6 200R digital scale weight is 514 lbs and the V8 300R tallboy is 561 lbs. Is it accurate that Mercury only offers the 200R in DTS so that you can not plug it into any older rigging?
  23. #284
    Dec 2009
    middle tennessee
    That is correct. DTS only. It requires new rigging. I called around to a few dealers. You cannot rig yourself. You must pay the dealer to rig it for you.
  24. #285
    Aug 2015
    Southeast
    Quote Originally Posted by aj06bolt12r View Post
    That seems like a money grab. Why would they force you to use dts instead of cables??
    STV ProComp w/ 225 Promax
    STV Procomp with 280
    25 Liberator "The Battleship" Sold
    Blazer 650 Pro Tour
    30ft Cobra with Triple 280's
  1. Caldwell Racing Technology Introduces Billet 2.5 Liter V6 Engine
    Last Post: 02-19-2024, 09:16 PM
  2. XS Series-Custom Built From Mercury Racing.
    By 4-strucked in forum General Boating Discussion
    Last Post: 05-09-2012, 10:23 AM
