Results 181 to 195 of 332
03-04-2024, 05:13 PM #181
03-04-2024, 06:56 PM #182
03-25-2024, 01:17 PM #183
So anybody care to check my Mathimates on Vizard's 128 rule
this assumes a 10.5 compression chamber so this would need some welding up to bring it up to spec similar to the an LS3 chamber
from what i could find a flattop piston would be desireble with valve releases offcourse
183 183 cubic inch
Cubic Inches motor number of cylinders Cubic Inch Cyl valve size value divide by LSA
vizard 128 LSA rule 183 4 45,75 2,00 0,91 128 equals 107,18375 LSA
Graph number
Graph value overlap divide by Graph Calc number LSA GCN+LSA Times
Lobe Duration Degree
number 5 value 70 divide 2 outcome 35,00 + 107,18375 Lobe Duration 142,18 times 2 equals 284,3675 total LOBE duration
LSA Graph
powerabout liked this post
03-26-2024, 01:57 PM #184
Ronnie ... I'm not much for doin "maff a ma tistics" ..
But experience tells me 10:1 will run on 92 octane. Especially when ya bleed some of it off with an intake lobe thats around 220-225* @ .050 lift. Ten more on the exhaust will help get rid of pumping losses.
110 to 114 LSA will help out with the "high gear only" no trans or converter to flair, situation that Vizard's numbers .. provide as optimal.
A 20 year veteran of Rottler CNC porting moved a couple doors away from Extreme cly head. He takes care of "everything" that's not related to air cooled Porsche heads.
He is up and running. brought me an LS head to weld up the broken / customer tried to remove the broken stud .. turned into a 1/2" bomb crater hole ..
I asked him .. think you can do any of these Merc-yota porky heads. He said I have over 1200 programs on file .. digitizing a few more wont hurt a bit ..
BTW .. Merc raised limiters on all their R+D motors. Like any mfg. they need to see what the motor will take .. before handing a tamed down version to John Q. Public who can break an anvil with a rubber mallet and demand a new anvil .. so yea, they can, but don't offer a "stepped on" model ..
Ronnie is talkin about doin an aftermarket PCM .. that way you don't need to beg the evil mother for crumbs .. you just write your own .. ifin ya can ..
03-27-2024, 02:55 PM #185
If i can get some cash together i will look for a cheap head on ebay
Getting some hands onLast edited by PanRonnie; 03-27-2024 at 02:58 PM.
Tcatrett liked this post
03-29-2024, 08:20 AM #186
$550.00 US .. Merc probably want's that much for a camshaft ..
Nice thing about having a cam core is that it can be put on a "cam-doctor" machine. It will print out the exact numbers on what each lobe value is. Then it can be welded / re-ground to whatever you want it to be.
It will need valve springs too ..
03-29-2024, 12:01 PM #187
03-29-2024, 02:07 PM #188
04-02-2024, 11:29 AM #189
Just finished break in on this one. Going to test some props and a 175 sport master from the V8 soon. Ran 77 so far 26 fury with 35 lbs of water psi.
07-24-2024, 12:51 PM #190
Supporting Member
- Jul 2004
- Connecticut
- 6,265
- 518
- 205
- 1075
- 1127
07-24-2024, 01:04 PM #191
If they take a saterday to go through some catalogs they can put something together
07-24-2024, 03:02 PM #192
5000 RPM
- Apr 2010
- Indian Lake Ohio
- 337
- 79
07-24-2024, 07:09 PM #193
07-24-2024, 07:52 PM #194
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,337
- 1068
- 413
- 4734
- 2179
- 9 Post(s)
John S liked this post
08-29-2024, 12:23 PM #195
I believe I'm eating crow. I think I saw one in a video this morning. They called it a 225R anyway.
Allison XB21 2+2
Caldwell Racing Technology Introduces Billet 2.5 Liter V6 Engine
By Scream And Fly in forum General Boating DiscussionReplies: 238Last Post: 02-19-2024, 09:16 PM -
XS Series-Custom Built From Mercury Racing.
By 4-strucked in forum General Boating DiscussionReplies: 6Last Post: 05-09-2012, 10:23 AM
