Results 316 to 330 of 1397
Thread: 15 400R news
11-13-2015, 08:25 PM #316
The Historic Photo Master
- Jan 2004
- Florida
- 38,660
- 78
- 1764
- 384
- 20403
- 4 Post(s)
11-13-2015, 08:34 PM #317Mirage Jaguar RiverRacer
Polaris PRO785
Bennington 255LCC
Scream & Fly Flying Machine of the Month: September 2005
http://www.screamandfly.com/showthre...ild&highlight=
11-13-2015, 08:41 PM #318
Platinum Team Member
- Jul 2003
- Discovery Bay, CA
- 1,616
- 46
- 9
- 475
11-13-2015, 08:43 PM #319
- Jan 2004
- Florida
- 38,660
- 78
- 1764
- 384
- 20403
- 4 Post(s)
Your the exception, not the rule. You can remove them if you'd like. Only on the fastest boats out there, boats like yours, does it make the most sense. The majority of owners leave them on. Most common for boats left in the water, unlike yours & raceboats. I come from a Merc era when this was the standard clamp bracket on all Merc V-6's. We drilled new transoms for these clamp bracketed motors and would never think of removing those zincs. They double as support to hold the two clamp bracket halfs aligned properly during and after installation. Are they meant to hold the entire clamp assembly from failing? No. But they provide clamp alignment & prevent clamp bracket movement, when your transom bolts stretch, transom compresses, and otherwise gets loose, which then works your tiltube more.
11-13-2015, 08:44 PM #320
- Jul 2003
- Discovery Bay, CA
- 1,616
- 46
- 9
- 475
Merc has us all in a headlock - I know guys spending $50k for a new long block, $100k for a new complete 1,350 when they blow up out of warranty. Even $27k for a new standard 400R is a lot of $$$. I know all my boats are old now, but I'm glad I've got them and they're paid for! No new builds for me in the coming years........
11-13-2015, 08:49 PM #321
- Jul 2003
- Discovery Bay, CA
- 1,616
- 46
- 9
- 475
If this is true (and I believe you that it is), why isn't that piece made out of a strong material?
They could mount an anode in another location to take it's place, letting that piece be a truly integral (and strong) part of the transom bracket. You can break one of those anode pieces with your bare hands.
11-13-2015, 09:09 PM #322
- Jan 2004
- Florida
- 38,660
- 78
- 1764
- 384
- 20403
- 4 Post(s)
Again, your thinking about your world, your boat, your application. It doesn't need to be any stronger for the average boat, the other 97 percent of the other boat types that these clamp brackets were used on. It been unchanged since its inception in '79. Years ago, I remember discussing Bravo drive & transom plate warranties with my OEM Merc Rep regarding they're failure rates in the first 5 years of Bravo One drive production, back in the late 80's, early 90's... (Let just say I built a few hundred offshore powerboats) He politely reminded me that 90% of all his MerCruiser drive warranty issues, came from less than 10% of his customers. I don't know why I brought that up(?) lol
11-14-2015, 04:48 AM #323
11-14-2015, 04:51 AM #324
11-14-2015, 06:55 AM #325
The skirt is basically part of the cowl for that look. Im guessing its a heavy mother all in all top and bottom cowl. It would be interesting to know how much just the drop on weighs? Carbon pieces by Mike Nass could probably cut the weight down considerably. Sweet looking behemoth for the rich and famous for sure!!
Outa my league unfortunately. Merc needs to up the boost on the Verado 200 to 325 and some one make a 15inch to SM for them.
That would be an interesting project and light weight. Shouldn't be a problem getting big hp from that block. 1.5lt indy cars seem to not have any trouble getting 900+++HP from a couple of litres.
noli liked this post
11-14-2015, 09:00 AM #326
5000 RPM
- Dec 2013
- georgia
- 550
- 31
- 24
- 57
- 65
Im with you on this one. I dont need to wait on mercury to turn up anything just find me two donor verado i4 motors and access to a dyno im sure we can sqeeze an extra 100hp -200hhp out of it with a aftermarket standalone system. Mercury did all the hard work already from a engine builder and tuner point of view its 4stroke and force induction. Guys no matter what you think or feel can be removed or lightened. the verado i6 will not get any lighter just think about all the different components it has over a two stroke motor. im focusing my energy on the verado i4 boost n fuel is all the love it needs to make more power and its only around 500lbs.
11-14-2015, 11:35 AM #327
11-15-2015, 01:45 AM #328
They double as support to hold the two clamp bracket halfs aligned properly during and after installation. Are they meant to hold the entire clamp assembly from failing? No. But they provide clamp alignment & prevent clamp bracket movement, when your transom bolts stretch, transom compresses, and otherwise gets loose, which then works your tiltube more.[/QUOTE]
That makes sense but that is not the definition of "structural".Last edited by F14; 11-15-2015 at 01:48 AM.
tux974 liked this post
11-15-2015, 03:31 AM #329Markus' Performance Boating Links:
11-15-2015, 06:15 AM #330
They are far from structural!
The only purpose they serve is sacrificial if you keep your boat in water especially near any (EMF's) electrical magnetic fields....
Certainly not important or necessary if you trailer your boat......
About done, Stroker/400R
By npark in forum General Boating DiscussionReplies: 147Last Post: 08-07-2016, 08:28 PM -
Eliminator 28' w/ 400R
By noli in forum General Boating DiscussionReplies: 44Last Post: 04-11-2016, 10:28 PM -
Skater 400r
By AZMIDLYF in forum General Boating DiscussionReplies: 48Last Post: 10-31-2015, 10:55 PM -
PLEASE READ - Bad News and Good News from Florida Drags
By Sam Baker in forum General Boating DiscussionReplies: 23Last Post: 06-16-2004, 07:28 AM
Sometimes this internet stuff sucks, because if we were all sitting around BS'ing, we'd all have big smiles on our face discussing this crap - even if we disagreed on some things.
