Page 27 of 142 FirstFirst ... 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 77 127 ... LastLast
Results 391 to 405 of 2122
  1. #391
    Long Island N.Y.
    My boats always run faster in a lite chop, like you see in salt water. Flat fresh water wont aerate the bottom like a lil chop does. jm 2cts
    ah secret the tuffs are aerated,
  2. #392
    Quote Originally Posted by davemvegas View Post
    map sensor.
    Quote Originally Posted by Dirk Pitt View Post
    do they control the air fuel mixture throughout the power band?
    Accurate system and yes it should be
  3. #393
    Long Island N.Y.
    Quote Originally Posted by RBT View Post
    May I suggest turbo Hondas?
    tell me about that
  4. #394
    Turbos are great for making up for low air density as they rev harder in thin air
  5. #395
    The exhaust manifold needed for a turbo would be labor intensive on an outboard I would think.
  6. #396
    Jan 2007
    Amityville/Lindenhurst
    What i have seen of dirks boat so far it is all gelcoat.
    it should also be noted that the boats come stock with a 30 gallon plastic tank.
    notching the hull of a 21 linder did NOTHING for top end, it gave better control.
    remember 2 local previously running/set up boats with no other modifications besides the notch reported this so its not opinion.
  7. #397
    Jul 2004
    Connecticut
    Quote Originally Posted by Jimboat View Post
    Haha...sorry for sounding like a professor. (I got carried away)!
    Great detailed explanation as always. Thanks for the post.
  8. Thanks Jimboat thanked for this post
  9. #398
    Jul 2004
    Connecticut
    The bottom line for THIS specific example....fresh water is going to be very slightly faster(< +0.5mph), assuming everything else is also the same (temperature of water, temp of air, atmospheric pressure, relative humidity, boat weight, fuel load, passenger payload, water conditions, etc.)
    With the exception of relative humidity (point taken earlier that Canada also has some) it looks like all other items are/can be pretty much neutralized. So perhaps it is more like a 300XS Tuff is 105mph on demand in Canada, 104mph in Strong Island and 103mph in Cuban waters.
    I'm sticking with 91.6mph top speed with the Evinrude 300 fully factory. If Dirk moves to a transom mounted water pickup I'd raise the number to 95 even but I suspect that would void the BRP warranty which aint worth it. Having an on demand 90mph SOB when conditions are right, that can also run real rough water like New York Harbor and that has 7 years of trouble free use ahead of it is plenty appealing.
  10. #399
    Long Island N.Y.
    Quote Originally Posted by RobF View Post
    im sorry to differ with the people that gave you these reports, in my particular case it was worth at least 3 to 5 mph, and the boat was somewhat eaiser to drive without the notch, between 80 and 85 mph maybe but when the 21 Linder variant enters the relm of north of 90mph its a totally different specices, these boats were never designed to go the speeds there doing today,although the design is a testement to George Linder, there was only a handful of 90 plus boats on the GSB, and even less between 95 and 100, and only 2 at 100 plus on the GSB,
    it appears all the 21 Tuffs are notched and airaided and they are ALL VERY FAST so he must be on to something, but we shall see soon enough wont we? yes Im going to initinally rig it with the BPR, to TRY and prove that we can go fast with other motor manufacter options, but I also have a 300x coming to try and break the Canadian 106 mark,maybe maybe not we shall see that soon enough too, you and i have discussed the 30 gal tank, and are in agreement that its ridiculous, but he did it for a reason, there on a lake and fuel capacity is a non issue, therefore giving him the opportunity to save weight,and money, but on the other hand in his effort to reduce construction costs he used plywood on the bottom and sides of the seats, which is a penny foolish decision...and that statement is a fact, which was reafirmed by my inside sources, both manufacting cost reductions are past on not as a savings to the customer but a profit to the manufacter....
  11. #400
    If that's the case I wonder what my Intimidator would do with a notch
    21 Intimidator 300x Sold
    http://www.youtube.com/watch?v=KBoYUJ58sLE
    1/2 21 Skater 300x Sold
    http://www.youtube.com/watch?v=tKNFL8b6kWo
    30 Activator 850 HP Sold
    https://youtu.be/NZgOTNGKzqg
    30 Concept Twin 300Rs
  12. Likes Brabender liked this post
  13. #401
    May 2001
    great south bay
  14. Likes AZMIDLYF liked this post
  15. #402
    East Wallyworld Vt
    firstly, charleyN. There is a big difference between vacuum bagging and infusion.
    If you go back and read my original comment you will find someone posted that infusion did not need a bag, it is them you should direct your post to, I was only commenting to that, I have been doing composites for 44 years, I do have a little understanding. Some of my work is silicone B molds, far beyond the regular bag. I have worked with pre-preg but it is not small shop friendly.
    Regards,
    Charlie North
    If it ain't broke, modify it.
    87 Glastron CVX20 Hull
  16. #403
    Long Island N.Y.
    Quote Originally Posted by Trimmed Out15 View Post
    thats why Tuff is doing it, if there was no advantage, he wouldnt add another operation to the manufactering process, its time consuming and costly, no manufactorer would add an operation if didnt yeild results, when the Red indimiadator was hatched, we all had full bottoms, sometime after Herb was burning up the bay, the idea for us was born, joey ECM came up with that idea,and we had many lunch meeting with Linder and Lurhs over the concept, Superboat Bob did the first couple, if I remember correctly Venomus traveled from NJ to have one done By Superboat Bob on his Challenger, but again heavy boat, and couldnt produce the north of 90 speeds,which the notch benifited,but again if my memory serves me right he was elated with the outcome, but he can comment on that, The indimadater is fast becauce herb applied the time tested concept, reduce the weight and you go faster, saying that try it who knows you may find more speed, I beleive every Superboat Challenger, Tuff is slightly different, weight, and bottoms, we were blue printing the bottoms years ago for that very reason...
  17. #404
    May 2010
    Baldwin ny
    I owned an original 82 shadow it had a notch I believe all the Linder Lurhs shadow boats did
    my under standing is they did that to add set back with out adding set back to the transom
    the tuff's on the other hand are adding notch and a lot of set back..... Somewhere between 18" and 22"
    the smaller tank is to move the CG back, not necessarily to save money I think
    77 challenger 200 yami
    82 shadow 3.6 gt sold
    http://m.youtube.com/watch?feature=g...&v=09QazIq2FgY
  18. #405
    Feb 2005
    Muskoka Canada
    The 106 boat runs 8" setback
    2023 TUFF 25
  1. Any Jet boat shops long Island NY??
    By Jo Jos Fountain in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 05-19-2014, 09:01 PM
  2. long island boat events
    By mercracer2.5 in forum Upcoming Events, Races, and Gatherings
    Last Post: 07-29-2011, 02:39 PM
  3. Long Island Boat Accident
    By lightspeed in forum General Boating Discussion
    Last Post: 10-09-2009, 02:56 PM
  4. need help with boat LONG ISLAND???????????????
    By 21eagle in forum General Boating Discussion
    Last Post: 05-18-2009, 02:03 PM
  5. any boat appraisers on long island?
    By wbones9 in forum The Scream And Fly Lounge
    Last Post: 07-16-2008, 04:22 PM
