Page 18 of 23 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 LastLast
Results 256 to 270 of 332
  1. #256
    Sep 2021
    Grand Rivers, KY
    Quote Originally Posted by skewby View Post
    FBM what are you doing? You doing your best to outrun that yellow boat on watts bar running a lil motor
    Pretty sure we did, with an even lil'er mota
  2. #257
    Sep 2021
    Grand Rivers, KY
    FBM you need to hang the little fella on a scale and get a true weight. Not sure what Merc has placed on the tag but the big 300 R weighs 561lbs
    Will do, we are going to hang it on a 2 seater XB21 just to see how it does on a tournament rigged boat so I will throw it on the scales at that time.
    I weighed a 250R with Darris back in 2018 and it was 560lbs, oddly enough the R cowl was 34lbs and the Pro XS cowl was 27lbs. I cant imagine the R mohawk weighs 7lbs...
  3. Thanks John S thanked for this post
    Likes Greg G liked this post
  4. #258
    Lake Coochiching, Ontario
    90 plus with the 200R on the 21 Allison is impressive. For comparison, the 20 Tuff went 86 with a 225 Merc 4 stroke, and 81 with a flashed to 231 Yamaha 150
    Overall length is similar: Tuff 21'10" Allison 21'2" (19'9" centerline)
    The Tuff is narrow at 82" vs the Allison at 93"
    The 200R results interest me more than the 450R, but I am curious about the differences between FBM's 450R 21 Allison and River Rocket's experience.
  5. #259
    Dec 2019
    Spring Lake MI
    That 225 on the 20 had a normal lower though so they couldn't raise it up. I bet a 25 would go 90 with a 200r, it will go 110+ with a 300r and little test time. I bet I could go 90 with a 200r on my 24, I would try it if it didn't have power on it haha.
    TJ @ Baker Engineering
    Tuff 24 300xs
    Tuff 16 90 Yammie
    3.75@199mph with LSX power!!!
  6. #260
    Jul 2004
    Connecticut
    I still don't understand why they did not just offer a 225 R V6. Not many folks bought the 250 R V8 so not like it would compete with that model.
  7. #261
    SOCAL, the land of 75* and sunny!
    Quote Originally Posted by FBM View Post
    Has Allison been doing anything different to their XBs to accommodate the new motors? Or are they capable of handling the extra weight without anything design/ structural to handle it? Or is it just different setups?
    Great reviews BTW, keep em coming.
  8. #262
    Maybe they did offer a 225 V6, but chose to call it a 200.
  9. Likes Speed Jr. liked this post
  10. #263
    Jul 2004
    Connecticut
    Quote Originally Posted by David View Post
    Not sure what you mean by that. The OEM has to stick with the +10% rule so the 200 can only make 220hp, where if they offered a 225 label it could make 247 which at least would equal the Promax and X back in the day.
  11. Likes 22R liked this post
  12. #264
    Bristol, WI
    People focus way to much on the sticker instead of the performance. Put that old 2.5L 225 PM on a loaded new XB21......See how it runs against a 3.4L 200R with a bigger prop spinning more blades.....The 2.5 is only relevant on lighter/smaller hulls. To get to top speeds with big props pushing real weight requires Torque. I'd much rather have the lower sticker number on the side of the motor to get cheaper insurance than have the big number and go slower.......
    Jr.
    Larry Gempp Jr.
  13. Thanks 22R thanked for this post
    Likes rjdubiel liked this post
  14. #265
    The 10% is voluntary. It’s possible that the 200 R, or for that matter the 300R go past that. BMW under rated some of their car engines.
  15. #266
    Sep 2021
    Grand Rivers, KY
    River Rockets explanation is spot on. The 450 is too heavy and the AMS mid makes it even more cumbersome. The amount of hours I have invested in the setup from June 2021 until Nov 2024 is surreal...I'd hate to even try to put a number to it. I have an easy 15,000+ miles behind the steering wheel. The Allison has so many curved and cupped surfaces that were designed with 500lbs in mind and when you add 220lbs to that it really changes things. I was able to make mine great in a straight line but it really took the Allison out of the boat. The AMS complicates things like setback because a hydraulic plate is a must but due to the 5" built into the AMS you are limited to a select few plates. I tried multiple setback lengths as well and each time it changed the entire dynamic of the boat. The power steering was a huge issue, the boat was undrivable so I had to come up with a workaround for that. Just so many little issues that add up to be a major issue.
    RR knew what he was getting into before hand. We installed a new 300R on his boat and so far its been 104.8 with room to grow.
    Quote Originally Posted by John S
    The XB21 series is built like a tank, Aluminum grid transom w/ studs instead of through bolts, aluminum glassed in anywhere something attaches (like the trolling motor). The boat handles the 300R with ease, and after 3.5 years of a 450R on the back of mine, there isnt a stress crack anywhere. I have put this boat through every condition imaginable. Our shop is located on Kentucky Lake and if the wind is blowing 30MPH, we are still liable to make a 50-75mile one way run for a tournament. Saying that, the weight of the 450 changes everything. It is just too much stern weight. The boat needs to be about 3' longer to float the weight better. It sits nose high at rest when compared to a 300R.
  16. Thanks David, John S, aj06bolt12r thanked for this post
    Likes David, 108, hellbents-10, HydroSkreamin liked this post
  17. #267
    @FBM Would you say the 300R is the ideal motor for the prosport? That has always been a dream cruiser for me. Kind of like an age appropriate next step up from my old XB-2002. I think it would make for a great cruiser/ beach hopper.
  18. Thanks 22R thanked for this post
  19. #268
    Sep 2021
    Grand Rivers, KY
    Quote Originally Posted by John S View Post
    IMO....Yes, the 300R pairs quite nicely with all models of the XB-21.
  20. Thanks John S thanked for this post
  21. #269
    You mentioned the boat could use another 3’. Darris (and a million others) has been teasing the 23’ Grandsport since I can remember. Is a 24’ Prosport possibly in the plans? I looked at their site the other day, kinda made me sad the old models are all gone. I understand, but, ya know.
  22. Likes 22R liked this post
  23. #270
    Sep 2021
    Grand Rivers, KY
    Darris is and has been actively working on a larger hull design for several years now. If it was done today they would still have to design the top deck layout, build molds, test, etc. I think we will eventually see a big GS, but its not going to be soon unfortunately.
  24. Thanks John S thanked for this post
  1. Caldwell Racing Technology Introduces Billet 2.5 Liter V6 Engine
    Last Post: 02-19-2024, 09:16 PM
  2. XS Series-Custom Built From Mercury Racing.
    By 4-strucked in forum General Boating Discussion
    Last Post: 05-09-2012, 10:23 AM
