Page 4 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 46 to 60 of 104
Thread: Shop heat??
  1. #46
    11 Post(s)
    ...83 degree's here today in Fla. With the 85% humidity, they say the "feels like" temperature was 89...and it felt like it. Remember those days Gary?
    Yep. I'm better w/the heat than the humidity.
    I remember one day while finishing my Sonic down there, up and down a ladder all day. Weighed myself in the morning and weighed myself at the end of the day. Ate two sandwiches, two bananas and drank a gallon of water and still lost 9 pounds!
    And I miss it every day :-)
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  2. #47
    11 Post(s)
    Quote Originally Posted by RobF View Post
    Got my tubes up and running. The silence is awesome and dont have to run any ceiling fans blowing the heat down any more. No way i would go back to forced air in a shop or garage environment
    That would have been preference but didn't have the time or the $$$.
    Maybe next yr.
    Another thing that pushed me this way is if I don't like it, the resale market is strong.
  3. #48
    Jan 2007
    Amityville/Lindenhurst
    when I go to quote I cant use the spacebar lol
    the install is just as easy as a forced hot air unit.
    Gas in, air intake, exhaust, thermostat wire, hang from chains.
    I would always advise someone working in a shop to have fresh air intake and not use shop air for combustion , less chance of blowing yourself up
    The downside of the tubes is if you have a very low ceiling you have to watch clearance or in that situation you install where the ceiling meets the wall on a 45.
    I think they sell box units you can mount in the corner ?
    open the door to move stuff and you dont instantly lose all your heat and no air blowing around all the time
  4. Thanks Instigator thanked for this post
  5. #49
    Jan 2007
  6. Thanks Instigator thanked for this post
    Likes olboatman, Forkin' Crazy liked this post
  7. #50
    Try hitting "Enter" (then backspace to where you left off if you need to)... mine has been doing the same thing on certain websites. Once I hit enter, the spacebar works for the rest of the post.
  8. #51
    Jan 2007
    lets see if this works
  9. #52
    11 Post(s)
    Finally got and installed my new heater yesterday.
    Only 24 hrs in but so far I really like it.
    The two stage feature is slick, as is the wireless (as in portable) remote/thermostat.
    Can adjust temp, set a run time timer, and fan only.
    When it gets to within 2* of target temp it drops to the low side. When it hits temp it shuts off completely. When it maintains temp, 90% of time it does it on low side.
    $750 for everything.
    First real test was this morning. 28* outside temp, 38* inside (from overnight which I love).
    Set the thermostat to 60* 50 mins later it was there.
    Not bad for a 24" electric heater in 32' x 57' x 13' shop.
    Was also playing w/my torpedo heater earlier for some base lines.
    Once at target temp, it shut off then refired every ten mins and ran for one.
    Simar ambient as yesterday/today w/elec.
    Bad on the torpedo (besides sucking fuel) is blows a puff of smoke every time it fires and noisy as hell.
    Also, it is 120k btu compared to 48k for new one so expecting it to run longer.
    So far so good.
  10. #53
ID:	362485Click image for larger version.
  11. #54
    amps?
  12. #55
    11 Post(s)
    63 on high side.
  13. #56
    Should do OK, will it keep up when the vortex shows?
  14. #57
    Nov 2001
    Lake Charles, Louisiana
    That's an impressive heater to warm your place that fast. I like the remote thermostat.
    93 STV Mod VP/MERC 2.5 200
    Proverbs 4:18-20
    -- John F. Kennedy 1962
  15. #58
    Jul 2004
    Connecticut
    What size breaker does that unit require? I was looking into tubes but now I think your route might be quick and easy.
  16. #59
    Jan 2007
    63 on high side.
    That would cost a fortune to run here
  17. #60
    11 Post(s)
    240 volt single phase
  1. 2.4 o over heat
    By SPECTRE racing in forum Technical Discussion
    Last Post: 07-05-2013, 04:47 AM
  2. 280 over heat
    By 280Ally Dave in forum Technical Discussion
    Last Post: 06-15-2013, 10:42 PM
  3. 3.0 L Won't heat up
    By shooter1 in forum Technical Discussion
    Last Post: 03-14-2013, 06:45 AM
  4. Mercury Tech: over heat ???
    By afr in forum Technical Discussion
    Last Post: 03-25-2009, 04:58 PM
  5. Need Heat
    By TB21 in forum Technical Discussion
    Last Post: 03-04-2005, 09:17 PM
