Page 51 of 54 FirstFirst ... 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 LastLast
Results 751 to 765 of 797
  1. #751
    Jul 2010
    Miami Springs, FL
    Quote Originally Posted by rtarford View Post
    Attachment 330931
    Made a big difference. I bought this boat when I was 25 , I'm pushing 50 now. I was never able to lift the bow with using the trim on the engine. The nose was very heavy and I had a hard time breaking loose from smooth water. Last time out that all changed, the plates aren't pushing the nose down anymore. It was hard to get between 90 & 100 with the tabs down. Now its easy but I have to learn how to fly it all over again.
    Those plates were acting as trim tabs pushing the bow down, and now with them flush with the tunnel like most HST's it breaks loose like it supposed to do. My boat came with those aluminum tabs, but they are longer and would stick out another 8 inches out the back. Never put them on, but still have them. If those are factory I think they were cut at some point.
    As for the davits my rear eyes came out years ago too, and I just glassed the holes up. I have eyes built into my setback plate for ropes. I was think for my davits to build two long bunks to go down the tunnels to pick it up and set it on my dock.
    1989 Hydrostream HST
    1989 Actioncraft Flatsmaster SE
    2006 Baycraft
  2. #752
    Belgium
    You are def. need to learn to fly that HST. Only 110mph...
    I'm kidding. Thats a real nice number! Wonder what your weighs. You should put it on the scales one time. I guess it's light...
    Is it a full interior? Your should take some action shots or movie. Not many get 110 out of their HST...
    http://www.geocities.com/fletcher_arrowbeau
    Fletcher 17F6
    Hydrostream HST 20F
  3. Likes David - WI liked this post
  4. #753
    No kidding. I'm 100hp short of that number; and I don't think mine's that heavy... but you can only do so much with 200hp.
  5. #754
    Dec 2009
    md
    Is it a full interior? Your should take some action shots or movie. Not many get 110 out of their HST...[/QUOTE]
    yes full interior,27 gal center tank & 4 gal fuel cell on the side
  6. #755
    Dec 2009
    md
Name:	BOAT AND MOTOR 016.jpg
ID:	331481Click image for larger version.
Name:	BOAT AND MOTOR 019.jpg
ID:	331482Click image for larger version.
Name:	BOAT AND MOTOR 023.jpg
ID:	331483Click image for larger version.
Name:	BOAT AND MOTOR 021.jpg
ID:	331484Click image for larger version.
Name:	BOAT AND MOTOR 022.jpg
    No Click image for larger version.
ID:	331485kidding. I'm 100hp short of that number; and I don't think mine's that heavy... but you can only do so much with 200hp.
    my last engine was a 175 Johnson BIG difference ,I couldn't hit 70
  7. #756
    Belgium
    Any new hst owners on the board?
    Fletcher 17F6
    Hydrostream HST 20F
  8. #757
    Quote Originally Posted by bigboy View Post
    Just the old HST guys, I guess.
    I cut out a lexan plate to make a sort of "skid planer" to get some more lift in the stern without adding a bunch of weight... but I don't know yet.
  9. #758
    upstate N.Y.
    bigboy. it's been a while, what's new?
    why ask me ?
  10. #759
    Belgium
    David, you made it so try it. You have a 200 right? What setup and speed?
    Nick: Lets say that the fact I haven't post updates in the resto thread doesn't mean I haven't made any progress.... More to come later!
    Fletcher 17F6
    Hydrostream HST 20F
  11. #760
    It was basically a stock carb 200 2.4L motor with CLE, I think it was back 8" when I got it... 88 mph. Motor is apart now, no compression on two holes... but I'll test the plate when I get time; and the cone on the lower unit. Boat is lighter now and will have more hp, so it should run in the 90's now I think.
  12. #761
    Belgium
    88mph is quite good for a 200 if you ask me! What prop?
    Fletcher 17F6
    Hydrostream HST 20F
  13. #762
    Jul 2010
    Miami Springs, FL
    Just the existing HST guys. New seatar pro steering going on mine now and the engine has all new electronics as well. Hopefully have it running by June again.
    2006 Baycraft
  14. #763
    Some big-ear chopper (28P Chopper II maybe?) that came with it. I've only had it in the water maybe 5 times in the 12 years I've had it. I have other props I would like to try on it, but I have to figure out this Hynautic steering and fix the motor first.
    It's actually reasonably light for an HST, weighed 1460# with anchor, 5 vests, fire extinguisher, ski pylon, stereo, etc... without fuel, oil, spare prop or driver. (Still has all the foam.) I'm figuring 1865# full of fuel with me in it.
  15. #764
    Nov 2005
    Plaisance, Québec, Canada
    Hi,
    I'm fairly new to HST's. I had mine for the past three years and have some weird issues.
    I will be back later today to explain and I'm sure we'll be abble to get it running great.
    Glastron GT 150 W OMC 140
    Glastron GT150 w OMC 235
    Hydrostream Vision with 2.0l 135
    Hydrostream HST w 3.0L 225
    I know two things that are infinite, the Universe and Human's Stupidity, although I am not sure about the first one.
  16. #765
    St Petersburg, Florida
    I also am new to HST(In the last year) Somehow ended up with 2 HST's. The one I'm currently running is a Black Bruiser jel sceme full interior with a
    3ltr 200 Evinrude/Johnson 20" Vindicator mid 14in setback. It's a blast to fly. I love it. It has the aluminum plates at the extentions as well. It also has extra lifting strakes on the outside sponsons my other one doesn't have. No aluminum plates on the extentions on the white one either. The center Stepped Pod/pad is the same on both.
    The other(white with red,grey,black, multi color sceme) I'm restoring so its lighter, stronger and hot rodding a Rude 3.4ltr w/16in mid for it. Still at least a month out on this one before I get her wet again.
    Tony
