Results 1,456 to 1,470 of 1571
Thread: Yamaha 130 V4 Project Build.
02-25-2016, 12:00 PM #1456
I talked to hydrotec and they werent interested. I thought the only way to do it and make it cost effective would be to make a bunch and maybe Hydrotec would buy some to resell. They had a titanium flywheel from someone else at one time and there just wasnt a big enough market.
21' Paramount
Mercury 300 Promax
02-27-2016, 03:55 PM #1457
02-27-2016, 05:10 PM #1458
olboatman liked this post
02-27-2016, 06:02 PM #1459
Chris is that a stock cowl cut out for the frame and what type of adhesive are you using? Thanks Gary
02-28-2016, 10:34 AM #1460
02-28-2016, 10:40 AM #1461
Rivers would be cool- start looking like an airplane!
02-28-2016, 10:56 AM #146213' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
02-28-2016, 10:01 PM #1463
Put the big wheel on today for only the second time ever and she is def down a little on power on the low end. Struggled to break the prop loose and then pulled real slow until about 4500rpm then pulled right to 95mph at 6750. Ran out of real estate but it was still pulling.
Stopped by to see Rick Junker this evening and have a little skeg work done and I showed him that prop. He thinks its leaving a LOT on the table. Its got a ton of cup all the way to the hub and is really really thick. Not what he thought would be a good top end prop at all. I left it with him and if he can get the skeg work done he is going loosen it up a bit for this coming weekends Suwanee run.
My skeg is showing what appears to be a very fine crack starting again at the same spot. Just dropped it off with Rich Junker and he is going to run the torque tab all the way up to the bullet and really make that thick. That part isnt even in the water and on Yamaha gearcases its very thin there. I know if I get another case it will just do the same thing. Been there 3 times now. I think adding this will work and if it does I will seek out a fresh case and add one to that. If not my only choice is going to be trying to adapt a sporty and that will change a lot. It will be like starting all over with setup.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
02-28-2016, 10:31 PM #1464
02-29-2016, 02:32 AM #1465
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,320
- 1055
- 411
- 4702
- 2169
- 9 Post(s)
02-29-2016, 08:59 AM #1466
02-29-2016, 11:38 AM #1467
Junior Member
- Jan 2016
- Brasil
- 15
- 14
Yamaha v4
Hey Guys
Here is the first test on water:
Prop pitch 28x14
6900 RPM
Speed:???
Still need a lot of improvements, I`m having trouble in reacceleration, it feels like need more fuel. To plane the boat I need to kick very fast the accelerator to avoid the engine stops.
Also I have doubts about my ignition timing, I`m using -2 in full retarded and 26 in full advanced.
Best RegardLast edited by rodrigokrug; 02-29-2016 at 11:43 AM.
02-29-2016, 12:18 PM #1468
Love that sound. Get her broke in and lets hear it at 7,000 rpm.
21' Paramount
Mercury 300 Promax
02-29-2016, 10:21 PM #1469
Thanks for the updates. Always read them. For all the work you've done you probably could have had a speed master adapted to run on that mid. Even an old school Super Speedmaster was run under 190HP inline 6's and the first T3's.
Im mostly play with and research the old stuff. It surprises me that more people don't use a speedmaster on there performance boats. I would think your boat would love one.L6fan57-88
02-29-2016, 10:27 PM #1470
No reverse would suck on a pleasure boat. Sure I could have done it for less butt then there are the insurance claims LOL.
A speedy prob wouldnt be any faster. I only have 3/4 of my skeg in the water so a smaller bullet wouldnt help me.
I do have some ideas about building a billet rudder that would attach to the current lower unit.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
