Page 95 of 105 FirstFirst ... 45 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 LastLast
Results 1,411 to 1,425 of 1571
  1. #1411
    Aug 2004
    Venice, Florida
    So.....
    Good news and bad news.
    The good news is I picked up 200 rpm cutting the tuner! Lost a little below maybe 4500 where is feels a little "soft" now but no problem breaking the prop loose and jumping up on plane. Big gain up top though. 2.5mph which in theory puts me over 100mph.
    And now the bad news. My lightened flywheel came apart at about 5500-6000rpm and did some damage. The ring gear seperatated and fell down destroying the stator, timing advance, ate some of the starter, etc. What worries me is there are metal shavings all over. When it went the motor immediately shut off but Im worried I ingested some metal. It was raining when I got home so I parked and took nap
    Ill take a closer look tomorrow.
    First time being towed. Luckily there was another ramp close by.
    Big thanks to Mike M. (DagoDiver) for the tow and going to get my trailer.
    21' Paramount
    Mercury 300 Promax
  2. #1412
    Sep 2002
    Parry Sound, On
    Ya...that's a bad day...be glad that it didn't hit you in the head! It's really not that far away lol.
    '08 SRV
    Yamaha 3.1 Phase III
  3. #1413
    East Wallyworld Vt
    Be glad that ring is round and just the center failed.
    The mechanicals can be fixed.
    Regards,
    Charlie North
    If it ain't broke, modify it.
    87 Glastron CVX20 Hull
  4. #1414
    Aug 2004
    Venice, Florida
    Yup its just parts. Im going to pull the intake and see if there's any metal shavings present.
    She really woke up over about 4500rpm. I was all smiles for about 10 minutes.
    21' Paramount
    Mercury 300 Promax
  5. #1415
    Aug 2004
    Venice, Florida
    This is what I get when I plug in the new numbers with my top end prop.
    Can I call it a 100mph boat or do I have to actually do it?
    21' Paramount
    Mercury 300 Promax
  6. #1416
    ft pierce fl
    you have to do it to make it count. and that you already know. but i agree it looks good on paper.
  7. #1417
    Aug 2004
    Venice, Florida
    Quote Originally Posted by davemvegas View Post
    I looks safer on paper :-)
    21' Paramount
    Mercury 300 Promax
  8. #1418
    East Wallyworld Vt
    The boat and motor do not know the difference between 95 and 100. The boat does not know of any magical limit. Only you know what the boat is telling you when it is up at speed, it is easy for all of us to just say go do it. To me if the boat felt good from 90 to 95, I expect it should feel fine through the next step up, unless you can sense that may not be the case. If it might not be the case then you should not go there.
    Remember back in 1999 all the stupid talk of what was going to happen, nothing did. So is 99.9 any different?
    Regards,
    Charlie North
  9. #1419
    ft pierce fl
    Quote Originally Posted by Mr. Demeanor View Post
    try for 100 at the Suwanee in nov. water is not that cold when you go in with a adrenalin rush.
  10. Likes baja200merk liked this post
  11. #1420
    Aug 2004
    Venice, Florida
    I'll put the big prop on next month at the Suwanee run if conditions look right.
    21' Paramount
    Mercury 300 Promax
  12. #1421
    Aug 2004
    Venice, Florida
    Got it all apart yesterday after quite a battle with the flywheel. Took a puller, bottle of map gas, penetrating oil, and an air chisel to get the flywheel off.
    When I pulled the flywheel, 3 magnets stayed on the stator. I kind of wonder if one had come loose and sent the flywheel on a path to self destruct.
    The stator and trigger ae destroyed. There is a good grind mark on the top bearing housing but it should be fine. I dont think you can remove that cap with splitting the cases.
    Ill pull the intake and inspect for any fragments but I think I am okay. I swabbed the carb throats with cotton swabs and found no metal.
    21' Paramount
    Mercury 300 Promax
  13. #1422
    You can remove the cap. Ive swapped omc to yamaha a few times just by loosening the top CC bolts.
    If you need any yamaha ignition stuff I've got an old timer around the corner with a few containers full of it.
  14. #1423
    Aug 2004
    Venice, Florida
    Thanks buddy. Ill let you know.
    I found all the large metal parts I was worried about and even though there was shaving everywhere I checked the intake, reeds, etc and cant find a speck. Scoped the cylinders and they look fine so I think I lucked out in that respect. I did see Im still running a little rich even with the cold weather and coming down in jet size so theres a little more power there keeping the jetting safe.
    21' Paramount
    Mercury 300 Promax
  15. Likes baja200merk liked this post
  16. #1424
    Aug 2004
    Venice, Florida
    Found a PRISTINE fresh water flywheel and stator looks like brand new Im buying.
    You know the flywheel new now is like $1000, stator is $700, and trigger is $350.....WTF???????????????????
    21' Paramount
    Mercury 300 Promax
  17. #1425
    Price of parts is going crazy for all the motors.....Good thing you didn't hurt anything else.....
