Page 3 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 31 to 45 of 88
  1. #31
    Man those domes have a funny looking burn. Like the roofs are really flat.
  2. #32
    May 2002
    Lake Havasu City AZ
    Quote Originally Posted by Freddie Webb View Post
    Attachment 330875I forgot who ask for this picture but here it is. And before comments are made that is klotz benol on the cylinder wall. Those who have run it before know what a mess it makes if you don't flush with conventional oil before storing.
    That was me who asked. Thank you.
    Are you taking it completely apart? If so would love to see in side exhaust chest.
  3. #33
    Hi Freddie
    does the have the allen head bolts on the side of the crankcase that must be holding something just beside the rod slot?
    Racer tells me they are quite trick on the inside.
  4. #34
    Alabama
    You are welcome and no sir not taking it all the way apart. Just cleaning things up.
  5. #35
    Alabama
    This is an older engine and it has regular hex head bolts. I think the efi motor has Allen bolts
  6. #36
    Alabama
    Kevin what makes you say that?
  7. #37
    Alabama
    I'm assuming Kevin that you are referring to the roof angle of the transfer ports?
  8. #38
    Hi Freddie
    So whats inside there?
    Some kind of contoured block to feed from rod slot to the boost port( the middle transfer port)?
  9. #39
    Alabama
    I'm not sure I understand your question powerabout.
  10. #40
    Apr 2007
    wow makes curious what it is i have now my model and serial number does not even come up on the list
    7 to 3pm 5 days a week
    Custom Fiberglass and Paint
    In Business since 1984
    for sale
  11. #41
    mine has these bolts, I wonder what they are for?
  12. #42
    Alabama
    Oh, yeah I know what that is. It is a brilliant idea they had for resleeving. What you are looking at is a plug but there is a different bolt that goes in there when you are resleeving.
  13. #43
    to hold the sleeve in place?
  14. #44
    Align the sleeve?
  15. #45
    at the track repair, have the barby then put the block on and change the sleeves that are pre finished and they are located perfectly to allow for the alcohol content of the crew?
    sounds very Australian
  16. Likes AZMIDLYF liked this post
  1. Formula (Thunderbird) Formula One
    By dba900 in forum General Boating Discussion
    Last Post: 10-06-2018, 08:02 PM
  2. Mercury Tech: Carb Floats for Mercury 2.4 WH Series Carb
    By DirtySouthMikey in forum Technical Discussion
    Last Post: 10-24-2012, 03:21 PM
  3. Replies: 2
    Last Post: 02-19-2012, 08:59 AM
