Page 109 of 142 FirstFirst ... 9 59 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 ... LastLast
Results 1,621 to 1,635 of 2122
  1. #1621
    ft pierce fl
    Quote Originally Posted by Dirk Pitt View Post
    just recieved a 33" Bblades going testing today maybe Ill run into P22
    well did the bblades run? or did it sling a blade?
  2. #1622
    Long Island N.Y.
    The new tournament Rams are awesome. They are square instead of round and are much better built everythjng from the ram to the brackets is much stronger.
    I mi have a front mount Latham that works great but costs more then the complete pro setup
    and everyone calls it something different part Number?
    21 Tuff, Mercury 300X
  3. #1623
    Long Island N.Y.
    Quote Originally Posted by davemvegas View Post
    no not yet but Ive only made a couple of passes with them I used the 32 on the KOC run and it was ok
  4. #1624
    Prince George B.C. Canada
    I never consider that but Im going to try it, if it works the chessebergers are on me
    Your on! haha i can tell ya this. i dont know of any Allison side steers that dont have some form of counter weight for running solo. The GS is only about 5 inches shorter and a little narrower pad vees,weigh about the same at 950 lbs. On mine and most Grandsports guys use around 40-50lbs counter weight not including battery thats in the rear port compartment. Im 220lbs ishhhh and 45 worked perfect on my setup. i had 2 25lb lead shot bags in the gunnel laying on the floor just behind the front passenger seat. When i have a passenger I need to move one over to the starboard {R} side to get perfect balance so I dont have to steer the crap out of her to fly straight. I 25 lb dumbbell and 2 10 lb ones for 45 lbs total bet does the trick solo. If you start bumping the other way take a 10 lb out and put it in the centre bilge or middle seat and see if you can get away with 35 ect... you may even need more that 45?? buy moving my seat base side ways and having the option of sliding my weight right or left enabled me to loose 20 lbs off offset. Its a little strange at first steering from the side but i love it now. Dont even notice it but with passangers I can just adjust my seat to always find the right ballance point for running high on the pad so Im not fighting flopping over. Ill bet you find her more balanced with one passenger?
  5. #1625
    Long Island N.Y.
    Quote Originally Posted by whipper View Post
    now that were talking about it I recall RBT telling me the 106 Tuff runs two small batteries on the port side hmmm interesting I went to a dive shop and bought these bags they use for divers there shot lead in fabric bags they work great 5lbs each,plus Mickey large let me borrow bags that he had which I have to return
    it really sucks fighting the wheel, maybe I was pointing the finger at the wrong issue
    theres no way Mcknight was comfortable with the way that boat was set up, I dont care what motor was on that boat
  6. #1626
    Nov 2002
    Long Island NY
    I don't know if I agree with that. I think when/if u change ur steering it's gonna make a big difference for drivability for great lengths
    SOB RACING!!! Because Golf, Basketball, Football and Baseball takes only one BALL!
  7. #1627
    Long Island N.Y.
    Quote Originally Posted by progression22 View Post
    joe hoestly I hope your right, I kinda think the weight thing is a band aid fix, the think should fly straight and true its a Tuff Boat
  8. Likes AZMIDLYF liked this post
  9. #1628
    Nov 2002
    Long Island NY
    There is absolutely no reason to add weight to a performance boat. u can move around what's in the boat already to achieve the same goal. So in my opinion who ever is telling u to add weight do not take any more advice from them... just my 2 cents
  10. Likes AZMIDLYF liked this post
  11. #1629
    Feb 2003
    Rochester, NY
    Remember, there is a torque reaction from your motor / prop that transfers back through the hull and the steering wheel. In fact the more pitch / rake you run in a given prop, the worse it gets. Proper hydraulic steering will allow you to compensate for that torque reaction and not have to hold the wheel to keep the boat on course. Proper weight distribution will allow the boat to stay level (port to starboard) as you make minor steering corrections to compensate for chine walking, waves, wind, etc.
    1992 Progression 22
    Mercury Racing 250R
  12. #1630
    Quote Originally Posted by TooStroked View Post
    Thats what i said? Is it not? If you have the weight inside the boat to ballance it out then you should not need to do anything to ballance the hull to compensate for driver weight and prop torque is the best case scenario. The lighter the hull to more the sensitivity to weight and ballance. Yes or no?? If you are running a single battery on the port side on a very light hull and the driver is over 150lbs and the hull isn't a center steer the chances the hull isn't balanced as good as it can be is all Im saying and yes it will make a big difference if the hull IS balanced weather buy your own means or buy using what you have to work with as equipment. Its actually a very common practice with very high performance hulls. But what do I know. Just trying to help. Also not saying that solid mounts arnt better and laythem type steering put it all togeather and my wife could drop the hammer down on her. Well maybe not....haha
  13. #1631
    Long Island N.Y.
    i respect your opinion and i already went out bought the dive weight bags I try them tomorrow, like no one ever put weight in a progression ?
  14. #1632
    Nov 2002
    Long Island NY
    None of the proven ones.
  15. #1633
    Long Island N.Y.
    I guess thats you of course, how silly of me
  16. #1634
    Nov 2002
    Long Island NY
    To be completely honest, I don't even consider the yellow one proven yet. Yeah yeah everyone has stories about the boat...... that's what they all are.. stories!!!!!
  17. #1635
    Sep 2010
    long island,ny
    When you find the right style prop with the right setback you will not need any added weight in the boat.
    You just haven't tried enough combo's yet. Keep up the good work !
    1990 22' Activator Yami HPDI 300-sold-86.4
    1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
    1982 21' Superboat 300merc-87
    1990 22' Activator yami OX66 Vmax 250-84.2
    1982 30' Scarab-twin 200 Merc-sold
    1979 21' Challenger 300 Evenrude-sold
    1979 21' Superboat 200 Merc-sold-72
  1. Any Jet boat shops long Island NY??
    By Jo Jos Fountain in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 05-19-2014, 09:01 PM
  2. long island boat events
    By mercracer2.5 in forum Upcoming Events, Races, and Gatherings
    Last Post: 07-29-2011, 02:39 PM
  3. Long Island Boat Accident
    By lightspeed in forum General Boating Discussion
    Last Post: 10-09-2009, 02:56 PM
  4. need help with boat LONG ISLAND???????????????
    By 21eagle in forum General Boating Discussion
    Last Post: 05-18-2009, 02:03 PM
  5. any boat appraisers on long island?
    By wbones9 in forum The Scream And Fly Lounge
    Last Post: 07-16-2008, 04:22 PM
