Page 66 of 142 FirstFirst ... 16 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 116 ... LastLast
Results 976 to 990 of 2122
  1. #976
    I've herd guys that have asked their dealer if a nosecone would void warranty and the dealer told them no. How true that is I don't know.
    If you do a cone you can run the water through the factory pickups so you don't need external water tubes.
  2. #977
    Dirk, you said you were getting a 300x in a previous post. Did that happen and could that lwr be an easy swap to try?
  3. #978
    Jul 2004
    Connecticut
    I've herd guys that have asked their dealer if a nosecone would void warranty and the dealer told them no. How true that is I don't know. If you do a cone you can run the water through the factory pickups so you don't need external water tubes.
    Interesting, but I personally would not want to test that when/if push comes to shove with BRP's warranty folks. Easiest next step is to add "BajaBlockerBags" and raise the motor up to the next highest bolt. 5 minutes to do and 5mph gained. 94mph with a full tank of gas and the rear seat installed is my assumption with the 18" existing setback left intact.
  4. Likes baja200merk liked this post
  5. #979
    Jul 2015
    Canada
    Quote Originally Posted by whipper View Post
    That doesnt look to bad at all. Other than the covering on the upper holes. haha You could plug those up nice and {Smooth} with some danaglas then paint white and look factory..
    The sides shape its self looks good I think! It looks like it would carry well.
    Yea and funny thing, if you use viscous LaPage marine epoxy, it looks terrible on the outside, drips down on the inside, then solidifies, breaks off and goes into your water pump in the middle of the lake. Use PC7...
  6. Likes baja200merk liked this post
  7. #980
    May 2001
    great south bay
    How stout is the prop shaft? Once you get some height the next issue is going to be keeping the propshaft in the case, Those herring props are not cheap! and I can guarantee dont float!!!
  8. #981
    We are a BRP dealer and it would void any gear case related warranty which may also include an overheat issue on the powerhead.
  9. Thanks baja200merk thanked for this post
  10. #982
    May 2001
    great south bay
    What is the required break in procedure? If there is none would they frown on max RPM within the first few minutes of running?
  11. #983
    Prince George B.C. Canada
    That was a pic of a guy I helped do the mods it wasn't finished when he took the pic. Mine looked factory and I filled in the side water pickups and shot the whole motor with brp white. I did it like 4 yrs ago so i can't find any good pics. Here's mine from a few boats ago
    i gathered that about the look. Just had to rib ya on that that pic. haha. Ya your motor looks SICK!! Love to hang that on my Allison!!
  12. #984
    Long Island N.Y.
    [QUOTE=AZMI
    Im waiting for Noli to make up his mind
    21 Tuff, Mercury 300X
  13. #985
    Long Island N.Y.
    test yesterday
    went up about 1 1/2" the temp went up, went down 1/2" temp good but experienced blow out.......
  14. #986
    Jul 2004
    Connecticut
    Quote Originally Posted by Dirk Pitt View Post
    test yesterday. went up about 1 1/2" the temp went up, went down 1/2" temp good but experienced blow out.......
    Did you plug the side water inlets?
  15. #987
    Long Island N.Y.
    no because Im thick headed, I need to see what happens with every change I make, this new territory...
  16. Likes whipper liked this post
  17. #988
    Thats the best way not like me I make 2 or 3 changes make a gain and sit there and try to figure out what change made the biggest difference, then forget about it. Then say scew it i got a gain all is good. haha Now if I did that and lost rpm It wouldn't be as cool!!
  18. #989
    Jul 2004
    Connecticut
    So just to regroup...........
    You are still running 18" of setback. A couple of days ago with the motor lower or roughly dead even with the pad, you had no blow out at all and ran 90mph with no rear seat.
    Now, you raised the motor to 1" above the pad and experienced some blow out. What speed was this at ?
  19. #990
    Long Island N.Y.
    [QUOTE=Greg G;2789473]So just to regroup...........
    You are still running 18" of setback. A couple of days ago with the motor lower or roughly dead even with the pad, you had no blow out at all and ran 90mph. Now, you are 1" above the pad and experienced some blow out. What speed was this at?[/QUOTE
    It was in the low 80's which makes sense plus I tried a Evenrude prop, talk about bow lift, Im starting to think I need a cleaver
  1. Any Jet boat shops long Island NY??
    By Jo Jos Fountain in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 05-19-2014, 09:01 PM
  2. long island boat events
    By mercracer2.5 in forum Upcoming Events, Races, and Gatherings
    Last Post: 07-29-2011, 02:39 PM
  3. Long Island Boat Accident
    By lightspeed in forum General Boating Discussion
    Last Post: 10-09-2009, 02:56 PM
  4. need help with boat LONG ISLAND???????????????
    By 21eagle in forum General Boating Discussion
    Last Post: 05-18-2009, 02:03 PM
  5. any boat appraisers on long island?
    By wbones9 in forum The Scream And Fly Lounge
    Last Post: 07-16-2008, 04:22 PM
