Results 976 to 990 of 2122
Thread: Tuff Boat on Long Island
09-11-2015, 09:58 AM #976
09-11-2015, 10:19 AM #977
Dirk, you said you were getting a 300x in a previous post. Did that happen and could that lwr be an easy swap to try?
09-11-2015, 10:20 AM #978
Supporting Member
- Jul 2004
- Connecticut
- 6,250
- 516
- 201
- 1065
- 1115
Interesting, but I personally would not want to test that when/if push comes to shove with BRP's warranty folks. Easiest next step is to add "BajaBlockerBags" and raise the motor up to the next highest bolt. 5 minutes to do and 5mph gained. 94mph with a full tank of gas and the rear seat installed is my assumption with the 18" existing setback left intact.
baja200merk liked this post
09-11-2015, 11:07 AM #979
Junior Member
- Jul 2015
- Canada
- 9
09-11-2015, 11:59 AM #980
How stout is the prop shaft? Once you get some height the next issue is going to be keeping the propshaft in the case, Those herring props are not cheap! and I can guarantee dont float!!!
09-11-2015, 12:10 PM #981
We are a BRP dealer and it would void any gear case related warranty which may also include an overheat issue on the powerhead.
baja200merk thanked for this post
09-11-2015, 02:58 PM #982
09-11-2015, 03:05 PM #983
09-11-2015, 07:44 PM #984
[QUOTE=AZMI
Im waiting for Noli to make up his mind21 Tuff, Mercury 300X
09-12-2015, 06:04 AM #985
test yesterday
went up about 1 1/2" the temp went up, went down 1/2" temp good but experienced blow out.......21 Tuff, Mercury 300X
09-12-2015, 06:08 AM #986
Supporting Member
- Jul 2004
- Connecticut
- 6,250
- 516
- 201
- 1065
- 1115
09-12-2015, 06:10 AM #987
whipper liked this post
09-12-2015, 06:13 AM #988
Thats the best way not like me I make 2 or 3 changes make a gain and sit there and try to figure out what change made the biggest difference, then forget about it. Then say scew it i got a gain all is good. haha Now if I did that and lost rpm It wouldn't be as cool!!
09-12-2015, 06:15 AM #989
Supporting Member
- Jul 2004
- Connecticut
- 6,250
- 516
- 201
- 1065
- 1115
So just to regroup...........
You are still running 18" of setback. A couple of days ago with the motor lower or roughly dead even with the pad, you had no blow out at all and ran 90mph with no rear seat.
Now, you raised the motor to 1" above the pad and experienced some blow out. What speed was this at ?
09-12-2015, 06:21 AM #990
[QUOTE=Greg G;2789473]So just to regroup...........
You are still running 18" of setback. A couple of days ago with the motor lower or roughly dead even with the pad, you had no blow out at all and ran 90mph. Now, you are 1" above the pad and experienced some blow out. What speed was this at?[/QUOTE
It was in the low 80's which makes sense plus I tried a Evenrude prop, talk about bow lift, Im starting to think I need a cleaver21 Tuff, Mercury 300X
Any Jet boat shops long Island NY??
By Jo Jos Fountain in forum Jet Boats, V-Drives and Stern DrivesReplies: 2Last Post: 05-19-2014, 09:01 PM -
long island boat events
By mercracer2.5 in forum Upcoming Events, Races, and GatheringsReplies: 13Last Post: 07-29-2011, 02:39 PM -
Long Island Boat Accident
By lightspeed in forum General Boating DiscussionReplies: 21Last Post: 10-09-2009, 02:56 PM -
need help with boat LONG ISLAND???????????????
By 21eagle in forum General Boating DiscussionReplies: 12Last Post: 05-18-2009, 02:03 PM -
any boat appraisers on long island?
By wbones9 in forum The Scream And Fly LoungeReplies: 1Last Post: 07-16-2008, 04:22 PM
