Results 376 to 390 of 2122
Thread: Tuff Boat on Long Island
08-09-2015, 05:37 PM #376
Screaming And Flying!
- 15,029
- 402
- 1432
- 5953
- 11573
Very good explanation, just like I was back in college.....
Jimboat thanked for this post
08-09-2015, 05:41 PM #377
08-09-2015, 05:47 PM #378/Jimboat
AeroMarine Research
NEW 'Secrets of Tunnel Boat Design - SE' book (complete revision)
'Vee Hull - Vee Pad design'
'Tunnel Boat Design' & 'Vee Boat Design' Performance software Ver 8 with Porpoise Analysis, Dynamic Stability, Steps Analysis, Vee-Pad Analysis & Economy Analysis
Free Technical Articles
YouTube videos
08-09-2015, 05:50 PM #379
but I did find this which looks like it confirms your observation
R = C x ((rho x V^2)/2) x A
where:
R = resistance in pounds
C = coefficient of skin friction
rho = density of water in slugs per cubic foot
V = velocity in feet/sec
A = wetted area in sq. ft.
Using this as a basis for some "hoodoo math", one can test to see whether a hull will have more or less frictional drag in fresh water than in salt. To keep things reasonable here, we will assume that the coefficient of skin friction will be constant at 0.995, and velocity is constant at 33.77 ft/sec (20 knots).
In salt water,
rho = 1.99
A = 100
therefore R = 0.995 x ((1.99 x 33.77^2)/2) x 100 = 112903.7
In fresh water, which is 2.34% less dense than salt,
rho = 1.94
A = 102.4 (wetted surface increases due to more of the hull being submerged in the less-dense fluid)
therefore R = 0.995 x ((1.94 x 33.77^2)/2) x 102.4 = 112708.5
08-09-2015, 06:04 PM #380
All I know is in the real world my super with the 250 on it was 4 mph slower in lake george than the barnegat bay JMO
08-09-2015, 06:34 PM #381
08-09-2015, 07:02 PM #382
The northerners that run in salt at sea level should not compare the northern high altitude fresh water lakes. Even though the newer engines account and adjust for barometric pressure which helps minimize power loss compared to a carb motor there is still a loss
08-09-2015, 07:17 PM #383
Jimboat liked this post
08-09-2015, 07:29 PM #384
- 15,029
- 402
- 1432
- 5953
- 11573
My boats always run faster in a lite chop, like you see in salt water. Flat fresh water wont aerate the bottom like a lil chop does. jm 2cts
08-09-2015, 07:33 PM #385
Wow this thread has really taken off, what's gonna happen when winter comes around.
firstly, charleyN. There is a big difference between vacuum bagging and infusion. While I get that both have a bag, the process is very different as are the results and the lamination schedule has to be designed accordingly. All tuff's were bagged, the latest have been infused. Since the 106.4 boat. I have been infusing since 2007. I wouldn't vacuum bag ever again.
We have humidity here, those Great Lakes have a huge effect on us. Our actual altitude is 730 feet above sea level, I suspect this has more effect than salt does. But if I were a betting man, I'd say that it would go faster in gsb then here. Like I said before tuff #1 has run over 100 mph since inception. Over a decade ago and it was the heaviest of them all. The basic lamination of all tuff is the same, sometimes advanced composites are substituted. The 106 boat is standard layup schedule on,y substituting glass for Kevlar. Same mass, same orientation.
And for speeds, 225 ficht 87 mph. Old boat, over a decade this way, 300 Yamaha 93 mph. Turd of a motor compared to a merc. These are the old boats, most of the owners don't care about putting up a number. Fact is they are fast.2023 TUFF 25
Greg G thanked for this post
08-09-2015, 07:35 PM #386
08-09-2015, 07:37 PM #387
08-09-2015, 07:40 PM #388
08-09-2015, 07:46 PM #389
May I suggest turbo Hondas?
2023 TUFF 25
08-09-2015, 07:46 PM #390
- Jun 2007
- Singapore/Melbourne/Italy
- 9,317
- 1054
- 410
- 4697
- 2169
- 9 Post(s)
map sensor checks the load from rpm and moves the VE table in the pack constantly
Engine really needs a humidity sensor to cover all bases then it has air density covered
Engines can use the MAP sensor just when you turn it on before cranking to get an air density
( I am talking aftermarket here as I am no expert on E-tecs)
Any Jet boat shops long Island NY??
By Jo Jos Fountain in forum Jet Boats, V-Drives and Stern DrivesReplies: 2Last Post: 05-19-2014, 09:01 PM -
long island boat events
By mercracer2.5 in forum Upcoming Events, Races, and GatheringsReplies: 13Last Post: 07-29-2011, 02:39 PM -
Long Island Boat Accident
By lightspeed in forum General Boating DiscussionReplies: 21Last Post: 10-09-2009, 02:56 PM -
need help with boat LONG ISLAND???????????????
By 21eagle in forum General Boating DiscussionReplies: 12Last Post: 05-18-2009, 02:03 PM -
any boat appraisers on long island?
By wbones9 in forum The Scream And Fly LoungeReplies: 1Last Post: 07-16-2008, 04:22 PM
