Page 9 of 142 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 59 109 ... LastLast
Results 121 to 135 of 2122
  1. #121
    Massapequa NY
    Just saw a 27 Kryptonite on offshore only with twin 300x. Im in love.
  2. #122
    Long Island N.Y.
    Quote Originally Posted by mragu View Post
    This one photo by Dirk Pitt
  3. #123
    Long Island N.Y.
    hey this is about Tuff boats
  4. #124
    Sep 2010
    long island,ny
    Quote Originally Posted by Dirk Pitt View Post
    den mac is a dealer cool Ill look into it thanks for the heads up, have you tried one?
    Yes, should work good...they run stiff. .....oh but you better be able run high (above pad) engine height with it.
    1990 22' Activator Yami HPDI 300-sold-86.4
    1976 21' Challenger 2002 3.1 Yami 250 Vmax phase lll 89.7-sold
    1982 21' Superboat 300merc-87
    1990 22' Activator yami OX66 Vmax 250-84.2
    1982 30' Scarab-twin 200 Merc-sold
    1979 21' Challenger 300 Evenrude-sold
    1979 21' Superboat 200 Merc-sold-72
  5. #125
    Long Island N.Y.
    Quote Originally Posted by gm250 View Post
    I think you will need a much higher pitch then 31 1.82 is the issue did you buy the ho 250?
    no G1 300hp
  6. Likes ra4577 liked this post
  7. #126
    May 2001
    Ga
    Are you going to keep the push button start system I installed ? How bout the custom side panel ? Will all the gauges work with the brp ? Super slick boat ya got from a great guy too. hf...
  8. #127
    You will need more then a 32 with the 1.85 gear.
  9. #128
    Long Island N.Y.
    Quote Originally Posted by half fast View Post
    you installed that system? I love it!!! great job.... yes everything should work, Im not changing the merc harness, Im going to marry the two plugs, so i dont have to distrub anything, if it can be done.....
  10. #129
    It can be done. It's easy. I think cdi makes an adapter if not just buy a used Merc harnes and U can buy the correct MDS plug from evinrude along with 6 pins to make it work. If you want any system check gauges on the dash U will need to run the whole MDS Evinrude harness. U do not need to have system check if you don't want it.
  11. #130
    Sep 2010
    long island,ny
    Should just be a good 90+ all around prop with nice handling to let Dirk get used to running her. Use 8% slip to get an idea.
  12. #131
    Slip is higher due to the huge carrier in the m2
  13. #132
    Carrier size/gear case size dictating the slip?
  14. #133
    Don't know if you've seen this thread yet...
    http://www.screamandfly.com/showthre...ith-250-H-O-G2
  15. #134
    May 2001
    great south bay
    Reads like a commercial!
  16. #135
    Luv the boat and now the boat cover too Dirk!
    P&G does awesome work.
  1. Any Jet boat shops long Island NY??
    By Jo Jos Fountain in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 05-19-2014, 09:01 PM
  2. long island boat events
    By mercracer2.5 in forum Upcoming Events, Races, and Gatherings
    Last Post: 07-29-2011, 02:39 PM
  3. Long Island Boat Accident
    By lightspeed in forum General Boating Discussion
    Last Post: 10-09-2009, 02:56 PM
  4. need help with boat LONG ISLAND???????????????
    By 21eagle in forum General Boating Discussion
    Last Post: 05-18-2009, 02:03 PM
  5. any boat appraisers on long island?
    By wbones9 in forum The Scream And Fly Lounge
    Last Post: 07-16-2008, 04:22 PM
