Page 81 of 105 FirstFirst ... 31 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 LastLast
Results 1,201 to 1,215 of 1571
  1. #1201
    East Wallyworld Vt
    I was always curious that your plates mount to the back of the shaft where the vacuum really works the fasteners. Good it was not worse. Excel exhaust is at 40mm.
    Regards,
    Charlie North
    If it ain't broke, modify it.
    87 Glastron CVX20 Hull
  2. #1202
    I don't know if its just me but did not that screw break? Pic looks like 1/2 is threaded in the throtle shaft?
  3. #1203
    Aug 2004
    Venice, Florida
    Quote Originally Posted by Dave Strong View Post
    Both parts, the head and the threaded are in the piston. The threaded hole in the throttle shaft is vacant LOL. I would like to find some high quality button head allens to replace them.
    21' Paramount
    Mercury 300 Promax
  4. #1204
    Aug 2004
    Venice, Florida
    Quote Originally Posted by CharlieN View Post
    Is the Excel and the Special the same?
    Just need a good height to shoot for. I may try and pick Hydrotecs brain and see if they will share with me. My buddy who does beautiful port work and lives right down the street is going to raise them up for me.
    I think in the end letting spin a little higher with less load will be a better overall package. I only need 500 rpm to run the same 97.4 mph with a 30 pitch that I ran with the 32 pitch and the 30 runs much better. If I can run a 28 in the low 90's for every day boating my gearcase/propshaft bearing issues will likely be reduced.
    Of course, I only need 200 rpm to break 100mph with the 32 and I think its really going to wake up now. The engine has 65 hours on it since the build. It will also give me a good chance to look at how everything we did is holding up.
    21' Paramount
    Mercury 300 Promax
  5. #1205
    Beefs motor ate a few brass pull overs, we found 1 in the reeds but the other 2 went through the motor. Not sure why but we never found a reason to pull it down. It ran 99 with a 26 and a 1.86 case when we noticed they were missing.
    Sorry to hear the 4 banger has to come apart but I think if you give Gordon a shout you will be 100+ first time out.
    BTW thanks for the new brackets 2 thumbs up for customer service
  6. #1206
    Aug 2004
    Venice, Florida
    Quote Originally Posted by Ray Neudecker View Post
    The V-6 special also known as a 220 was the predecessor to the excell. It had a vertical front half and the same porting as the later EXcell.
    Oh man, Ray answered my question 18 months ago. :-(
    21' Paramount
    Mercury 300 Promax
  7. #1207
    Aug 2004
    Venice, Florida
    You know Ted with the Yellow Mirage. He is going to do it. I can literally walk it over to his house. No worries about shipping and his port work is really nice. This is just a little grinding and a freshen up. Probably cost me less than the 34 pitch prop i would need to go faster.
    21' Paramount
    Mercury 300 Promax
  8. #1208
    Ted is the man and hangs out with the other local mad scientists. Hell if you wanted to go faster just let Ted's ole lady drive it
  9. #1209
    Aug 2004
    Venice, Florida
    She is probably the only one that would. I outweigh her by 140 pounds so it would be interesting.....
    21' Paramount
    Mercury 300 Promax
  10. #1210
    Quote Originally Posted by Mr. Demeanor View Post
    I wasnt banking on the weight but good point
  11. #1211
    Aug 2004
    Venice, Florida
    These seem pretty conservative? I think Ted said the Merc 2.5 stuff is around 1.6
    Mine has the ex relief notches as well.
    21' Paramount
    Mercury 300 Promax
  12. #1212
    Years ago when I was rebushing QJet carbs was a place that sold different throtle shaft screws. Think it was called the Carb Shop. Probably has a different name now but look at places that restore old muscle car carbs might hook you up with screws. I know I always used new screws when rebushing shafts.
  13. #1213
    The only difference between a stock 225 and a 250 (3.0 carb looper) is the exhaust port is .170 wider and .070 higher. The intake ports will have to be moved to move power up.
  14. #1214
    Aug 2004
    Venice, Florida
    Just measured mine at 1.62" which is pretty high. Talked to Hydrotech and they say 1.550 max.
    21' Paramount
    Mercury 300 Promax
  15. #1215
    East Wallyworld Vt
    The early 200 Ex is at 1.69 or 43mm
    My early 150 ProV is the same 1.69 with the addition of a 10mm or call it 3/8 notch.
    The 225 Excel is 1.57
    These numbers are from engines I have measured.
    So with yours at 1.62 that was a hotter tune than the 200 was, interesting.
    Looking forward to what power you have with another 1.5 or 2mm port height.
    Regards,
    Charlie North
