Results 811 to 825 of 1571
Thread: Yamaha 130 V4 Project Build.
05-26-2014, 04:09 PM #811
Thats my concern but if it does, putting the jackplate back on should fix it. The only issue I forsee is the slow/mid range hop might be worse. If it is, I can just move the motor back to get some more lift.
I took some measurements and bolting the motor right to the transom using the existing holes I end up 1/2" lower than it is now. I was going to drop it down a little anyway as its felt very loose at 85+. Even yesterday with a full tank and my smaller prop if starting feeling really loose back there at 85. I think between lowing it and losing the weight it might be a wash. The setback will be the same if I lose the jackplate..13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
05-26-2014, 04:12 PM #812
If that were mine I would rework that lower bracket so the shifter goes down through the swivel as original.
For a tiller arm you could consider sandwiching an aluminum plate under the powerhead and have it protrude out the front as needed.Regards,
Charlie North
If it ain't broke, modify it.
87 Glastron CVX20 Hull
05-26-2014, 04:14 PM #813
05-26-2014, 05:01 PM #814
I dont know that losing weight back there is the answer. I would actually like the back to feel more planted and reduce the hop. My new 28 I had a lot of cup put in and the hop is almost gone. Im thinking it all over but I might even try more setback to settle the boat down at high speed.
I would think, and please feel free to comment, that increasing the distance between the prop and the back of the two sponsons (the only parts touching the water) would make the boat more stable. The boat would think its longer. But...it would also increase the crabbing effect as the prop would have more leverage as it paddle wheeled sideways. The paddle wheel effect / crabbing is my issue if anything.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
05-26-2014, 05:04 PM #815
05-26-2014, 05:13 PM #816
Ain't that the truth.lol
Maybe just best to mount it to the present plate and see how it goes, bit more set back than you wanted. But may run great and way less work than pulling the plate first and needing to put it back on. Easier to only change one thing at a time, cuz if change a couple your never sure just what didn't work out.
05-26-2014, 06:49 PM #817
05-26-2014, 07:22 PM #818
As long as the shaft length has not been set yet you have total freedom. My mind was on a piece of 7075 but the stainless would be tougher where the tiller bolt goes through.
Regards,
Charlie North
05-26-2014, 07:57 PM #819
Thats right. I love the plate idea.!
Dago
05-26-2014, 08:16 PM #820
It gives you allot of freedom to get the clearances Chris is looking for without things getting out of hand with needing to change the steering cylinder or other components.
Regards,
Charlie North
05-26-2014, 08:45 PM #821
i had to use trim stops and one inch transom wedges on mine to get it to tuck where it would come out of the hole and still turn all the way. if you just moved the bottom of the jack plate in as far as you can and left the top alone that shouldnt mess with the setback. you would loose the slot the bolts ride in but if you are happy with the height it is at now that shouldnt be a problem..........benji
hold on and hope for the best
05-26-2014, 09:26 PM #822EDITED my post, did not make sense:I would think, and please feel free to comment, that increasing the distance between the prop and the back of the two sponsons (the only parts touching the water) would make the boat more stable. The boat would think its longer. But...it would also increase the crabbing effect as the prop would have more leverage as it paddle wheeled sideways. The paddle wheel effect / crabbing is my issue if anything.
Being more stable is a possibility I would think. Your points form a tripod so to speak. The farther those legs are apart they more planted it may feel.
I like that mid.
CLast edited by milkdud; 05-27-2014 at 11:50 AM.
L6fan57-88
05-26-2014, 10:56 PM #823
The prop is applying force sideways to the skeg in my case a lot of force because its so high. The further the prop is from the transom, the greater the the leverage the prop will have to crab the boat.
Ive thought about adding more skeg forward toward the front of the gearcase. Gordon actually mentioned it awhile back.
The plate idea is cool but more complicated IMO. Im about keeping it simple. Bolting on a new tiller using the top engine mount bolts or just welding on a new tiller arm is the simplest solution IMO.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
05-27-2014, 05:25 AM #824I am not sure that the plate is complicated especially if that mid has bearings that do not want undue heat from welding.The plate idea is cool but more complicated IMO. Im about keeping it simple. Bolting on a new tiller using the top engine mount bolts or just welding on a new tiller arm is the simplest solution IMO.
granted a bolt on tiller does not impose heat but your mounting points are narrow so the fabricated parts need to be beefy near the attachment.
The plate would just sandich under the powerhead. the bottom pan gets trimmed as needed to set in place.
One of my thoughts where the swivel point is moved forward is that this moves the prop further back increasing steering load at high speed. Granted it is not uncommon to move the swivel forwards in high performance applications.
I also wonder if a 1:1 gear ratio and short prop would work well for your needs. Much less side walking of the prop at speed.Regards,
Charlie North
05-27-2014, 06:51 AM #825
