Page 47 of 105 FirstFirst ... 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 97 ... LastLast
Results 691 to 705 of 1571
  1. #691
    East Wallyworld Vt
    Nice performance, So late in the week you will have much cooler air to run in. It would be interesting to see what some power air will give you.
    Regards,
    Charlie North
    If it ain't broke, modify it.
    87 Glastron CVX20 Hull
  2. #692
    Mar 2002
    Racine,WI
    Absolutely awesome!! Love following your progress!
    Jeff
    VENTURA BROS
  3. #693
    Aug 2004
    Venice, Florida
    Went out after dark and took a look at my piston tops. It doesnt look too fat. Im going to leave it jetted where it is for awhile and pull a head after I get a good wash.
    Thanks for the nice comments
    21' Paramount
    Mercury 300 Promax
  4. #694
    Aug 2004
    Venice, Florida
    Quote Originally Posted by CharlieN View Post
    It was pretty good today. 73 and low humidity. Im sure 40 degrees and no cross wind would do a little better. I may drop it in the salt later this week. Prop slip will be a tiny bit lower in the salt.
    21' Paramount
    Mercury 300 Promax
  5. #695
    sw florida
    Way cool chris.! Great job.
    Now leave it alone and lets do some boating.!
    Dago
  6. #696
    englewood florida
    Quote Originally Posted by Mr. Demeanor View Post
    Let me know when, I'd like to see if I can break 100.....finally.
    18 Action 225 Promax
  7. #697
    Aug 2004
    Venice, Florida
    You have a 100mph+ boat. Its just not finished....
    You need to write out a check list and go through it.
    21' Paramount
    Mercury 300 Promax
  8. #698
    Aug 2004
    Venice, Florida
    Quote Originally Posted by dagodiver View Post
    Dago
    Absolutely. Looking forward to the upcoming runs.
    The boat ran 92.7 right off the trailer today. Ran 92.5 the other direction. Dropped one size in jets and it picked up in the midrange but ran 92.7. It was crazy consistent.
    At the end of the day the wind laid down a little and it went 93.9 with no other changes. Amazing what a little change in conditions can do. It wasnt a little spike either. It held 93.8+ for at least a half mile.
    The prop is 1/2" larger diameter than what I have been running. I was going to try going up 1/4" which is about 1 to 1.5mph but I didnt have my 3/4" wrench. I dont know how the prop will like going higher but I would like to try it once.
    21' Paramount
    Mercury 300 Promax
  9. #699
    Jackson,Tenn.
    Good job. Awesome motor.
    Ray Neudecker Over The Hill Gang Outboard Racing
  10. #700
    Aug 2004
    Venice, Florida
    Quote Originally Posted by Ray Neudecker View Post
    Thanks for all your help and advice Ray.
    21' Paramount
    Mercury 300 Promax
  11. #701
    englewood florida
    I'll bet you know what the first on the list is.
  12. #702
    Quote Originally Posted by rkmirage View Post
    My buddys ski racer ran 103 with a 175 efi on 87 octane. You should be 110 with a top end setup. Nice looking boat too
  13. #703
    Aug 2004
    Venice, Florida
    He will get there. Its just not set up and has real conservative static trim right now. It did like this 32x15 ET though.
    21' Paramount
    Mercury 300 Promax
  14. #704
    Aug 2004
    Venice, Florida
    Huh?
    21' Paramount
    Mercury 300 Promax
  15. #705
    Sep 2002
    Dublin, Ireland
    Working on a lightweight cowl for the yam V4! Should be ready in next few weeks!
    looking at it I'd say it'll fit over a V6 too but will need to see after its finished!
    styled on the SHO cowl.
    Will fit stock tray and hopefully use stock latches!
    Power Marine 650 Offshore Race, Yamaha 130 Pro-V
