Page 46 of 105 FirstFirst ... 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 96 ... LastLast
Results 676 to 690 of 1571
  1. #676
    Its in there we filled quite a bit of room and put carson reeds in it. Ran it the other day didnt notice much change but still need to tune mid range. Turning 7400rpm seems to run out of port right around there. We need a bit more timing its still 2* less than factory spec. We jetted it down until 4 stroke stopped and left it alone. Also have a different set of heads we want to try, should make a bit more power with the flat top 3.3 pistons.
  2. #677
    Waukesha,Wi
    How did the stacks work for you?
  3. #678
    Aug 2004
    Venice, Florida
    Quote Originally Posted by hydro View Post
    Have not run them yet. Waiting for a set of reeds for the new cages I ported. Holidays, etc....
    21' Paramount
    Mercury 300 Promax
  4. #679
    Aug 2004
    Venice, Florida
    Reeds are here (thank you Mr. Carson) and I just finished lapping the cages. They were BAD!!!! Should be running tomorrow.
    Weather looks awesome on Sunday for a high speed run if I can get it dialed in.
    The first pic was after a LOT of lapping and its still not flat.
ID:	290050Click image for larger version.
    21' Paramount
    Mercury 300 Promax
  5. #680
    Sep 2009
    iowa
    What grit do you start with and what did you finish with?
    1975 Hydrostream Ventura II
    1987 evinrude 200xp
  6. #681
    Aug 2004
    Venice, Florida
    Quote Originally Posted by NosBoss View Post
    I asked Mr. Carson and he said 400. These were really bad so I was using 320 to get some material off and the finish looks real nice. The 320 was probably worn to 600 y the time I had it done! I have always done this wet (water and dish soap) but I tried one dry and it seemed to work better.
    Yamaha cages have a very small lip along the bottom edge one one side of the cage you have to grind off before your start lapping.
    21' Paramount
    Mercury 300 Promax
  7. #682
    Sep 2009
    iowa
    Awesome, thanks!
    1987 evinrude 200xp
  8. #683
    Aug 2004
    Venice, Florida
    Shes running for the first time since November. New propshaft, reeds, cages, and carb mods.
    Going to the lake tomorrow with a 32 ET
    21' Paramount
    Mercury 300 Promax
  9. #684
    englewood florida
    I hope you can turn it....sort of... lol!
    18 Action 225 Promax
  10. #685
    Aug 2004
    Venice, Florida
    I said it would run 94mph and it did.
    94mph t 7050rpm with 32 x 15 Performance Propeller ET and a set of .106"/2.7mm (#36 index drill) drilled jets. The stock jets were 1.80mm.
    The carb mods and new reeds worked awesome. I can not beleive how much fuel this thing is taking and its never 4 stroked.
    Prop calculator show 12% and a 34 x 15 should put me around 96-97mph.
    21' Paramount
    Mercury 300 Promax
  11. #686
    Apr 2013
    Canada
    Quote Originally Posted by Mr. Demeanor View Post
    i have the same prop for my excel,and barely turn it you must be making some good hp numbers, have you had it on a dyno?
  12. #687
    Aug 2004
    Venice, Florida
    Quote Originally Posted by BoomerMuskoka View Post
    Its probably around 170hp but I am turning it with engine height. My gearcase is 1/2" out of the water. Nothing but skeg....the bullet is dry.
    I like these props a lot. Going to have some props for sale soon. I have a 28 and 30 real ET and a 30 drag that need new homes I think. The boat really likes the 15" props.
    PS. I totally stoked. 94mph was always in the back of my mind and 95mph kind of a perfect scenario stars aligned downhill with a tail wind dream. I think its going to happen now. Today was on a small lake with NO current and about a 10mph cross wind for the record.
    21' Paramount
    Mercury 300 Promax
  13. #688
    Apr 2013
    Canada
    hats off to you my friend, that a great achievement, nothin' but skeg
  14. #689
    Jul 2011
    Louisiana
    Won't be long till we see you posting 100 mph I bet.
  15. #690
    Apr 2013
    Canada
    Quote Originally Posted by chris3198 View Post
    and with a v4, it blows my mind.
