Results 676 to 690 of 1571
Thread: Yamaha 130 V4 Project Build.
12-26-2013, 11:56 PM #676
Its in there we filled quite a bit of room and put carson reeds in it. Ran it the other day didnt notice much change but still need to tune mid range. Turning 7400rpm seems to run out of port right around there. We need a bit more timing its still 2* less than factory spec. We jetted it down until 4 stroke stopped and left it alone. Also have a different set of heads we want to try, should make a bit more power with the flat top 3.3 pistons.
12-29-2013, 08:39 PM #677
5000 RPM
- Feb 2002
- Waukesha,Wi
- 226
How did the stacks work for you?
12-29-2013, 09:19 PM #678
01-10-2014, 01:44 AM #67913' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
01-10-2014, 10:26 AM #680
5000 RPM
- Sep 2009
- iowa
- 679
What grit do you start with and what did you finish with?
1975 Hydrostream Ventura II
1987 evinrude 200xp
01-10-2014, 10:32 AM #681
I asked Mr. Carson and he said 400. These were really bad so I was using 320 to get some material off and the finish looks real nice. The 320 was probably worn to 600 y the time I had it done! I have always done this wet (water and dish soap) but I tried one dry and it seemed to work better.
Yamaha cages have a very small lip along the bottom edge one one side of the cage you have to grind off before your start lapping.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
01-10-2014, 10:35 AM #682
5000 RPM
- Sep 2009
- iowa
- 679
Awesome, thanks!
1987 evinrude 200xp
01-11-2014, 02:13 PM #683
Shes running for the first time since November. New propshaft, reeds, cages, and carb mods.
Going to the lake tomorrow with a 32 ET
21' Paramount
Mercury 300 Promax
01-11-2014, 05:21 PM #684
I hope you can turn it....sort of... lol!
18 Action 225 Promax
01-12-2014, 06:28 PM #685
I said it would run 94mph and it did.
94mph t 7050rpm with 32 x 15 Performance Propeller ET and a set of .106"/2.7mm (#36 index drill) drilled jets. The stock jets were 1.80mm.
The carb mods and new reeds worked awesome. I can not beleive how much fuel this thing is taking and its never 4 stroked.
Prop calculator show 12% and a 34 x 15 should put me around 96-97mph.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
01-12-2014, 06:36 PM #686
5000 RPM
- Apr 2013
- Canada
- 511
- 18
- 25
01-12-2014, 06:40 PM #687
Its probably around 170hp but I am turning it with engine height. My gearcase is 1/2" out of the water. Nothing but skeg....the bullet is dry.
I like these props a lot. Going to have some props for sale soon. I have a 28 and 30 real ET and a 30 drag that need new homes I think. The boat really likes the 15" props.
PS. I totally stoked. 94mph was always in the back of my mind and 95mph kind of a perfect scenario stars aligned downhill with a tail wind dream. I think its going to happen now. Today was on a small lake with NO current and about a 10mph cross wind for the record.Last edited by Mr. Demeanor; 01-12-2014 at 06:44 PM.
21' Paramount
Mercury 300 Promax
01-12-2014, 06:53 PM #688
5000 RPM
- Apr 2013
- Canada
- 511
- 18
- 25
01-12-2014, 07:21 PM #689
Member
- Jul 2011
- Louisiana
- 36
Won't be long till we see you posting 100 mph I bet.
01-12-2014, 07:36 PM #690
5000 RPM
- Apr 2013
- Canada
- 511
- 18
- 25
