Page 13 of 105 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 63 ... LastLast
Results 181 to 195 of 1571
  1. #181
    Aug 2004
    Venice, Florida
    I guess 97.1 on your second pass with a big prop
    I guess its going to take seat time to get used to the new power. 95 would be awesome as that would be as fast as the center steer Biel with a 225.
    I spent 30-40 minutes on the phone with Bob Kottman today. I was a little worried as I have heard he can be cranky but he was great. Seemed like a genuinely nice guy.
    Everything is looking good for building next weekend. Ultrfast (Don) agreed to look over my shoulder and make sure I righty tighty all the bolts and install the pistons in the correct holes. Don, if your reading this, clear the schedule.
    21' Paramount
    Mercury 300 Promax
  2. #182
    Quote Originally Posted by Mr. Demeanor View Post
    I dont think he knows how to do that!
  3. #183
    Aug 2002
    florida
    Quote Originally Posted by baja200meha!,rk View Post
    alrighty then!,
  4. #184
    Aug 2004
    Venice, Florida
    Flow bench testing my epoxied front half
    21' Paramount
    Mercury 300 Promax
  5. #185
    melbourne florida
    Cool
    What is the PRACITCAL hull speed on this 13' hull??? at some point it's going to want to fly, not trying to be negative but when I was runnin my MAGNUM MISSLE w/a 2.5 offshore merc 16' boat, which was designed to go 60's, w/a I-6 1500xs, at 70mph-75mph no problem-then 75-85 mph the boat started talking to me, when I got to 90mph it was a handfull and only on a perfect day would I push my luck, it was exciting and scarry at the same time knowing there history...just be careful and use common sence and don't let the #95 bring you down...." HAPPY TRAILS "
  6. #186
    Aug 2004
    Venice, Florida
    Quote Originally Posted by magnum2.5 View Post
    I think the boat will be safer on typical days when I am running with a group at 80mph as I will be able to do it with a lot less trim. Now, letting it all hang out will be adventure and ist something that I will sneak up on a little at a time.
    Having said that, this boat really drives like a much bigger boat. Its not light (500 pound hull) and the short tunnel may actually make it less prone to flight. If it had sponsons pickle forks like a typical tunnel it would measure longer but really be no bigger.
    Ive been hurt pretty bad doing various things and am a little older, wiser, and beat up these days.
    21' Paramount
    Mercury 300 Promax
  7. #187
    melbourne florida
    BTW...I like your LOGO alot...there is a 21 PARAMOUNT with twin 200 merc's for sale over here...spacecoast craigslist...would match your
    logo perfect...be like RICH MARTIN buy your old boat back rather than change your AVITAR... AVOID THE NOID
  8. #188
    Aug 2004
    Venice, Florida
    Just got off the phone with Falicon and my rotating assembly should be done today. There have been some issues with the rotating assembly (all at my end) and Falicon has been FANTASTIC to deal with. I have been working with Sean up there and he has been extremely helpful and patient. Great customer service. Cant wait to see the crank.
    21' Paramount
    Mercury 300 Promax
  9. #189
    Aug 2004
    Venice, Florida
    Crank is done and being shipped back. I will have it tomorrow and start to assemble Saturday. I will post pics of the work they did.
    21' Paramount
    Mercury 300 Promax
  10. #190
    southast ark
    Mr d does Falicon have a website???
    Laser 1550 ...under construction with a serious weight loss
    Motor 2.4....undecided on hp yet
  11. #191
    Aug 2004
    Venice, Florida
    http://www.faliconcranks.com/
    My last Falicon crank was in this:
    21' Paramount
    Mercury 300 Promax
  12. #192
    Aug 2004
    Venice, Florida
    I would love to try those Mikuni flat slides off the bike on my motor.
    21' Paramount
    Mercury 300 Promax
  13. #193
    May 2006
    Lakeland, FL
    Lectron 50's.
  14. #194
    East Wallyworld Vt
    Did you have 38 or 40 on the bike? The carbs on your boat are 42mm throttle plates now obviously with different venturi sizing available.
    It would be an interesting machining to make a suitable manifold for the carb spacing. The height of the carbs might be an issue but the spacing could be closed up a bit to get a decent flow path to the reeds.
    I started machining a set of throttle bodies that would bolt on to convert to injection. No reason they could not be made with 44mm plates in them.
    Regards,
    Charlie North
    If it ain't broke, modify it.
    87 Glastron CVX20 Hull
  15. Thanks abdrews013 thanked for this post
  16. #195
    Oslo,Norway
    I had a tuned V4 yamaha, later we looked into using a 225 v6 block front half and cut it to get horisontal reeds and better flow.
    Last corner in Flosta boat race 90mph.
    http://www.youtube.com/watch?v=WbqlgOB3ulQ
    Espen Hilde
    Hosle Norway
    Mobile:
    +47 90700200
