Results 1 to 15 of 17
Thread: Promax carb?
    TN
    Promax carb?
    Can wh-22 carbs feed a 225 promax? I’m sick of computers.
  2. Thanks pcrussell50 thanked for this post
    Likes pcrussell50 liked this post
    Mar 2004
    Brooklyn Park, MN
    Sure can. Just start with main jets around 84-86 and go down from there. You will be safe there, as you go lower remember there will be a lean spot at mid throttle if you get low enough on the main jets (two circuit carbs, no mid range jets). I would go up on idle jets also, go to like .056 or so.
    1973 Viper - sold
    1978 Viking - sold
    1995 XB02
  4. Thanks Baker343, mercrazy, pcrussell50 thanked for this post
    Likes pcrussell50, pkstv liked this post
  5. #3
    May 2009
    7 Post(s)
    Quote Originally Posted by mercrazy View Post
    I hear ya, mate.
    I'm from the fuel injection generation. My track car has the Bosch style fuel injection system that the two stroke EFI Mercs has. I have an interface to the service port of the PCM to let me tweak settings a needed. I never even touched a carb until I got my first boat back in 2008.
    Even still, for my uses as a boater, the simplicity of carbs is like magic to me. It's satisfying to link and sync, and then get the timing pickup just right. I don't put in nearly enough hours to worry too much about fuel economy.
    I don't know if it's anything to go by, but I swear I see way more questions from people having issues with their 2.4/2.5 EFI two strokes right here in this SnF Technical Discussion forum, than I do people having carb motor issues.
    -Peter
    "padded wonder"
    __________
    the wet:
    18’ Bahner bow rider, 2.4/200
    the dry:
    2003 bmw ///M5
    and a handful of clunkers
  6. Likes mercrazy liked this post
  7. #4
    Sep 2017
    Ashland city tn
    Ive ran wh 22s , 46s , 20s on a modified promax, ported , 150 compression the works, depending on weather 82 or 84 mains and 60 idles with wh20s currently. Personally I like the 20s and the 46s but the 22s r good to.
  8. Thanks mercrazy, pcrussell50 thanked for this post
    Likes pcrussell50, rjdubiel liked this post
  9. #5
    TN
    Can I use carbs from a 3 liter 225hp? Seems to be plenty of those. I can’t find wh20s. I want to make a 245hp with a ff block. Also heard I could use Yamaha carbs. What would be best?
  10. #6
    Sep 2017
    Ashland city tn
    I haven't tried but I hear it's hard to get a good runnin tune with 3L carbs but don't take my word for it on that. 245 hp with a ff gonna need alot portin and cuttin and compression. Wh46 carbs also run good. Alot say they can't tell a difference in 46s or 20s etc. Maybe depends on combination of everything not sure. U can get u sum 245 carbs and try those
  11. #7
    TX......somewhere?
    3 liter carbs are a pita ona 2.5 period.. tried a coupla times... not worth tha trouble imo.. a very few have had a little success...
  12. Thanks mercrazy thanked for this post
    Likes 25two.stroke liked this post
  13. #8
    Jan 2020
    Pittsburg, Ca
    I 2nd this.
  14. #9
    TN
    Where can I find 245 carbs? Are they wh15 or wh20 only?
  15. #10
    Jan 2020
    Pittsburg, Ca
    I think both 15s and 20s came on 2.4
    WMH-36 came on a 245?
  16. Thanks mercrazy thanked for this post
    Likes rjdubiel liked this post
  17. #11
    TX......somewhere?
    crap shoot on which wh ya got ona 2.4....
    245's could be several wmh numbers.. think it depended on "whats in tha box" when it got put together deal.. mostly depended on jetting more than anything else... was told this by retired merc guy long time ago....
  18. Thanks mercrazy thanked for this post
  19. #12
    TN
    So what is the main factor in a good carb for a 245? Throat size? Do all wmh carbs have same throat?
  20. #13
    TX......somewhere?
    think venturi size is same but tha internal passages are a little different... believe there were two sizes of venturi openings.. mostly differed with some 135's and 150's... all 175 and better were a tad larger.. even some 150's had same as tha larger on some models.. we used a coupla different wmh's: 16's primarily (when they could be identified) unlike tha wh's.... there were a coupla others but can't recall tha wmh number.. basically anything that came ona 200 or better would work with tha right jetting............
  21. Thanks mercrazy thanked for this post
  22. #14
    TX......somewhere?
    got lucky and found an old thread that MRCRSR had some very good infor 'bout tha carbs....
    Mercury Tech WMV-WMH carb info
  23. Thanks David - WI, mercrazy, LakeFever thanked for this post
  24. #15
    Jan 2020
    Pittsburg, Ca
    I probably have some WMV-18 carbs from a 2.5 200. If you would wanna start with those just send me a pm and I will go look in my shop.
  25. Thanks mercrazy thanked for this post
  1. 225 promax vs 245 carb
    By RRS in forum General Boating Discussion
    Last Post: 04-21-2019, 04:25 PM
  2. 98 Promax and 96 Carb 200
    By JAA in forum Technical Discussion
    Last Post: 08-27-2014, 01:28 PM
  3. making a 225 promax carb.
    By SPECTRE racing in forum Technical Discussion
    Last Post: 04-29-2006, 08:53 PM
  4. Best carb for ProMax
    By FishnFast in forum Technical Discussion
    Last Post: 05-02-2004, 09:23 PM
  5. 245 Carb on ProMax Mid
    By ProComp in forum Technical Discussion
    Last Post: 01-30-2004, 12:57 PM
