Page 5 of 7 FirstFirst 1 2 3 4 5 6 7 LastLast
Results 61 to 75 of 92
  1. #61
    I have replaced a LOT of those check valves on the main tank pressure line over the years.
    Oct 2016
    Northern California
    Are you talking about the tee fitting #424254? Or, the one on the engine block #432783? I am guessing the latter can be bad even though the engine tank still fills, because the pressure still works, but when it fails it allows air to go backwards, thereby causing the siphon effect? Is that right? If I take it out to check, when I put it back, or replace it, is there a sealant that needs to be used, or does it seal simply by threading it back in?
    Edit: Just removed hose on the 432783 on the block. Put a short section on it, and I could not blow back into the block. I could, however, suck air through it and, thankfully, I didn't inhale, because I could certainly "taste" fuel-ish fumes. Disclaimer: This procedure can cause cancer to those that reside in the State of California
    So that leaves me with o-rings and the 424254. Should I order the 424254 to have on hand when I order the o-rings, or take another gamble and just get o-rings?
    1998 Viper Coral 201
    1998 Mercury Promax 300 with Sportmaster
  3. #63
    Nov 2021
    Northwest
    Quote Originally Posted by Basnova View Post
    I am aware, thanks, but not ready for that right now. Also, sounds like work to mix. Do you also have to worry about separation when sitting over the winder, and such?
    I've never had a problem with separation, even after sitting too long.
    On another note. A tool like a mityvac would be very helpful for finding air leaks.
  4. #64
    Start the engine and do the soapy water test on the main oil tank. Hoses and fittings too if you can get to them. You should see bubbles like ski said if there's a leak. . Could be a leak in the tank you can't see just by looking at it. That would be the next test imo. The o-rings may be it, they are old and prob need replaced anyway. The T fitting is 35 bucks so not too bad. The blow back test passed the air supply check valve for function to build pressure in the tank, but it may have debris in it and allow a slow leak. It's about 35 bucks also.
  5. Likes David - WI liked this post
  6. #65
    Apr 2023
    Long island, NY
    You can not use the mouth blow technique to check for a slow leak. A slow leak can show in the bubble test as 1 bubble every few seconds. You will never feel it with your mouth. It's a very basic system. There has to be a leak somewhere before the engine tank. If no leaks show up with the bubble test, change the pressure check valve. But I think new orings will fix it. Make sure all sealing surfaces are clean and dont have any nicks scratches or cracks.
  7. Likes David - WI liked this post
  8. #66
    Oct 2016
    Northern California
    Alright, I ordered two o-rings, and the check valve, just in case. I really don't think it is the tee fitting, because based on how that works, it would allows air in when the motor is running. If it allowed air in while sitting, then it would leak, and it's not leaking. And, it is not a one-way valve for the oil.
    Looks like I will be doing changes in stages because the tank gasket was ordered before the o-rings so I will likely not be able to sit on idle hands while waiting for the o-rings. If it still leaks then, I will replace the o-rings next. If it still leaks then, I will replace the check valve.
  9. Likes skialot2 liked this post
  10. #67
    Jul 2022
    Do you have the aggressive smoke on start up still? Are you sure the pressure relieve valve isn't bad and it is pushing oil into your intake?
    If you leave the cap off it should overflow when idling. But I would start the engine on the hose with the cap off. Let it pump all the way up to the top. Shut the engine off and then see if the oil level goes down with the cap off. If it doesn't, it means the system is staying pressurized and pushing oil into your fuel line with the engine off. If it only happens with the cap on, I would think all your check valves should be fine and the issue is pressure, with the only place for it to go is to bleed into your fuel line.
  11. Thanks David - WI thanked for this post
  12. #68
    It seems to be draining when he tilts the engine up on the trailer locks. Yours is a good test though. Worth doing.
    Oct 2016
    Northern California
    Quote Originally Posted by superboop View Post
    Thank you for chiming in here.
    When I start it and just idle it, it smokes a little, like I would expect a 2-stroke would. If I give it some throttle soon after starting it, I get a clouf of smoke, but once I get it heated up I don't think it's overly smoky. But, I have nothing to compare it to because it's been like that from day one.
    It would definitely overflow if I left the cap off, so I cap it before it gets to the top of the threaded neck, because right now I don't want any oil overflowing while I'm troubleshooting and looking for oil/air leaks.
    But I would start the engine on the hose with the cap off. Let it pump all the way up to the top. Shut the engine off and then see if the oil level goes down with the cap off. If it doesn't it means the system is staying pressurized and pushing oil into your fuel line with the engine off if it only happens with the cap on but all your check valves should be fine.
    That last sentence isn't quite clear to me. Is there a typo and/or a missing punctuation in there somewhere? Could you please clarify that sentence? In the meantime, I can tell you that the oil always only drops to the point just below the fill port, so I'm pretty sure it's being siphoned back down the fill line. I would think if it was pushing into the fuel line the tank level wouldn't always drop to that exact point, or at least be inconsistent, right?
  14. #70
    Apr 2023
    Long island, NY
    If it was pushing oil through when shut off the tank would not stop draining at the fill nipple every time. Plus if that much oil was pushed through the oil pump into the fuel while not running, it would be too much oil in the fuel too run.
  15. #71
    Oct 2016
    Northern California
    ...I would start the engine on the hose ...
    A little off-topic, but I have been sticking the lower end in a 100 gallon horse trough. How do you start it on a hose? Do you mean via the Mercury nose cone attachment? I've been wanting to get one of those because using 100 gallons all the time is a real PITA, and can get costly where I live if I do it enough. But, I heard there are different attachments for different Sportmaster nose cones, and I didn't want to get the wrong one and not get enough water into the motor. Do you happen to know which part number I need? Serial #0G703213, if that matters. I also read on this forum that people DIY using tubes, or something, but I've been scared to try it for fear of, again, not getting enough water flow into this motor.
    Sorry if I hijacked my own thread, but I really do want to know more about this!
  16. #72
    Jul 2022
    Sorry I’ve got a torquemaster on my 98 pro max so it’s easy to put ear muffs on. With your sporty you probably need to stick with the trough. I’m sure there is a way to run off a hose but I don’t want to give you bad information.
  17. #73
    Jul 2022
    Fixed my wording to be more clear. Agree it is odd it is always the same spot. Seems like it’s the check valve at the motor then.
  18. #74
    https://www.buckshotracing77.com/pro...arcase-flusher
    I think you can find these for around $50 if you shop around, but it fits Sportmasters, coned lowers, etc.
  19. #75
    Oct 2016
    Northern California
    I've been researching them, but the inlet is not directly under the pickup on my cone. My pickup
    grate is right under the front of the cone and the inlets on these flushers are farther back. Does that matter?
  1. volvo penta one beep alarm
    By Euroski in forum Technical Discussion
    Last Post: 09-06-2020, 07:46 AM
  2. 2000 Mercury EFI 200 beep beep beep beep beep beep beep
    By claypoolxx in forum Technical Discussion
    Last Post: 07-15-2019, 08:12 PM
  3. 2001 200 Optimax 4 beep alarm
    By Mikeytogo in forum Technical Discussion
    Last Post: 04-21-2019, 05:01 PM
  4. OPtimax 4 beep alarm
    By luckycraft in forum Technical Discussion
    Last Post: 05-28-2009, 10:05 AM
  5. Promax 300 alarm beep after overheating
    By 86 apache 22 in forum Technical Discussion
    Last Post: 07-27-2006, 07:08 AM
