Results 61 to 75 of 92
Thread: 4-Beep Oil(?) Alarm
07-31-2025, 04:02 AM #61
Screaming And Flying!
- 15,042
- 404
- 1441
- 5979
- 11625
I have replaced a LOT of those check valves on the main tank pressure line over the years.
07-31-2025, 08:59 AM #62
5000 RPM
- Oct 2016
- Northern California
- 188
- 15
Are you talking about the tee fitting #424254? Or, the one on the engine block #432783? I am guessing the latter can be bad even though the engine tank still fills, because the pressure still works, but when it fails it allows air to go backwards, thereby causing the siphon effect? Is that right? If I take it out to check, when I put it back, or replace it, is there a sealant that needs to be used, or does it seal simply by threading it back in?
Edit: Just removed hose on the 432783 on the block. Put a short section on it, and I could not blow back into the block. I could, however, suck air through it and, thankfully, I didn't inhale, because I could certainly "taste" fuel-ish fumes. Disclaimer: This procedure can cause cancer to those that reside in the State of California
So that leaves me with o-rings and the 424254. Should I order the 424254 to have on hand when I order the o-rings, or take another gamble and just get o-rings?Last edited by Basnova; 07-31-2025 at 10:17 AM.
1998 Viper Coral 201
1998 Mercury Promax 300 with Sportmaster
07-31-2025, 10:27 AM #63
07-31-2025, 12:21 PM #64
- 15,042
- 404
- 1441
- 5979
- 11625
Start the engine and do the soapy water test on the main oil tank. Hoses and fittings too if you can get to them. You should see bubbles like ski said if there's a leak. . Could be a leak in the tank you can't see just by looking at it. That would be the next test imo. The o-rings may be it, they are old and prob need replaced anyway. The T fitting is 35 bucks so not too bad. The blow back test passed the air supply check valve for function to build pressure in the tank, but it may have debris in it and allow a slow leak. It's about 35 bucks also.
David - WI liked this post
07-31-2025, 01:14 PM #65
You can not use the mouth blow technique to check for a slow leak. A slow leak can show in the bubble test as 1 bubble every few seconds. You will never feel it with your mouth. It's a very basic system. There has to be a leak somewhere before the engine tank. If no leaks show up with the bubble test, change the pressure check valve. But I think new orings will fix it. Make sure all sealing surfaces are clean and dont have any nicks scratches or cracks.
07-31-2025, 01:41 PM #66
5000 RPM
- Oct 2016
- 188
- 15
Alright, I ordered two o-rings, and the check valve, just in case. I really don't think it is the tee fitting, because based on how that works, it would allows air in when the motor is running. If it allowed air in while sitting, then it would leak, and it's not leaking. And, it is not a one-way valve for the oil.
Looks like I will be doing changes in stages because the tank gasket was ordered before the o-rings so I will likely not be able to sit on idle hands while waiting for the o-rings.If it still leaks then, I will replace the o-rings next. If it still leaks then, I will replace the check valve.
skialot2 liked this post
07-31-2025, 04:00 PM #67
Junior Member
- Jul 2022
- Wisconsin
- 12
Do you have the aggressive smoke on start up still? Are you sure the pressure relieve valve isn't bad and it is pushing oil into your intake?
If you leave the cap off it should overflow when idling. But I would start the engine on the hose with the cap off. Let it pump all the way up to the top. Shut the engine off and then see if the oil level goes down with the cap off. If it doesn't, it means the system is staying pressurized and pushing oil into your fuel line with the engine off. If it only happens with the cap on, I would think all your check valves should be fine and the issue is pressure, with the only place for it to go is to bleed into your fuel line.Last edited by superboop; 07-31-2025 at 10:08 PM.
David - WI thanked for this post
07-31-2025, 06:14 PM #68
- 15,042
- 404
- 1441
- 5979
- 11625
It seems to be draining when he tilts the engine up on the trailer locks. Yours is a good test though. Worth doing.
07-31-2025, 07:14 PM #69
5000 RPM
- Oct 2016
- 188
- 15
Thank you for chiming in here.
When I start it and just idle it, it smokes a little, like I would expect a 2-stroke would. If I give it some throttle soon after starting it, I get a clouf of smoke, but once I get it heated up I don't think it's overly smoky. But, I have nothing to compare it to because it's been like that from day one.
But I would start the engine on the hose with the cap off. Let it pump all the way up to the top. Shut the engine off and then see if the oil level goes down with the cap off. If it doesn't it means the system is staying pressurized and pushing oil into your fuel line with the engine off if it only happens with the cap on but all your check valves should be fine.Last edited by Basnova; 07-31-2025 at 07:16 PM.
07-31-2025, 07:16 PM #70
If it was pushing oil through when shut off the tank would not stop draining at the fill nipple every time. Plus if that much oil was pushed through the oil pump into the fuel while not running, it would be too much oil in the fuel too run.
07-31-2025, 07:27 PM #71
5000 RPM
- Oct 2016
- 188
- 15
A little off-topic, but I have been sticking the lower end in a 100 gallon horse trough. How do you start it on a hose? Do you mean via the Mercury nose cone attachment? I've been wanting to get one of those because using 100 gallons all the time is a real PITA, and can get costly where I live if I do it enough. But, I heard there are different attachments for different Sportmaster nose cones, and I didn't want to get the wrong one and not get enough water into the motor. Do you happen to know which part number I need? Serial #0G703213, if that matters. I also read on this forum that people DIY using tubes, or something, but I've been scared to try it for fear of, again, not getting enough water flow into this motor.
Sorry if I hijacked my own thread, but I really do want to know more about this!Last edited by Basnova; 07-31-2025 at 07:30 PM.
07-31-2025, 10:05 PM #72
Junior Member
- Jul 2022
- Wisconsin
- 12
07-31-2025, 10:09 PM #73
Junior Member
- Jul 2022
- Wisconsin
- 12
07-31-2025, 11:33 PM #74
https://www.buckshotracing77.com/pro...arcase-flusher
I think you can find these for around $50 if you shop around, but it fits Sportmasters, coned lowers, etc.
08-08-2025, 03:27 PM #75
5000 RPM
- Oct 2016
- 188
- 15
volvo penta one beep alarm
By Euroski in forum Technical DiscussionReplies: 1Last Post: 09-06-2020, 07:46 AM -
2000 Mercury EFI 200 beep beep beep beep beep beep beep
By claypoolxx in forum Technical DiscussionReplies: 5Last Post: 07-15-2019, 08:12 PM -
2001 200 Optimax 4 beep alarm
By Mikeytogo in forum Technical DiscussionReplies: 2Last Post: 04-21-2019, 05:01 PM -
OPtimax 4 beep alarm
By luckycraft in forum Technical DiscussionReplies: 4Last Post: 05-28-2009, 10:05 AM -
Promax 300 alarm beep after overheating
By 86 apache 22 in forum Technical DiscussionReplies: 25Last Post: 07-27-2006, 07:08 AM
