Results 1 to 15 of 17
Thread: fuel pres gauge
11-12-2024, 04:59 PM #1
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,941
- 595
- 100
- 518
- 627
fuel pres gauge
has anyone tapped into the shrader valve [laser] to run a gauge up to the dash? seemed simple enough, but cant find a coupler/connector from valve to poly hose line. its some kind of spec thread, need a female to thread on shrader valve? or a better way? any suggestions would help,tks ArtK
11-12-2024, 05:32 PM #2
eliminated schrader with a "T"... ran braided stainless up to dash... gauge and stainless came from summit...........
11-12-2024, 05:49 PM #3
You need a "gauge isolator" if you're going to run the line through the cockpit... so gasoline doesn't spray all over or the line fails or gets cut (or if the gauge fails and leaks).
https://help.summitracing.com/knowle...SR-00125/en-us
NICE PAIR thanked for this post
11-12-2024, 06:50 PM #4
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,941
- 595
- 100
- 518
- 627
a T ?. dont want to take the inj front apart, cant i just thread somthin on the schrader? a nipple of sort?
11-13-2024, 01:44 AM #5
ya keepin' tha "factory reg" and etc?.. always "pro stocked" all my laser junk..... as for a fuel leak. ya already have lotsa fuel junk in tha boat ta start with.. if worth a grain a salt then you would not increase tha chance of a fuel leak anymore than is already in tha boat.......... jmo.
11-13-2024, 01:58 AM #6
NICE PAIR liked this post
11-13-2024, 02:05 AM #7
KIRCHNER liked this post
11-13-2024, 08:46 AM #8
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,941
- 595
- 100
- 518
- 627
11-13-2024, 09:55 AM #9
11-13-2024, 01:11 PM #10
11-13-2024, 01:14 PM #11
Maybe something like this ?? with adapter for the schrader
11-13-2024, 01:23 PM #12
11-13-2024, 01:24 PM #13
Will those work?
11-13-2024, 04:13 PM #14
i went through two of those before i gave up and went ta mechanical.... they jus didn't last very long.
KIRCHNER thanked for this post
11-13-2024, 05:47 PM #15
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,941
- 595
- 100
- 518
- 627
i ordered a 6' poly shrader ext hose ebay, shrader female end to engine other to hand held gauge. ill know whats up after 1 run. 6$ hose ebay for the race car we used soft copper appliance frdge stuff, compression fittings only 6psi for a big holly4bbl.
Old Livorsi Fuel Gauge turned into Digital Volt Gauge
By Liberator*21 in forum Custom Rigging and Metal FabricationReplies: 31Last Post: 01-24-2014, 02:01 PM -
Fuel Pres. Need Help
By twister in forum Technical DiscussionReplies: 2Last Post: 06-14-2003, 08:39 AM -
2.4 carb. fuel pres.
By popslavaz in forum Technical DiscussionReplies: 2Last Post: 08-07-2002, 04:25 PM
