Page 15 of 23 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 LastLast
Results 211 to 225 of 332
  1. #211
    Jan 2003
    aalsmeer
    Quote Originally Posted by Tcatrett View Post
    Its a 162 sport master from a 3.2 Opti. Had to mod the drive shaft and shift shaft.
    What did you have to modify on the shift shaft?
    I thought that would be a drop in
  2. #212
    Jun 2004
    Morgan City, LA
    Quote Originally Posted by PanRonnie View Post
    I used the 150 shift shaft. Not sure why they did it but the spline was off. Would not line up in neutral. I put it in my lathe and twisted it a little.
  3. Likes 108 liked this post
  4. #213
    Mar 2015
    bunnell FL/old town FL
    Quote Originally Posted by 22R View Post
    Anyone see or know MSRP? Glad we have a option though still a bit heavy.
    22R
    I heard around 22-23 with the sportmaster
    2003 mirage ski racer with e-tec power
  5. Thanks 22R thanked for this post
  6. #214
    Jul 2004
    Connecticut
    Testing the 150 pro xs on my XB02 soon. Installing this weekend.
    Testing this week a few days after work.
    Storm is headed to us so testing will be delayed.
    Were you ever able to get out and run the 150 Pro XS ?
  7. #215
    Jun 2004
    Morgan City, LA
    Yes. Been testing props. 24 fury is fun. Ran a lil over 80. The 28 bravo is slow to plane but after that it pulls hard to 87. Going to put about 20 hours on it then work on a stand alone pcu with a wide band O2 sensor. The stock system does not like prop ventilation.
  8. Likes David, Greg G liked this post
  9. #216
    Jul 2004
    Connecticut
    What size Sporty gear case is the 200R V6 using?
  10. #217
    Apr 2023
    Long island, NY
    I read somewhere it is a 4.8" sporty. But now I cannot find where I read that.
  11. #218
    Jun 2004
    Morgan City, LA
    Its the same case as the 300r. 5.44"
  12. #219
    Lake Coochiching, Ontario
    5.44 is big. Probably too big for small v bottom boats
  13. #220
    Dec 2019
    Spring Lake MI
    The large gearcase and the speed control stuff while surfacing a prop in a single application I hear is not super ideal or fun to drive. If I ever go 300r I will have a Motec on it for sure.
    TJ @ Baker Engineering
    Tuff 24 300xs
    Tuff 16 90 Yammie
    3.75@199mph with LSX power!!!
  14. #221
    Dec 2009
    middle tennessee
    I didn’t know “Speed Control” was a thing until I read your post and looked it up. Damnit. No reason for that to be on an R motor. Or there at least needs to be a way to turn it off. That last thing you want in a small pad v is the computer changing the throttle position without driver input. Ugh
  15. #222
    Jul 2004
    Connecticut
    Wait, so not only does the 200R have the big 5.44" gearcase, it also has a computer that restricts and changes throttle like a robot?
  16. #223
    Apr 2023
    Long island, NY
    There are 3 different gearcases available on the 300R. The Sportmaster, the Torquemaster and the larger 5.44HD. The Sportmaster and Torquemaster are not 5.44" diameter.
ID:	537758 Click image for larger version.
ID:	537756Click image for larger version.
  17. #224
    Apr 2018
    Lake Placid, FL
    The Sporty is 5.44", the torquemaster is narrower.
  18. #225
    Jul 2004
    Connecticut
    So on the V6 you can choose at time of order what gearcase you want with a 200R ?
    You can get the 5.44" Sporty with a torque tab, or you can get the Torquemaster which has less diameter (probably bigger than 4.75") and water inlets on the top of the bullet as well as the side.
  1. Caldwell Racing Technology Introduces Billet 2.5 Liter V6 Engine
    Last Post: 02-19-2024, 09:16 PM
  2. XS Series-Custom Built From Mercury Racing.
    By 4-strucked in forum General Boating Discussion
    Last Post: 05-09-2012, 10:23 AM
