Page 2 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 16 to 30 of 64
    Aug 2021
    Osteen/Deltona, FL
    Quote Originally Posted by rock View Post
    I was somewhat confused by the bare block and 1 pc heads also. If it's an 88 200 it's certainly not a fishin motor.
    Rock
    My thoughts as well.
    83 Vking 150 Mariner 2.5L
  2. #17
    May 2024
    Tennessee
    Og787233
  3. #18
    May 2024
    Tennessee
    So I’m guessing it’s a 1987 then?
  4. #19
    Pekin, IL
    So were there no numbers or letters behind the timing arm?
    Rock
    Team Junk
  5. #20
    May 2024
    Tennessee
  6. Likes LakeFever liked this post
  7. #21
    Jun 2018
    Floating around
    Lucky bastard that’s a 225 promax block. Gotta run the good fuel in that one. No ethanol 91 oct minimum. Might want to pull a head, cc it and measure the head gasket thickness. Could be your issue right there
  8. #22
    Pekin, IL
    Does look like an NN stamp. Can you show a pic of the side of the engine.
    Rock
    Team Junk
  9. #23
    Apr 2023
    Long island, NY
    Congratulations!!! you got a nice motor!!!
    Serial number that starts 0G7***** Is probably a 1997 or 1998
    0G3******* is a 1996. So, it has to be newer that that.
  10. #24
    May 2024
    Tennessee
  11. #25
    May 2024
    Tennessee
  12. #26
    May 2024
    Tennessee
    I will get more pictures tomorrow if I need more to help y’all out.
  13. #27
  14. #28
    Pekin, IL
    That is what is commonly known as a Frankenmerc. Definitely a 225 Promax block but with carbs. And no fuel pump.
    Rock
    Team Junk
  15. #29
    May 2024
    Tennessee
    So needs to have a electric fuel pump?
  16. #30
    May 2024
    Tennessee
    A couple more questions should I run it with the tstats and poppet valve? I also put a different lower unit off a Mariner 150 i was wondering if that could be some of the problem? Any and all help would be appreciated.
  1. 1988 200hp black max 2700 Lake Lanier GA
    By BrownEyedGirls in forum Outboard Engines
    Last Post: 04-29-2020, 09:11 PM
  2. 1988 Mercury 200 Outboard Overheating at high RPMs
    By K-DOGG in forum Technical Discussion
    Last Post: 08-10-2016, 03:13 PM
  3. OMC 97 200HP overheating
    By wfowahoo in forum Technical Discussion
    Last Post: 02-08-2007, 05:48 AM
  4. merc upgrades 1988 200hp black max
    By david martin in forum General Boating Discussion
    Last Post: 12-05-2005, 09:07 PM
  5. Merc V6 200hp overheating
    By tindell1 in forum Technical Discussion
    Last Post: 01-21-2005, 11:28 PM
