Results 16 to 30 of 64
Thread: 1988 Black max 200hp overheating
05-23-2024, 09:24 AM #16
05-23-2024, 07:16 PM #17
Member
- May 2024
- Tennessee
- 31
Og787233
05-27-2024, 08:09 AM #18
Member
- May 2024
- Tennessee
- 31
So I’m guessing it’s a 1987 then?
05-27-2024, 11:50 AM #19
So were there no numbers or letters behind the timing arm?
RockTeam Junk
05-27-2024, 01:18 PM #20
Member
- May 2024
- Tennessee
- 31
LakeFever liked this post
05-27-2024, 01:41 PM #21
Lucky bastard that’s a 225 promax block. Gotta run the good fuel in that one. No ethanol 91 oct minimum. Might want to pull a head, cc it and measure the head gasket thickness. Could be your issue right there
05-27-2024, 01:49 PM #22
Does look like an NN stamp. Can you show a pic of the side of the engine.
RockTeam Junk
05-27-2024, 03:02 PM #23
Congratulations!!! you got a nice motor!!!
Serial number that starts 0G7***** Is probably a 1997 or 1998
0G3******* is a 1996. So, it has to be newer that that.
05-27-2024, 03:39 PM #24
Member
- May 2024
- Tennessee
- 31
05-27-2024, 03:42 PM #25
Member
- May 2024
- Tennessee
- 31
05-27-2024, 03:42 PM #26
Member
- May 2024
- Tennessee
- 31
I will get more pictures tomorrow if I need more to help y’all out.
05-27-2024, 04:03 PM #27
05-28-2024, 06:55 AM #28
That is what is commonly known as a Frankenmerc. Definitely a 225 Promax block but with carbs. And no fuel pump.
RockTeam Junk
05-28-2024, 07:05 AM #29
Member
- May 2024
- Tennessee
- 31
So needs to have a electric fuel pump?
05-28-2024, 10:16 AM #30
Member
- May 2024
- Tennessee
- 31
A couple more questions should I run it with the tstats and poppet valve? I also put a different lower unit off a Mariner 150 i was wondering if that could be some of the problem? Any and all help would be appreciated.
1988 200hp black max 2700 Lake Lanier GA
By BrownEyedGirls in forum Outboard EnginesReplies: 5Last Post: 04-29-2020, 09:11 PM -
1988 Mercury 200 Outboard Overheating at high RPMs
By K-DOGG in forum Technical DiscussionReplies: 8Last Post: 08-10-2016, 03:13 PM -
OMC 97 200HP overheating
By wfowahoo in forum Technical DiscussionReplies: 5Last Post: 02-08-2007, 05:48 AM -
merc upgrades 1988 200hp black max
By david martin in forum General Boating DiscussionReplies: 8Last Post: 12-05-2005, 09:07 PM -
Merc V6 200hp overheating
By tindell1 in forum Technical DiscussionReplies: 3Last Post: 01-21-2005, 11:28 PM
