Page 11 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11
Results 151 to 165 of 165
  1. #151
    PARADISE /Naples
    https://bobsmachine.com/product/fixed-setback-brackets/
    Wally Lamkin the owner of Triad boats the builder of STV's before Jack B got the molds had his son running in Lake Racer class drag racing 1/4 mile, the boat was the top boat at that time and Wally said to me they said that all that set back would not work...
    He proved them wrong with his son winning time after time
  2. #152
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by RSWORDS View Post
    Thanks
    Yeah. Im.looking into adding an extension box the bolting my jackplate to it
    Quote Originally Posted by CUDA View Post
    That's the bracket I was looking at. Anything wrong with bolting my jack plate to it to get my 12"?
  3. #153
    Not at all ... works good. Thats how I did my Superboat. Bought a 6" ran it for a while, decided it wasn't enough and added 4" .
    The big hub wheel we talked about the other day ... does it have a flair ring at the back .. ??? If so, chuck it in the lathe and cut it off as short as possible. Big hub adds length to the gearcase (stability) and without the ring it won't add any additional influence to the handling.
    As always, tell the princess I said howdy ...
    P.S. How does she like her new boat ....
  4. #154
    I did the cut down mod to a tempest prop. One of my best runners now.
    Jul 2011
    Gloucester, VA
    It does. I need to carry it to my machinist amd get some holes in it.
    The chopper feels way more solid and settled then the scorpion but I feel that's because the scorpion was actually lifting the boat and trying to get up.
    She loves her new boat and I'll tell her buddy
  6. #156
    Jul 2011
    Gloucester, VA
    Ok so raised the motor up some more. The "some kinda cut" chopper sucks now. Won't get the boat up and only running mid 60s. Adding trim does nothing to the attitude of the boat. Bow stays down.
    The solas scorpion is getting her up on the pad and banging the limiter at about 80. Boat rides good but I still feel I'm trimming way above level.
    So I'm needing to search for another prop. I like the hole shot of the over the hub. Any suggestions? I do need to add my extra set back still though.
    This is the chopper. Not sure what cut it is. I know it started as a small ear
  7. #157
    Aug 2003
    Gilbert Arizona
    The 4 blade will have better holeshot and cruise and will only be a few mph slower,also the 4 blade is way smoother due to its balance properties
    You need a Mazco RE-4 or RE3,a Spinelli is a good choice also
  8. #158
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by wideglide55 View Post
    I have a RE3 that's at the prop shop being cleaned up right now. Hopefully that has more bite
  9. #159
    Aug 2003
    Gilbert Arizona
    I ran every prop known to man on my Vegas V-Bottom and on my Daytona and never found any other prop that had better bowlift,holeshot and top speed than the Mazco,the only prop that was almost as good was a Spinelli
  10. #160
    Aug 2003
    Gilbert Arizona
    My Vegas had the identical bottom as your Vulture because it was an early Vegas,they changed the bottom on the newer model
    Vegas.The difference is the seating is much farther forward in your boat so a prop with lots of bow lift is a must
  11. #161
    Jul 2011
    Gloucester, VA
    I agree. A driver m9d would be my best bang for the buck. As in shedding 100 lbs. Lol
  12. #162
    Jul 2011
    Gloucester, VA
    Been running it and enjoying it. My C-Hawk is done for the year so I can replace the floor and stringers so I figure there is no point in letting a perfectly good 300 sit around while getting my floor replaced....Click image for larger version.
  13. Likes CUDA, mistah_max, Hippie459MN, NICE PAIR liked this post
  14. #163
    Oct 2010
    Harrisburg,Pa
    Get a Hoss Triton or Hyperdrive 28-30 The big blades on the hoss help with planning, Good bow lift too.
  15. #164
  16. Thanks RSWORDS thanked for this post
    Likes Hippie459MN liked this post
  17. #165
    Jul 2011
    Gloucester, VA
    Couple Videos from labor day
    Running 83 at 6300 RPM with a hill 28p 4 blade on the limiter and it gets to there quick. When it does his the limiter the sudden lack of acceleration REALLY upsets to boat LOL
    Going to locate a 32 i think. I really like how the 4 blade carries the boat. Also going to add my 6" extensions
    https://www.youtube.com/watch?v=aDzIGF-gdN4
    https://www.youtube.com/watch?v=GKVZPt91qOo
  18. Likes motexas, LakeFever liked this post
  1. 20' Hydrostream Vulture
    By xcheesehd in forum Hulls up to 20'
    Last Post: 09-12-2016, 11:12 PM
  2. hydrostream vulture?
    By 16ft superboat in forum General Boating Discussion
    Last Post: 05-25-2011, 09:03 PM
  3. New toy Hydrostream Vulture
    By bahamatrama in forum General Boating Discussion
    Last Post: 09-05-2010, 07:10 PM
