    Feb 2008
    Lars Strom
    Wow great picture Pasi,
    Thanks
    I guess it’s from Stockholm 1985 before the mid section broke and the engine ended up at the bottom of “Riddarfjärden”
    Divers found the engine next day and took it to my Evinrude dealership so we could save the powerhead from corrosion damage..
  2. Likes Watermark liked this post
  3. #9647
    Feb 2008
    Pasi Haavisto
    Lars, It is hanging for a while in the wires.
  4. Likes 22R, Watermark, Lake X Kid liked this post
  5. #9648
    Feb 2008
    Lars Strom
    Pasi, The power-pack flew up in the dry pit and ended up close to Roland Rosenholtz..the Officer of the Day for the race..
    Pasi Haavisto
    Lars, and here it is gone.
  6. #9649
    Feb 2008
    #4 Kari Saukkonen, Finland UIM SE Class Evinrude/JK-Cat. (1986)
    Salvekvik (adhesive plaster) is a good sponsor if you crash a lot.
    Photo: Tiina Haavisto
  7. #9650
    Feb 2008
    @Watermark
    Check this out..memories from Stockholm GP 1985.
    I was there keeping an eye on you all..!!..
  8. Likes Lake X Kid liked this post
  9. #9651
    Aug 2004
    20 Post(s)
    Smile
    Quote Originally Posted by lars strom View Post
    @Watermark
    That's a memory, for sure!, Lars.
    The engine broke off while driving through the corner, shortly after Barry's incident. My boat hooked sharply to the left, launching the boat straight into and overtop of one of those massive orange turn-pins. When it splashed down and all went quiet, it was one of those "What the hell happened? " moments.. "Could have been worse!", I thought.
    So then, a few minutes later, I had a first-hand, on-the-water view of Arthur Mostert heading down the straight, entering the turn and losing his engine. That was scary .. seeing a V8 fly through the air - and then the boat skip/slid sideways across the water heading toward the break-wall. It was amazing to watch it stop just meters away, and see Arthur climb safely from his cockpit.
    Naturally the race was called after that.
    Thanks to Pasi Haavisto for taking and sharing those photographs. Amazing to see decades later - and a good reminder that luck was with us, and those spectators standing on the wall.
    - Mark
  10. Thanks lars strom, Lake X Kid thanked for this post
    Likes peterse90, lars strom, Jimboat liked this post
  11. #9652
    Feb 2008
    Quote Originally Posted by Watermark View Post
    - Mark
    Thanks for your report Mark.
    Here is the Powerboat & Waterskiing report from Stockholm GP 1985.
    Attached Thumbnails Attached Thumbnails Screenshot (20).png   Screenshot (21).png
  12. Thanks Watermark thanked for this post
  13. #9653
    Aug 2004
    20 Post(s)
    Wow.. sounds like that tow-boat guy had a bad day too..
    .. and as you've reported on before, that issue didn't end there. Bertil was extremely fortunate to have survived his crash through an aluminum safety boat during practice in Minneapolis. On board were several people who likely resigned immediately from that volunteer job!
  14. Thanks lars strom thanked for this post
    Likes lars strom, Jimboat liked this post
  15. #9654
    Feb 2008
    #12 Bertil Wik in Minneapolis 1985 (practice)
  16. Likes Lake X Kid liked this post
  17. #9655
    Southern California
    31 Post(s)
    I would have thought the boat’s transom would have been the weak link, not the V8 engines mid-section. With all that engine torque and vibration, the boat’s wooden transom prevailed.
    I saw Freddy Miles in his Milesmaster come to shore in England, with a ripped-out transom. And the engine with the help of the steering cables, did not sink to the bottom Lake Windermere.
  18. #9656
    Feb 2008
    It was the early 6 inch mid sections when they came out 1985 who broke.. Was replaced fast by OMC with better design/material.
    Newer an issue after that.
  19. #9657
    Feb 2008
    Quote Originally Posted by Lake X Kid View Post
    Well the 6 inch mid section was possible because at the same time OMC developed the fuel injection. (1985)
    A carb power-head was not possible to use for the 6 inch mid section, but you could change the carb power-head to fuel injection.
    If you look close at this picture you can see there is not enough space for a carb power=head. (Lower part of the front)
    You can also see pretty good at this picture how short the 6 inch mid section is..(light grey casting)
    Again, it was the early 6 inch mid sections when they came out 1985 who broke (Stockholm GP & Minneapolis).. Was replaced fast by OMC with better design/material.
  20. Likes Jimboat liked this post
  21. #9658
    Feb 2008
    Peter "Pepe" Sandman UIM SE class 1985.
    Photo: Tiina.
  22. #9659
    Aug 2012
    So the injected motor had a horn with the throttle body in the middle (like newer stuff nowadays) allowing the motor to be lower?
  23. #9660
    Southern California
    31 Post(s)
    That 6 inch mid-section looks like cast aluminum. And if there is some porosity in the metal after the casting process, then those air gaps will be a weak link. Or the thickness of the casting might not have been thick enough.
Page 644 of 901 FirstFirst ... 144 544 594 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 694 744 ... LastLast
  1. Evinrude & Johnson Racing 1967+
    By Mark75H in forum Outboard and Racing History
    Last Post: 04-24-2023, 09:58 PM
  2. V8 Johnson/evinrude Outboards
    By baassoc in forum General Boating Discussion
    Last Post: 04-17-2020, 06:21 AM
  3. D and E Class OMC outboards, Johnson 60 and Evinrude 75
    By smokin'joe in forum Outboard Engines
    Last Post: 05-21-2017, 09:24 AM
  4. Replies: 0
    Last Post: 10-02-2014, 09:07 PM
