Results 106 to 120 of 293
Thread: 2.5 ff rebuild
10-04-2018, 07:36 PM #106
Bobby thanks a ton. Since all mine r new but 2. I'll just order me 2 new ones and let bullet get yours. I know he bout need some to!
10-04-2018, 09:20 PM #107
Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 505
ive been in the same discussions before with fong, ive never ever had a stock rod bolt break in a single motor ive rebuilt ever!!!!!!!!! even in my own twisted up promaxs or 2+60 or 280 or 300 x ive had all of them my own ,the stock rods wont use the big head 260/280/300drag rod bolts ive never seen 5/16 head arp that are hi strength but that does not mean somebody does not make them. i closed shop last year i had seven blocks back from machine un built and all kinds of parts i just pulled the plug i was SICK dealing with some people .
Laseraddict liked this post
10-04-2018, 09:31 PM #108
(936) 229-1865
- Jul 2012
- Lufkin, Texas
- 2,653
- 301
- 279
- 1791
- 1275
Yes, got my stock fishin' motor '79 175 partially disassembled. It broke a rod at 8,000 RPM's. This motor has been on the 'Stream since '81. Regular use by the original owner and then myself up to 72-7400 since then. Original owner scuffed a piston (#1) in the early 90's. He sent the original lower to Bob's at that time and had it coned. Cleaned the bore w/ acid and replaced the #1 piston. Some 15 years later I wound it to 8k for an extended period and the #1 rod almost cut the top of the block off. At first I thought the rod bolts had broken. After disassmbly it was clear that the bolts backed out. He didn't use loctite when he put it back together...
Josh Peterson
10-05-2018, 05:47 AM #109
I'm putting all blame on the new hf torque wrench. It seem to b very accurate up to 25lbs but when set to 30 it wouldn't click. Moral of the story is. Stay away from harbor freight
10-05-2018, 06:54 AM #110
Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,352
- 10
- 265
- 32
- 733
I think I agree with you...and I'de be changing any other rod bolts you used that wrench on too,I've never broken a rod bolt while installing,thousands of them...Chris
10-05-2018, 07:48 AM #111
I have also never broken a rod bolt. I have felt several of them stretch as I was torqueing them. Pull them out and they have a distinct hour glass shape to them. Seen one back out cuz of blue Loctite and have seen a bunch of broken rods. Mercury uses a pretty good bolt. 35 lbs torque with red Loctite.
RockTeam Junk
10-05-2018, 06:23 PM #112
While I didnt get very far in ,the couple I did do in steps seemed to do "ok" would a dirty thread cause wrench to fail? Seems like damn wrench should had clicked at sum point? I should had been watching the bottom of the bolt I guezz but I never felt any difference on the wrench til it snapped. But again I can feel a bolt gonna break with a 3/8 ratchet, i was easing into the 30lb also. I didnt just (go to town) with it. Either way chris has me little nervous so I'm gonna replace the couple I did also, I've been very picky/precise so far that I wouldn't sleep good at nite thinking bout those rod bolts . I wanna get it on water b4 winter but ,if it takes a week longer so be it. So to the ones that's thinking about doing this for the 1st time. if something like this comes along , go the safe route. No need taking a chance!
10-05-2018, 06:32 PM #113
Dirty threads would have added drag and caused wrench to click before proper clamping force. The wrench calibration is just probably off. A torque to yeild bolt will only tighten so far then goes into an elastic state for “improved” clamping force (this is the point of the extra rotation after the last torque setting). Let’s say the bolts went into elastic state near 40 ft lbs and your wrench set at 30 was actually over the elastic state torque, it would never click but the bolt would just keep stretching until it gave up the ghost. This is more than likely what happened, wrench clicked just fine as long as you were below the elastic state of the bolted
Merc 2.5 thanked for this post
10-05-2018, 06:35 PM #114
You can check the length of the bolts to a known good one, if they are the same length, you are ok. If any are longer, they have already been put into the elastic state and should be changed
10-07-2018, 06:14 PM #115
I may not have need to but I went ahead and ordered 12 new bolts w/o torque to yield. Just standard torque method, not sure what kind they are,arp or sps or pro brand ordered from promarine , I'm 90% sure the bolts in it now r good but im just gonna go with all new standard type bolt, what's another 40$ for good insurance and not knowing 100% what state the others r in, I'm actually on a mini vacation in Gatlinburg tn at moment but hopefully by wed I'll have new bolts and start getting it ready for them .. question..... I think I should be able to chase/clean threads without taking pistons out? Nice clean rag under everything and just take my time ?
10-08-2018, 08:16 PM #116
10-10-2018, 11:41 AM #117
5000 RPM
- Jun 2014
- South Carolina
- 187
- 37
- 15
- 63
- 74
Got a Q I'd like to add to your thread Merclover if you dont mind -
Whats up w removing the front half - can it be removed to inspect the crank and slapped right back together without issue or would bearings/ seals/ tolerances shift around... Any special procedures to note while doing that?
10-10-2018, 11:46 AM #118
Not real sure what the question is be honest? Front half has to b removed to get to rods and crank. There is seals and o ring on top and bottom cap. Are you rebuild or swapping fronts?
10-10-2018, 12:02 PM #119
5000 RPM
- Jun 2014
- South Carolina
- 187
- 37
- 15
- 63
- 74
Pulling front to inspect crank, and reassembling. Mainly wondering- is the crank/bearings and everything retained so it can go right back together without issue..
10-10-2018, 12:08 PM #120
Yes everything is retained
NeedOne thanked for this post
Rebuild!
By Merc 2.5 in forum Technical DiscussionReplies: 113Last Post: 08-12-2018, 04:49 PM -
best place for powerhead rebuild/lower rebuild on Long Island?
By play2win in forum Technical DiscussionReplies: 2Last Post: 08-08-2011, 01:49 PM -
Mercury Tech: 3.0L S/Master Rebuild-Who's a good source for a rebuild ?????
By Liberator*21 in forum Technical DiscussionReplies: 4Last Post: 10-06-2010, 06:39 AM -
Mercury Tech: Powerhead on Mercury 125 hp/to rebuild or not to rebuild? Help! Please?
By rickyo in forum Technical DiscussionReplies: 5Last Post: 06-05-2010, 04:08 PM -
Need Rebuild on CLE
By bigmotor in forum Technical DiscussionReplies: 0Last Post: 07-14-2005, 10:06 PM
