Page 2 of 2 FirstFirst 1 2
Results 16 to 27 of 27
    Jul 2013
    medellin colombia
    If the engine is still running ok, you probably wont need any pistons. New pistons have different weights. Thats why you use a digtal gram scale to make sure they are usable. Don't know where you'd find a gram scale in columbia though, lol. Many things to know to build these motors properly. Big-block chevy's they ain't. You familiar with the 260's charging system?
    Yeah I feel ya on the scale. The ones they sell here the tare weight is 1 kg lol
    2 years ago one of my workers found a 40kg white square grouper floating near my island. It was like he hit the lottery even at the three dollars a gram retail price locally (it’s a dollar fiddy a G in medellin) he was rich btch. Lol
    No I’m not familiar with the 260 charging or ign system yet. What should I look for as far as inherent problems with this engine?
    If the bores and pistons are in good shape should I still swap for the top pinned pistons or can my existing pistons be modified to be to pinned?Thx. Rm
  2. #17
    Jul 2013
    medellin colombia
    I’m buying it for 4 million pesos which is about 1300 bucks u.s. which seems cheap enough. It’s missing the steering hardware tho
  3. #18
    If you have the mechanical ability tear it all the way down and look over everything carefully. Nice 260s are getting tough to come by. The gaskets and seals required are cheap. At the minimum measure the bores, run a brush hone down it and re ring. Along with an injector service
  4. #19
    Jul 2013
    medellin colombia
    i will take it to a machine shop to measure the cylinders with a bore gauge and I will mic the pistons myself. There is a good injector place in medellin they did the injector on my sumo. When you say brush hone are you talking about those dingle berry hones, as I have a set.
    Where are you guys buying your merc parts online? Thanks so much for the info guys
    what is to look out for on the 260 charging systems ? Thx again. Rm
  5. #20
    The charging system is enough to run the motor and that is about all. excessive idling, stereo etc will draw down the battery.
    https://goodson.com/collections/flex...nt=34583657606
    followed by
    https://goodson.com/collections/ultr...nt=33471791622
  6. Likes BUZZIN' DOZEN liked this post
  7. #21
    5 Post(s)
    New York
    I have 2 of them ill sell ya that don't need rebuilds. And they even come with a boat.
  9. #23
    minocqua, wis
    followed by
    would you use uf 350 ?
  10. #24
    Ft. Lauderdale, Fl
    Might be worth a 20 minute call to Jay Smith JSRE here....... he can get you squared away with parts and a huge wealth of information.......... http://jaysmithracing.com/
    Don't let the crappy website fool you, he is in the top 3 of his class in knowledge.
  11. Likes Capt.Insane-o liked this post
  12. #25
    Put your good ear on.
  13. #26
    Dec 2011
    Ludington michigan,on the shore
    Mic the stock Pistons,if they are not already top pinned,but mic ok send them to John Marles,he will top pin them,and supply rings for 6/7 hundred US dollars.Nothing wrong with a good seasoned used piston.Makes break in a non event!
  14. #27
    Jul 2013
    medellin colombia
    Thanks for all the info guys. Rm
  1. building a 21 in colombia south america
    By ratman67 in forum General Boating Discussion
    Last Post: 11-09-2016, 08:23 PM
  2. Total overhauling stv for international river championship in Colombia!!!
    By juanpava in forum General Boating Discussion
    Last Post: 09-05-2015, 05:40 PM
  3. getting raped by a thieving cusoms broker in colombia
    Last Post: 01-30-2014, 01:32 PM
  4. Colombia S C to florida???
    By ChrisCarsonMarine in forum General Boating Discussion
    Last Post: 05-29-2013, 03:38 PM
