Page 33 of 50 FirstFirst ... 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 LastLast
Results 481 to 495 of 740
  1. #481
    Aug 2011
    Lake Mälaren, Sweden
    Update:
    Head studs finished! (Shown in another thread)
    Rods freshened up with 400grit wet paper:
    Upper main bearing removed from its carrier:
    I placed the bearing carrier on a steel pipe in the owen.
    Once it reached 450 degrees the bearing dropped right out.
    Just clean and repaint the carrier before applying heat and a new bearing and a new seal.
  2. Likes olboatman liked this post
  3. #482
    Aug 2011
    Lower bearing carrier, not new -but almost...
  4. #483
    Aug 2011
    What do you guys think of this:
    Found it on this cite:
    http://richstaylordporting.com/moder...kePorting.html
  5. #484
    a gimmick.
    total waste of time and effort. and a patent as been applied for by a Pakistani !!!, that alone should tell you straight away its a con.
    its a way of making the combustion chamber bigger again if you have skimmed to much off... no science behind.
    another one of gupta's daft idea's that a lot of mugs will pay for to help slow down their motors.
    idiots saying how much its improved the power especially when they decked the block and skimmed the head !!!! err object defeated.
  6. #485
    Aug 2011
    This evening I did some crank preparation.
    Some pics:
ID:	399382400grit paper cut to fit the bearing race. Taped tight with some diesel as cutting fluid.
ID:	399381A long shoe lace around the race to spin the paper back and forth.
ID:	399383 The difference
  7. Likes FMP, NosBoss, olboatman, phillnjack liked this post
  8. #486
    Dimpling quench area has been dyno proven, V8 auto. Also port passages.
  9. #487
    Aug 2011
    Today it was time to fill the idle reliefs...
    Took a plastic syringe of about the same size as the relief holes.
    Cleaned the holes with acetone and plugged them in the bottom using parts of a foam earplug.
ID:	399477Of course I managed to create some mess on one of the cyls due to exessive amounts of JB. Tried to clean the bore fast with acetone, so I hope it didn’t end up clogging the cross hatches next to the relief hole.
    Attached Thumbnails Attached Thumbnails D6BD7749-8F6A-4EE8-BC00-C8B23CAC8CFD.jpg
  10. #488
    Sep 2009
    iowa
    That's exactly how I filled my relief holes. Keep up the good work!
    1975 Hydrostream Ventura II
    1987 evinrude 200xp
  11. #489
    that crank has come up very nice indeed.
    the idle reliefs look as though they should stand up ok, but from my understanding of the idle reliefs and how they work, is to give a far
    smoother idle, but from above 2000 rpm they dont do anything at all !!! so where is the gain in filling them in ?
    will they make a difference to mid range rpm and top end if no other mods were done ?
    this is something I have not done ( yet) as I have had conflicting advice on the idle reliefs
  12. Thanks bigbluechevy454 thanked for this post
  13. #490
    Sep 2002
    Solvang, Calif
    " so where is the gain in filling them in ? " Compression.
    Gary
  14. Likes Freddie Webb liked this post
  15. #491
    Aug 2011
    Quote Originally Posted by NosBoss View Post
    The method works fine doesn’t it?
    When I do the other bank this evening, I will grease the bore after clearing the relief hole iot prevent any epoxy from ending up in the bore.
    Clogging the bore’s cross hatch, thats the only thing I’m a bit worried about right now. I will try to inspect it with a magnifying glass. I hope it won’t need another round with the Lisle 15000!
  16. Likes phillnjack liked this post
  17. #492
    why not just put tape around it and then poke a small hole in it.. any glue from the tape can be wiped off afterwards.
  18. #493
    Aug 2011
    Quote Originally Posted by phillnjack View Post
    I’ve tried that, the problem is the air pocket that is being created between the bottom plug and the epoxy being poured in. You need to work it down there and thats why it becomes messy... With tape some of the goo easily finds its way in under the tape
    I am probably over reacting as any residue in the bore probably will disapear after a couple of piston strokes!?
  19. Likes phillnjack liked this post
  20. #494
    yes i think you are worry a bit too much.. it looks pretty nice to me..
    might sound daft but if you are worried then what about putting a drop of nail varnish around the area before you start ?
    that will come off for sure with acetone. any microscopic buts left will just disappear on first fire up ... just a silly thought..
  21. Likes spybot liked this post
  22. #495
    Aug 2011
    Its not the same bore in the pic, but no matter -you are probably right...
  23. Likes phillnjack liked this post
