Page 1 of 4 1 2 3 4 LastLast
Results 1 to 15 of 55
    Apr 2016
    Port perry
    95 evinrude 200 porting
    Ok guys the winter project is tore down planning on doing some exhaust porting trying to get around 250 horse out of it racer mentioned that I should make my exhaust ports the same size as an 89 225 but does anyone have suggestions on the shape and size that actually is and how I can make this happen. Ps I'm open to secrets on porting these motors.
    Apr 2016
    Port perry
ID:	426544 so another thing should I knock down all of the extra material from the block and the sleeve not matching up on all the intake port
    May 2001
    Mooresville NC
    Yes being careful to maintain the same angles.
    Jun 2002
    winter haven fl
ID:	426556Saw this on a jet ski site pretty cool idea it is a magnetic port map for the Yamaha 701 for surf riding, curious if this has been done in the outboard world much?
  5. Thanks Instigator thanked for this post
    Likes Instigator, Captain75 liked this post
    Apr 2016
    Port perry
    That's a pretty sweet idea I have been trying to figure out how I'm going to make a template to transfer the 89 exhaust port to the 95 and also do I maintain the top edge or bottom edge of the exhaust port or spilt the difference this is my first time doing port work so the more guidance I can get the better thanks guys
    May 2001
    Mooresville NC
    Leave bottom edge alone. Piece of aluminum tubing slide inside a sleeve (sleeve out of engine) and marked then cut out can then be slide inside your 95 and used as a template.
  8. Likes mikiedreb liked this post
    Apr 2016
    Port perry
    So because the easiest rout for me to get a sleeve is just to buy one is this the correct one https://shop.tsmperformance.net/Cyli...ore-1025SA.htm
    Apr 2016
    Port perry
    K guys I've been searching for someone with a sleeve and cant find one anywhere can anyone help me finding somewhere to get it. Thanks
    Sep 2017
    Ashland city tn
    U need get ahold wrechin 2 (James perry) makes his own
    May 2001
    Mooresville NC
    Advanced sleeve makes replacements with stock porting if you get an 88-92 that will have the exhaust port you want.
    Apr 2016
    Port perry
    Thanks racer but just went and visited frank and he had a sleeve lieing around so I got one thanks tho
  14. #12
    Apr 2016
    Port perry
ID:	429777Click image for larger version.
    Ok guys got a template made and the exhaust ports ground out turned out realy good also smoothed out any of the casting marks in the intake slots in the crank case and also were the sleeves didnt match the motor is there anything else I should do while I have the motor ripped apart.
  15. #13
    Sep 2017
    Ashland city tn
    Add a small chamfer (spell?) To ports to help from a ring snag and actually help performance , acting like its opening little sooner, looking good tho
  16. #14
    Apr 2016
    Port perry
    So make it more oblong
  17. #15
    Sep 2017
    Ashland city tn
    No. You want a small bevel on edge port, I'll try post a pic of mine if I can find it
  1. OMC 2 L porting
    By evilrude 1 in forum Technical Discussion
    Last Post: 02-22-2014, 08:50 PM
  2. Replies: 11
    Last Post: 06-13-2010, 02:03 PM
  3. XR4 porting?
    By peedeerooster in forum Technical Discussion
    Last Post: 11-11-2008, 09:27 PM
  4. Evinrude Porting
    By BilDewey in forum Technical Discussion
    Last Post: 10-06-2001, 09:18 AM
  5. Question on Z porting VS. Bridge porting?
    By Riverracer280SS in forum General Boating Discussion
    Last Post: 09-05-2001, 08:52 AM
