Page 7 of 8 FirstFirst 1 2 3 4 5 6 7 8 LastLast
Results 91 to 105 of 112
  1. #91
    SW Florida
    Quote Originally Posted by JPEROG View Post
    Don't forget to mention that you also run your case up in the nose bleed section so you either need the "Holbrook cheater case" or a remote pick up. Brent it the one that told me where to set my current STV/300X up at and it was perfect from day one. Getting the case set back and elevated makes a big difference in accel. and handling.
    Yea I tried going up last week but something was up with my water pump and I wasn't getting psi had to bring it back down. I put a new pump in and it was back to normal at idle in a tank so I will try going up again. What's the most you guys think I can go without the cheat or boat mounted pickup? I'm at 1 4/8" above centerline now that's putting a long level on the pad levelling the boat, estimating center of the bullet with a mark levelling the engine trim then measuring up from the level that's on the pad to the mark on the gearcase
    2004 Hydra-Sports Vector 2600 - twin 225 Yamahas
  2. #92
    Look down the inverted Vee from the front of the boat with the motor at neutral trim and raise it until you just barley see the water pick ups on the bottom of your case. That is as high as you can go without mods.
  3. Likes baja200merk liked this post
  4. #93
    SW Florida
    Ok gonna try tomorrow.
  5. #94
    Quote Originally Posted by at100plus View Post
    Have you ever been 120 in a hyundai?
  6. Likes AZMIDLYF, NICE PAIR liked this post
  7. #95
    Discovery Bay, CA
    The propshaft height on my STV Euro/300XS was 1 7/8" above the pad when I got the boat, and the ECU had no "low water pressure" codes triggered when we put the DDT on it. I raised it to 2" above the pad, but haven't run the boat yet at that new setting. Like Joe recommended, I sighted it from the front, and can just see the bottom of the pickups below the running surface. I've run several 3.0/3.2 cases at 2.0" above the bottom on larger boats without water pressure problems........
  8. #96
    I have no idea what you are talking about- LOL... nothing runs like a rental-
  9. Likes Todd D, baja200merk, NICE PAIR liked this post
  10. #97
    Quote Originally Posted by Rayzor View Post
    Don't forget to delete the guardian mode when it's near the limiter. Small single engine boat....
    I tried to do 120 in hers and I lost sight in my right eye. Must be the panoramic roof.
  11. Likes frank jackson liked this post
  12. #98
    lindsay on. canada
    ouch !!!
  13. #99
    Just saw a 138 posted for STV RR with a 225x/sporty combo. You out running with him Scawd?
  14. Likes baja200merk liked this post
  15. #100
    Dave driefort ran 138 but did you just say 225x? Maybe it was 15yrs ago haha
  16. #101
    Only repeating what was written in the post. Definitely not a 3.0L.
  17. #102
    Plantation Florida
    No I did not , but Dave has logged more time than anyone I know of north of 130 in a STV. He is by far the set up man that I know for just about any High Performance single outboard boat. He was running one of his Good 2.5's in warm conditions the other day to 138. With the Cool weather he will easily crank north of 140. Maybe he will chime in and embellish a little more.
    Brent
    2009 LCB 2005 300X
  18. #103
    Quote Originally Posted by scawd the dog View Post
    Wow!
  19. #104
    Plantation Florida
    Cool weather -Suwannee
    Brent
    2009 LCB 2005 300X
  20. #105
    Thats fast enough big boy. I don't think anyone could run a five mile stretch of that river and remain within sight of you. Its bad ass but I don't want to loose anymore friends-JMO.
  21. Likes AZMIDLYF, NICE PAIR, Hot Shot Merc liked this post
  1. 300x and it's owner go "MAD" stay tuned.....
    By Liberator*21 in forum Custom Rigging and Metal Fabrication
    Last Post: 12-12-2017, 01:52 PM
  2. 250XS or the "grrrrrrrrr" 300X--Need input
    By salty cat in forum Props, Setup, and Rigging
    Last Post: 03-04-2005, 07:47 PM
