Page 2 of 11 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 LastLast
Results 16 to 30 of 165
    Jul 2011
    Gloucester, VA
    So, anyone have any suggestions on a style and pitch of a prop to get a baseline? Going to be a 2002 200 fishing motor with old ingnition so you can spin up to 6500ish if needed. Cut the heads, reject as needed?
  2. #17
    melbourne florida
    my sugestion would be to set the boat up in what ever fashion you think will work for your application, then drive it, feel it out, get comfortable with normal operation, then start making adjustments to the base line, so you really know if they make a differance or not....be safe...Hydrostreams take some seat time for proficent performances
  3. Likes davemvegas liked this post
  4. #18
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by magnum2.5 View Post
    I agree. I've never had a performance oriented boat though so I don't really know where a good baseline to start would be. From my reading I'm thinking a 24" small chopper (I *think* it will swing it) with the shaft 2.5-3 inches below the pad as a start. The go up or down (no low water PU) as needed.
  5. #19
    Definitely not a small ear chopper. 25 tempest would be a good starting prop.
  6. Likes RIVERRUMMER 70 liked this post
  7. #20
    englewood florida
    I've got a real nice 25 tempest. Capt. is right, choppers like to be surfaced. I can send pics of the tempest, 200. plus the ride. 941 544 8187
    18 Action 225 Promax
  8. Thanks RSWORDS thanked for this post
  9. #21
    Jul 2011
    Gloucester, VA
    Reason? Trying to learn.
    And on a semi related note... How high can I run a stock lower with a few holes plugged? At the speeds I can realistically reach with my "stock" 200 motor I don't feel I'd gain anything but putting a low water pickup and jacking it up. Or can I?
  10. #22
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by rkmirage View Post
    Sent a text
  11. #23
    Jul 2011
    Gloucester, VA
    Ok, got a 25 tempest on the way. And I guess I need to order a nose cone/low water pickup...
  12. #24
    Jul 2011
    Gloucester, VA
    Well, seems now working a deal for the motor that's on the boat also. It's a 2.4 200 with a ton of work. Boats run low 80s with it.
  13. #25
    englewood florida
    I'm a fan of the 2.4 200, I had a bone stock one on my Vector, I ran a best of 86.1 with a 28 small ear @ 6900. Just MAKE SURE you have water pressure!
  14. #26
    Sep 2015
    Twin Cities, Minnesota
    I love the 2.4 carbed motors on old boats, its like they were made for each other.
  15. #27
    Jul 2011
    Gloucester, VA
    So I got my hands on a good 3.0 liter carb 225. I'm thinking the extra torque might be nice with the large Vulture hull.
    From my reading I can mod a 20" opti mid to fit it fairly easy. It also has a torque master lower unit. Will the factory low water pickups be sufficient with a few of the upper intake holes plugged or should I nose cone it?
  16. #28
    Sep 2015
    cone it if your planning on hitting 100+
  17. #29
    Jul 2011
    Gloucester, VA
    Quote Originally Posted by Krazymaan View Post
    Negative. Lol I'll be OK at 80 for now. Mid 80s would be awesome
  18. #30
    Jul 2011
    Gloucester, VA
    So what kind of heights are a factory torque masters good for?
  1. 20' Hydrostream Vulture
    By xcheesehd in forum Hulls up to 20'
    Last Post: 09-12-2016, 11:12 PM
  2. hydrostream vulture?
    By 16ft superboat in forum General Boating Discussion
    Last Post: 05-25-2011, 09:03 PM
  3. New toy Hydrostream Vulture
    By bahamatrama in forum General Boating Discussion
    Last Post: 09-05-2010, 07:10 PM
