Results 16 to 30 of 51
Thread: Honing advice needed
02-10-2017, 07:31 AM #16
OMC has a big wide exhaust and transfer ports ,they need a chamfer top and bottom not just the edges taken off... the sides i dont worry too much about because the ring isn't passing over it parallel. just my opinion though , as was said many ways to skin a cat. Dave
02-10-2017, 07:50 AM #17
02-10-2017, 08:28 AM #18
02-10-2017, 09:41 AM #19
I use the little 1/4 drum sanders and a tapered stone then finish it with a tapered cratex, all 1/8 grinders nothing bigger. Dave
02-10-2017, 01:17 PM #20
Now I know how it should be done...
https://www.youtube.com/watch?v=6AJDZVFkHUY
Have a nice weekend!
02-11-2017, 09:00 AM #21
Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 8,861
- 1083
- 424
- 4810
- 2214
- 9 Post(s)
02-12-2017, 04:39 AM #22
Ordered som 280 grit stones for the Lisle, hope they will Do the trick
02-13-2017, 04:15 PM #23
For a one stone hone job that will straighten the bore up and leave a ready to assemble finish . The 280 is a good versatile workhorse .
Don't forget what H2OPerf said about using a good low speed / hi-torque drill motor back on the first page ..
02-13-2017, 07:01 PM #24
- Jun 2007
- 8,861
- 1083
- 424
- 4810
- 2214
- 9 Post(s)
have you go a finishing/plateau brush as well, they are the final magic?
02-13-2017, 09:09 PM #25
To make the rigid hones do their job and square the bore back up they need a fair amount of tension... if your not having to hold on to the drill like a sig-sauer .45 and clamp the block to the bench then you got it too light, it takes a bit of torque to do it and keep the rpm even. Rule of thumb is 1200 divided by bore size for rpm if your drill has a max of much more than 500 no load your never gonna get enough torque out of it when you throttle it down for a good cross hatch. Sorry was abit short on the first post. Dave
02-14-2017, 09:11 AM #26
Scream And Fly VIP
- May 2001
- Hickory NC
- 5,625
- 21
- 270
- 219
- 524
- 5 Post(s)
Agree with Dave but a 280 stone with that much tension will leave to coarse a finish IMO, I would lighten up just a bit after bore is straight/round and finish with a cylinder brush. You asked about lubricant when honing, if you don't have actual honing oil vegetable oil works good. I did have the ability to lower current to the drill to slow it down, also had a large air drill that turned 500 rpm without a load that I used to finish. If you really want to do it right install a torque plate and bolt an adapter plate to the bottom. I also honed them at operating temp.
02-14-2017, 09:32 AM #27
Hey Al, Honing at temp sounds like the deal. Dave
02-14-2017, 12:15 PM #28
I use a monster dewalt drill u can slow it down but it doesn't just stop. If ur taking .002 out of all 6 ur arms are wore out. Even though I was only half throttle One day the ridgid hone grabbed a machined spot at the bottom of a 3.4 block and stopped. Well the hone stopped broke a stone and the drill proceeded to try and break my wrist.
I know nothing about honing at temp. I've seen it done with big diesels but do you change the hone oil since the heat will change viscosity?
02-14-2017, 06:32 PM #29
Scream And Fly VIP
- May 2001
- Hickory NC
- 5,625
- 21
- 270
- 219
- 524
- 5 Post(s)
No Kevin I sprayed the hone with fresh oil. I only did this on race engines that needed to be able to run hard with minimal break in. Standard rebuilds were horned with plates but room temp and the finish was slightly rougher than a race build.
My drill had a big handle on it.
baja200merk thanked for this post
02-14-2017, 08:18 PM #30
7000 RPM
- Central Florida
- 2,662
- 9
- 42
- 35
- 253
Be careful with the big handle. It is the right way but if the hone sticks that handle is gonna swing and probably clip you right in the nads.
advice needed
By skeeter ss140 in forum Technical DiscussionReplies: 0Last Post: 07-18-2009, 03:35 PM -
Advice needed
By 99f350 in forum General Boating DiscussionReplies: 30Last Post: 01-28-2009, 09:15 PM -
Advice Needed
By kenroc in forum General Boating DiscussionReplies: 1Last Post: 05-15-2003, 04:53 PM -
Advice Needed
By spanky2002 in forum Technical DiscussionReplies: 7Last Post: 01-25-2002, 11:01 AM
