Page 17 of 42 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 ... LastLast
Results 241 to 255 of 622
  1. #241
    Rhode Island
    Had a tough time seeing where the timing was on the black painted flywheel, so I traced it onto masking tape. Also used some TIG welding wire to make a little pointer for easier reading. Timing is set to about 33* BTDC.
    Started running the hydraulic steering lines also. What a pain in the butt doing it alone!!! That was a mistake haha.
    Used a a ratchet strap to pull all the rigging through my shop vac hose, I mean rigging tube lol. Still gotta put a couple short pieces where it tees off. More to do today and tomorrow.
    Going to South Carolina Thursday to Sunday, but maybe next week I'll get to try firing her up!!! Will still have to adjust idle, and mixture screws.
  2. #242
    Rhode Island
    Well... She runs !!! Click the link...
    http://youtu.be/C4_G3LQ1rIc
  3. Likes FMP, Slimm, tux974 liked this post
  4. #243
    Need a rub strip for the rail . Timing at 33 will get close to 31 at top rpm so try a bit more when tuned in.
  5. #244
    Mar 2010
    Brigham City, Utah
    Looks sharp and sounds great. Are you going to add a Transom Saver Brace to the back of the trailer for traveling to and from the water?
    Karsten
  6. #245
    Rhode Island
    i have the rub rail- haven't put it on yet. Need a nice warm day, and a cooler of hot water.
    Quote Originally Posted by Karsten View Post
    Karsten
    yes, just not sure how I'm going to make the bracket for the trail or yet.
  7. #246
    Quote Originally Posted by home made tunnel View Post
    Attachment 339499 "Nice Job" congrats on the finish.
  8. Likes tux974 liked this post
  9. #247
    Nov 2003
    Portsmouth VA
    That, sir, is a cool little boat. Why don't kids nowadays see how much more fun these are than a video game???
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
  10. #248
    Jul 2010
    Stevens Point, WI
    Wow. Fun thread to follow. Really nice job!
    198? Merten Marine 14'
    30HP Yamaha Mariner 15", 10 3/8 x 18 Chopper II, CMC PT-35
  11. #249
    south florida
    I have enjoyed the build. You have definitely overachieved. Congratulations from the Chrysler crew!
  12. Thanks home made tunnel thanked for this post
    Likes home made tunnel liked this post
  13. #250
    Rhode Island
    Thanks everyone!!! Built, not bought !!!
    Were supposed to be getting another 8" of snow tonight, which sucks... But giving me some more time to get things finished up.
  14. Likes NICE PAIR liked this post
  15. #251
    south florida
    Has the ice melted yet? It is shorts and t-shirts here.... Waiting un-patiently for a water test...
  16. #252
    Rhode Island
    Questions!!!!
    What are the three bolt holes on the port side of my engine clamp for???
    Also, do I have the jam nuts for the vertical adjustment of the jack plate correct?
    I can't wait to put her in the water!!! Another week or two I think. Last week we got 5" of snow at 5am, and it was melted by 11am. Now the roads are all salted and sandy again. Thanks Rhode Island DOT!
    I made a new serial number plate. The original sticker was on its last leg. Screwed it to the side of the clamp.
    Finally Drained the lower unit oil. Very sludgy!!!
    I did a mock graphics inverted colors for the white motor cowl. I went with 1200cc rather than 90hp. Just to make people ask lol. Still putting the teeth/mouth up front though haha.
    To to do list: -Wire battery switch /make bracket.
    -Wire relay and power to fuse box
    -Wire gauges:Tach/Fuel/volt/water pressure.
    -Wire bilge pump and switch.
    -Wire lights and switch
    -Make horn mount and wire to switch.
    -sand windshield edges.
    -swap lower unit oil.
    -wire trailer.
    -install floor hatch cover latches.
    -paint inside non-skid.
    -Install rub rail.
    -get graphics & reg numbers
    -build cover pole/check cover fitment.
    -grease all engine parts.
    -register!
    -Attempt to scream and fly!!!
    Attached Thumbnails Attached Thumbnails image.jpg   image.jpg   image.jpg   image.png   image.jpg
  17. Likes NICE PAIR liked this post
  18. #253
    Rhode Island
    There's nowhere to mount anything on this little boat, so had to make a bracket for a small battery disconnect switch.
    Started running the new rubrail, but is slow work at sub freezing temps.
    Just got another 4" of snow today!!! And it's still snowing!!! Bizarre weather in Rhode Island. Can't wait to water test this thing, but the season isn't cooperating. Haha.
  19. #254
    SE MN
    The 3 holes are for a mechanical trim indicator or a nla power sterring setup. Use for whatever you need to, like boarding ladder. Great project, hope you do more over the upcoming years.
    SE MN
    If I am looking at the pic correctly, you need nuts on both sides of the tab the threaded rod goes thru.
  1. Never mind Quints
    By Wayne Cammidge in forum General Boating Discussion
    Last Post: 02-19-2015, 05:29 AM
  2. Mind if I vent?
    By QUICKSILVER in forum The Scream And Fly Lounge
    Last Post: 10-21-2003, 10:22 PM
  3. Keep An Open Mind
    By mr.clean in forum The Scream And Fly Lounge
    Last Post: 10-09-2003, 12:23 AM
  4. Tell me if I'm out of my mind!
    By cdaspeed in forum Props, Setup, and Rigging
    Last Post: 08-26-2003, 09:31 AM
