Page 14 of 42 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 ... LastLast
Results 196 to 210 of 622
  1. #196
    Rhode Island
    With the jack plate all the way up and using the highest bolt holes on the clamp, 2.5" below the pad is as high as I can get the motor.
    Got the power head together, found out I'm missing one carb gasket, and lost the flywheel key haha. Another week stalled. Still have yet to weld the new Skeg on, and paint The mid and lower.
    What do you guys think about getting a bobs nose cone for it? I can't raise it any more, so I don't think the pointy nose cone would help much.
    Attached Thumbnails Attached Thumbnails image.jpg   image.jpg   image.jpg   image.jpg
  2. #197
    Work the cages, no reed stops and thin strip along the bottom for the screws. No need for carb covers. Motor looks good, everything looks good.
  3. #198
    Mar 2010
    Brigham City, Utah
    I just had this discussion with the shop owner that hung the 150 off the back of mine and jack plate or not......What I took away from it was I wasn't building a race and clean water or dirty water......Clean water being 12 inches off the transom and dirty water anything from the transom back to 12 inches. While at the same time the prop has to be in the water completely or you will be sucking up as well as low cooling.
    I would dare say you want a little more prop in the water rather than less....Hell, I don't know....
    It looks like your Cav Plate and a good half of your prop is going to be out over the water
    I would think you need to get 2 inches lower to get some water.
    Again, I don't know anything more than I have been told lately and I haven't had a chance to put my boat on the water as everything is cover in ice.
    Your boat has some awesome style and great work on the windshield.
    Karsten
  4. #199
    Rhode Island
    Are you saying to only use the thin metal strip from the new reeds or no strip at all? I did get rid of the large reed stop from the metal factory reeds. I don't have a final picture though. Girlfriend was insisting I come to bed and rushed me LOL
  5. #200
    Rhode Island
    Quote Originally Posted by Karsten View Post
    Karsten
    Thanks on the Style points !
    I think I'm going to ask the question about height in the "Technical' section of this forum.
  6. #201
    This Viper went 85 mph , the Chrysler on it was jacked way up . Just look at were the cav plate would be if the spray wasn't in the pic, that's racing. The reeds need some support along the bottom edge. So a strip as thick as the stop from one side to the other, but just wider than the screws, and a clean edge so not to cut the reeds .
  7. #202
    Rhode Island
    Did you see the unopened package of reeds in my picture? The thin brass strip in that is all that I put on the cages. The factory stop with the three holes is gone.
  8. #203
    As long as the strips provide good support without deflection at the screw heads. You could cut thicker ones, those are really Merc cages so depending on who packaged the reeds the instructions might be a bit vague.Use the tread lok. They say to use the factory stops on Chryslers but I don't and at first I did, gained 50 rpm without . Then they said I could run without. I said thanks. They might have edited the instructions , also some small OMCs. Factory stops gone, big clean up ???
  9. #204
    Rhode Island
    I didn't use thread lock. Oops. There's a chance the screws will come out? They're in there pretty tight.
  10. #205
    South Carolina
    Been following the tread and enjoying the progress. Everything looks super. You've gone a long way on a 14' Bayliner....
    if if you plan to ski with it at all, you'll be glad for a little prop depth. I would run it with the stock lower before you invest in a nose cone. Sometimes under 60, the cone does more harm than good. Keep up the good work.
    You cannot bring about prosperity by discouraging thrift. You cannot strengthen the weak by weakening the strong. You cannot help the wage earner by pulling down the wage payer. You cannot further the brotherhood of man by encouraging class hatred. You cannot help the poor by destroying the rich. You cannot keep out of trouble by spending more than you earn.
  11. #206
    Use the thread lok, why take the chance.
  12. #207
    Jul 2007
    Delray Beach
    Quote Originally Posted by Velocity72 View Post
    That's good advice, I would even say unless you are running over 75 or 80, running at an elevated transom height, you don't really need a cone.
  13. #208
    Charlotte, NC
    Seconded on the thread lock. Seen it happen. Screw won piston lost.
  14. #209
    Rhode Island
    Got the Skeg welded on, and put a white stripe on the side. Still need to get the black rubrail installed. Too many more things to do ! Really not looking forward to wiring.
  15. Likes FMP liked this post
  16. #210
    Looks good. Hows the oil look? Spring time . Snow this way.
  1. Never mind Quints
    By Wayne Cammidge in forum General Boating Discussion
    Last Post: 02-19-2015, 05:29 AM
  2. Mind if I vent?
    By QUICKSILVER in forum The Scream And Fly Lounge
    Last Post: 10-21-2003, 10:22 PM
  3. Keep An Open Mind
    By mr.clean in forum The Scream And Fly Lounge
    Last Post: 10-09-2003, 12:23 AM
  4. Tell me if I'm out of my mind!
    By cdaspeed in forum Props, Setup, and Rigging
    Last Post: 08-26-2003, 09:31 AM
