Results 1,411 to 1,425 of 1571
Thread: Yamaha 130 V4 Project Build.
02-06-2016, 06:31 PM #1411
So.....
Good news and bad news.
The good news is I picked up 200 rpm cutting the tuner! Lost a little below maybe 4500 where is feels a little "soft" now but no problem breaking the prop loose and jumping up on plane. Big gain up top though. 2.5mph which in theory puts me over 100mph.
And now the bad news. My lightened flywheel came apart at about 5500-6000rpm and did some damage. The ring gear seperatated and fell down destroying the stator, timing advance, ate some of the starter, etc. What worries me is there are metal shavings all over. When it went the motor immediately shut off but Im worried I ingested some metal. It was raining when I got home so I parked and took nap
Ill take a closer look tomorrow.
First time being towed. Luckily there was another ramp close by.
Big thanks to Mike M. (DagoDiver) for the tow and going to get my trailer.
21' Paramount
Mercury 300 Promax
02-06-2016, 06:40 PM #1412
Ya...that's a bad day...be glad that it didn't hit you in the head! It's really not that far away lol.
'08 SRV
Yamaha 3.1 Phase III
02-06-2016, 08:28 PM #1413
Be glad that ring is round and just the center failed.
The mechanicals can be fixed.Regards,
Charlie North
If it ain't broke, modify it.
87 Glastron CVX20 Hull
02-06-2016, 09:34 PM #1414
Yup its just parts. Im going to pull the intake and see if there's any metal shavings present.
She really woke up over about 4500rpm. I was all smiles for about 10 minutes.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
02-07-2016, 08:35 AM #1415
02-07-2016, 12:49 PM #1416
you have to do it to make it count. and that you already know. but i agree it looks good on paper.
02-07-2016, 02:56 PM #1417
02-07-2016, 03:43 PM #1418
The boat and motor do not know the difference between 95 and 100. The boat does not know of any magical limit. Only you know what the boat is telling you when it is up at speed, it is easy for all of us to just say go do it. To me if the boat felt good from 90 to 95, I expect it should feel fine through the next step up, unless you can sense that may not be the case. If it might not be the case then you should not go there.
Remember back in 1999 all the stupid talk of what was going to happen, nothing did. So is 99.9 any different?Regards,
Charlie North
02-07-2016, 08:17 PM #1419
baja200merk liked this post
02-08-2016, 10:22 AM #1420
02-08-2016, 11:07 AM #1421
Got it all apart yesterday after quite a battle with the flywheel. Took a puller, bottle of map gas, penetrating oil, and an air chisel to get the flywheel off.
When I pulled the flywheel, 3 magnets stayed on the stator. I kind of wonder if one had come loose and sent the flywheel on a path to self destruct.
The stator and trigger ae destroyed. There is a good grind mark on the top bearing housing but it should be fine. I dont think you can remove that cap with splitting the cases.
Ill pull the intake and inspect for any fragments but I think I am okay. I swabbed the carb throats with cotton swabs and found no metal.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
02-09-2016, 10:58 AM #1422
02-09-2016, 11:24 AM #1423
Thanks buddy. Ill let you know.
I found all the large metal parts I was worried about and even though there was shaving everywhere I checked the intake, reeds, etc and cant find a speck. Scoped the cylinders and they look fine so I think I lucked out in that respect. I did see Im still running a little rich even with the cold weather and coming down in jet size so theres a little more power there keeping the jetting safe.13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
02-09-2016, 12:47 PM #1424
Found a PRISTINE fresh water flywheel and stator looks like brand new Im buying.
You know the flywheel new now is like $1000, stator is $700, and trigger is $350.....WTF???????????????????13' Biel tunnel AKA "Flight Risk"
21' Paramount
Mercury 300 Promax
02-09-2016, 12:58 PM #1425
Screaming And Flying!
- 15,028
- 402
- 1432
- 5953
- 11572
Price of parts is going crazy for all the motors.....Good thing you didn't hurt anything else.....
