Results 106 to 120 of 129
07-25-2015, 05:54 PM #106
Junior Member
- Jul 2015
- NJ
- 17
It might be a missile then, for some reason I thought rabcos only had inserts. The title has it as a donzi but the HIN comes up at homemade. It has the last inspection as of 89
07-25-2015, 08:30 PM #107
either way...put a v/6 merc on it and let her rip....thrill a minute ride for no $$$$$ ..it has a 15" cut down transom so prob ran an old in line L6 in the day....he got it for nothing..." MONEY FOR NOTHING AND THE CHICKS FOR FREE"...GO FOR IT !!!
07-25-2015, 08:31 PM #108
We built a bunch in 76
SEEBOLD CHAMPBOAT MERCURY S3000
HeavyDuty liked this post
07-25-2015, 08:32 PM #109
What is the original gel??? was it metal flake underneath the paint?
07-25-2015, 08:37 PM #110
out of the 42 we built 30 of them were metal flake, we put some trick paint jobs on a few of them in 1981 and 82
07-25-2015, 08:39 PM #111
PARKER.. didn't you make two bottoms for that boat...one was faster than the other???
07-25-2015, 08:48 PM #112
Junior Member
- Jul 2015
- NJ
- 17
07-25-2015, 08:59 PM #113
MAGNUM never made a blue hull that I remember...
07-25-2015, 09:26 PM #114
Yes one bottom had a flatter running surface, had more lift...that's the bottom that would blow over
07-26-2015, 05:45 AM #115
07-26-2015, 07:48 AM #116
the DUO, DUTCHMAN, STARCRAFT hulls had a flatter running surface, different than the sharp edge of the MAGNUM= RABCO as I recall...got some pic's side by side somewhere...
07-27-2015, 12:28 PM #117
Junior Member
- Jul 2015
- NJ
- 17
I have no idea on the original color then. I should have the cap removed from the boat before the weekend.
07-27-2015, 01:51 PM #118
cool take some pictures
07-28-2015, 09:13 AM #119
Junior Member
- Jul 2015
- NJ
- 17
Ok im about to have the cap split, how much fiberglass mat and resign should i buy? I need to do the floor and the caps core and transom
07-28-2015, 12:14 PM #120
that's like asking how much paint do I need to paint a car. It all depends on how you lay everything back up, laminate the transom or not, how many layer on top of the core, etc etc. Start with a couple of gallons. you have to measure and determine how much and what kind of mat you want to use / need.
Good luck
