Page 54 of 105 FirstFirst ... 4 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 104 ... LastLast
Results 796 to 810 of 1571
  1. #796
    Aug 2004
    Venice, Florida
    It probably had wing plates and string steering. It something I didnt realize when I bought it. Im taking the drive shaft up to Marty Powell to be shortened and going to have to talk to him and Dago about doing something. I either have to have my old steering arom put on this or come up with a side steer.
    The problem is the swivel tube assembly is welded. No way to take it apart without cutting.
    I got it all bead blasted and cleaned up and had to get some primer on it.
    21' Paramount
    Mercury 300 Promax
  2. #797
    Aug 2004
    Venice, Florida
    Ironically....I just got off the phone with Marty. Im going to bring my stock steering arm assembly with me when I head up there. Going to have to shorten mine and switch over or make something up. Whatever he feels is the safest. I really dont like the cast steering arm. Maybe we will make up something from plate.
    21' Paramount
    Mercury 300 Promax
  3. #798
    East Wallyworld Vt
    You could cut the bottom mount off and cut down another swivel tube. That lower bracket is a simple weldment that can easily be replicated.
    Another option is to pickup a few of the mid to upper mount bolts as one would for sidearm or cable but bring a plate or weldment forward for your existing front mount.
    Obviously many other options out there too.
    Regards,
    Charlie North
    If it ain't broke, modify it.
    87 Glastron CVX20 Hull
  4. #799
    East Wallyworld Vt
    Took me too long to write, you got another post in,
    If I recall the tiller arm on my V6 is a stainless forging. Been so much rain up here I have not looked at mine in awhile.
    Regards,
    Charlie North
  5. #800
    Aug 2004
    Venice, Florida
    The wheels are turning. This actually might be a good thing. If I can raise the steering arm closer to the bottom of the pan it will give me more room to tilt the engine up before the steering hits the engine well. Its going to be very close as it is.
    Gets me thinking....
    My pan is solid aluminum and very heavy duty. I could have a steering arm bolt that went through the pan, through a block between the pan and steering arm and through the steering. It would tie the pan and the steering arm together making the pan kind of a big wing plate.
    21' Paramount
    Mercury 300 Promax
  6. #801
    East Wallyworld Vt
    My steering arm is raised a bit, plus you can look at mounting the steering to the top of the arm.
    I have drilled the pan to access the bolt.
    The pan is cast, I would not place much faith in it structurally but that does not mean it couldn't be reinforced and be used as a doubler for the cylinder mount.
    Regards,
    Charlie North
  7. #802
    Feb 2012
    Canada
    Quote Originally Posted by Mr. Demeanor View Post
    Real nice !
    Any thoughts on an exhaust snout ??
  8. #803
    Aug 2004
    Venice, Florida
    Quote Originally Posted by evilrude 1 View Post
    Real nice !
    Not much mid there to be cutting into and I need exhaust out the prop hub to help break these big props loose with my little motor.
    The tuner is going to be pretty much right down into the gearcase so I dont think a snout would do much. The end of the tuner would be lower than the snout. Im hoping the tuner fits. Hydrotech told me cutting the tuner to 11-1/2" on a stock motor is worth 8-10hp, probably a little more on a modded motor but it kills the bottom end.
    21' Paramount
    Mercury 300 Promax
  9. #804
    southast ark
    Could you not build a shorter steering arm out of stainless and have it machined. Shouldn't be no problem for a competent machinist and I know you are close to some very professional ones..... The ones that have already done some work fer ya
    Laser 1550 ...under construction with a serious weight loss
    Motor 2.4....undecided on hp yet
  10. #805
    Aug 2004
    Venice, Florida
    Talked to Dago today about making one up out of stainless. It could be made to bolt right to the upper motor mount bolts.
    21' Paramount
    Mercury 300 Promax
  11. #806
    sw florida
    After looking close at your engine at
    The lake today i have an idea.
    Answer your phone.!
    Dago
  12. #807
    Apr 2013
    Canada
    Aug 2004
    Venice, Florida
    Quote Originally Posted by dagodiver View Post
    Answer your phone.!
    Dago
    I was busy pulling the powerhead
    Sorry my phone died in mid sentence. Kind of the theme for the day.
    21' Paramount
    Mercury 300 Promax
  14. #809
    Aug 2004
    Venice, Florida
    Decided to tear it apart and dry fit some parts before painting and ran into a pretty big issue.
    The way the swivel was done in order to get the mid down to 15" also adds 1.5" of setback which is exactly what I dont want. Im going to have to get Marty Powell to look at it and see what he thinks. If we reduce the setback, the bracket at the bottom of the swivel will hit sooner reducing how far I can turn the wheel side to side.
    Tuner is also an inch longer than the midsection.
    You can see here with the bracket for the bottom motor mounts right against the mid, the top is about 1.5" out. would have to make some spacers and get longer upper motor mount bolts which isnt a big deal but I dont want the setback. It may also cause issues with my steering etc. but I can probably just make the new tiller arm longer.
    The other option would be to simply remove the jack plate and see what happens. That would be another 20 pounds off the transom and my setback would be about the same in the end (my jackplate on has 1.5" of setback). The downside is if the boat doesnt like it, it would mean taking it all apart again.
    As it sits, the new mid/swivel is 9 pounds lighter than the old. Lose the jackplate would be a total loss of about 25 pounds by the time I add back in a new tiller arm. Thats huge on this boat.
    21' Paramount
    Mercury 300 Promax
  15. #810
    Don't use 5200 if bolt the motor directly to the transom.lol
    25lbs less weight on the back of your boat could really screw up the balance.
