Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 33
    Jul 2009
    Napoleon Mi
    Sunken Glastron GT-150
    Here is what I went out to today!
    YouTube - Sunken Glastron GT-150 15' speedboat.
    Everything is fine, but when it runs now you can't grab the throttle/shifter without getting shocked. It feels like spark plug voltage! Any ideas what to look at? Motor is a 1986 Merc 90hp.
    Thanks guys!
    Trip..
    Wiring harness/keyswitch is wet or the ignition wire (yellow/black) is shorting through the box. When you touch it, it is using you for ground.
    1970 15' Allison/135 Chrysler stacker
    RC Mod-VP Boats
    IMPBA District 13
    NAMBA District 3
    Dec 2004
    Massapequa, N.Y
    that sucks Boats are
    Pekin, IL
    Bummer dude. Personally I think I would let it sit and dry out for a few days. Jack the nose as high as you can to promote drainage. If you have a copmpressor handy maybe blow out the control box as there could easilly be water trapped inside. I would also have one or several fans blowing inside there. Gotta get it dry so the wood don't turn crappy. Nice boat however.
    Rock
    Team Junk
    Apr 2009
    salem NH
    That stinks. Thats why I use a shorestation. raise it so high when I leave nothing in the water.
    R.I.P Paul Lanzillo September 23, 1956,August 30, 2009 Miss you Brother
    Jul 2005
    snohomish washington
    Quote Originally Posted by stream18 View Post
    yeah thats why screamandfly has become so popular. boats suck
    88 cougar mtr 19'
    '93 2.5 fishin motor made into a 245hp
    '71 marlin 16' flat btm v-drive 550hp 427ci set up for drag.
    Originally Posted by Hydrophobic guy
    I'm not a contractor but, I did stay at a Holiday Inn Express last night.
    Aug 2003
    Gilbert Arizona
    If you tied it bow out it would probably still be floating.
    Jul 2009
    Napoleon Mi
    Quote Originally Posted by Mark Poole ModVP View Post
    Thanks for the heads up on the yellow wire! It doesn't shock as badly as it did last night right after I drained it.
    Quote Originally Posted by rock View Post
    Bummer due. Personally I think I would let it sit and dry out for a few days. Jack the nose as high as you can to promote drainage. If you have a copmpressor handy maybe blow out the control box as there could easilly be water trapped inside. I would also have one or several fans blowing inside there. Gotta get it dry so the wood don't turn crappy. Nice boat however.
    Rock
    It sat all day w/o the cover on a 95 degree day. I took my shop vac to it an sucked it as dry as I could. It feels pretty dry now, but I know it is wet under the floor. Thanks for the compliment on the boat!
    Quote Originally Posted by wideglide55 View Post
    The water is so shallow I can't tie it up bow out without the skeg digging in the dirt.
    Trip..
    Jul 2008
    Binghamton, NY/ Raquette Lake, NY
    I dont know about yours but with mine if the rear trim pieces get in the water where the top half of the boat is connected to the bottom half it takes on water like crazy. It doesn't need to get that much water in it either for those pieces to go below the waterline. I bought a big ass automatic bilge pump and I always put a cover on it at the end of the day. I leave my boat in the water all season.
    '72 Glastron GT-150 Johnson Stinger 65
    '83 Hydrostream Varmint 2.4 225 Mercury
    '05 Hydrostream Voyager 250xs optimax
    Ft. Lauderdale, Fl
    Are you sure that dude with the jetboat didn't get out of jail and pay you a visit?
    Miami,Fl
    Quote Originally Posted by flabum1017 View Post
    I was thinking the same thing or did the side catch under the dock at tide change? I have seen that happen. Rick
  12. #12
    Jul 2009
    Napoleon Mi
    Quote Originally Posted by gregpro50 View Post
    I would love to see a pic of the automatic bilge pump! I cannot figure out a good place to mount mine, it's too small of an area. Mine was cobbled up with "Plumbers strap" and didn't fit worth a poop!
    Mine leaks like crazy between the cap and bottom too, right at the rub rail. The previous owner pumped a bunch of caulk in the seam to stop the leak. It helps, but it still leaks. I think this is where the "Flood" started!
    Trip..
  13. #13
    Jul 2009
    Napoleon Mi
    Quote Originally Posted by delawarerick View Post
    As far as the guy with the jetboat... I don't think so... The plug was still in! I did wonder though, if he may have come back and dropped anchor, while raising his "Hose" and putting his "Bare foot" gas pedal to the floor??? That would fill my little boat in a few seconds!
    As far as the tide, this is too small of a lake for the tide. Catching under the dock? Very good possibility!
    This boat only sits about 6-8 inches out of the water at the stern! Kind of a low-rider. LoL..
    All is OK now, except the shock every time I grab the control/shifter handle! That's fun!!
    It feels just like grabbing a hold of 110 A/C! Same buzz. Similar to grabbing a plug wire, but a little different. But, if I wiggle some wires it doesn't shock me as bad! lol
    Trip..
  14. #14
    Cincinnati
    Ive had that happen
    Quote Originally Posted by Trip View Post
    Thanks guys!
    On my houseboat I have a 75Hp Mariner. It would shock the crap out of you. On mine it was the wireing harness. The clip had come loose and all of the wires were not making contact. I pushed the plug back together and it was fine. It might not be a bad idea to disconnect the wireing harness and WD-40 it and reassemble. Mine was on the side of the powerhead.
    Good luck
    L.T.
  15. #15
    Jul 2009
    Napoleon Mi
    OK, thanks. I will look for that.
    Trip..
