Results 1 to 3 of 3
Thread: Inline Block Preservation
Yesterday, 02:23 PM #1
Junior Member
- Jun 2025
- Rochester, MN
- 7
I have this posted on one of the FB groups as well, but figured I'd inquire here also...
I have a couple of mid-80’s towers I have picked up over the years with low compression in one cylinder. My plan is to eventually rebuild them as a hobby. I have a source for the blind boring/honing, but have a few questions regarding maintaining the blocks/motors throughout the process. I tend to tinker with things over the course of months and even years. The motors are currently complete and stored on stand inside a heated garage. I fog the cylinders now and again through the plug holes and turn the flywheel over by hand.
I’d like to start tearing these things apart and getting the blocks ready for machining. What is the best practice for keeping the internal block and crank/components free of rust/corrosion both before and after machining? I’m anticipating the rebuild will progress over several months. Just want to keep the components as protected as possible after opening up the block and while everything is apart.
Just coat everything in oil and wrap in plastic? Any parts/areas I need to focus on aside from the cylinders and pistons. Any harm in storing the lower units with the oil drained?
Yesterday, 02:44 PM #2
Supporting Vendor
- Sep 2006
- Key Largo, Fl
- 3,350
- 259
- 30
- 716
Oil and shrink wrap most everything that can rust,Do NOT store the lowers empty.I have oversize pistons,and good gasket sets if you need them,Chris
MNhunter1 liked this post
Today, 08:01 AM #3
6000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,938
- 591
- 100
- 514
- 626
a climate controlled environment is a plus. i used to use brown paper bags,spray inside w/ wd40. marked with sharpe
Mercury Inline 6 ADI Block
By MacGyverJB in forum Misc. Parts and AccessoriesReplies: 0Last Post: 08-21-2019, 10:51 PM -
Help with Inline 4 - '71 Merc 650 (Panther block)
By Ron V in forum Technical DiscussionReplies: 1Last Post: 06-09-2012, 08:40 AM -
Un-painted block inline 6 ?
By inspectorlance in forum General Boating DiscussionReplies: 11Last Post: 06-11-2009, 06:14 PM -
Inline 1500 Block ID
By gstorr in forum Technical DiscussionReplies: 1Last Post: 01-05-2009, 03:03 PM
